BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Front PDC coding
Studio RSR
      01-17-2022, 07:09 PM   #1
Mitraks
Mitraks's Avatar
Drives: BMW 320d Sport line
Front PDC coding
Hi everyone
I got a problem with coding , I install front pdc retrofit (I have rear from beginning) , all coding was without any error but then I see on screen that there is error with park sensors and I need go to service , it's doesn't work at all , rear and front. I put the wire wrong ? Or I need to update my rem ecu?
My car is from 2013
      01-17-2022, 08:05 PM   #2
Jhnblckwood
Drives: F30 2014 320i xdrive
Originally Posted by Mitraks View Post
Hi everyone
My car is from 2013
I doubt the rem needs flashing. If yea I’d check your wiring.
      01-18-2022, 11:27 AM   #3
Mitraks
Mitraks's Avatar
It's possible because I made cable by myself
I put cable from 6-pin socket like this
Pin 1 to A174*14B PIN 48
Pin 2 to A174*14B PIN 36
Pin 3 to A174*14B PIN 53
Pin 4 to A174*14B PIN 40
Pin 5 to A174*14B PIN 41
Pin 6 to A174*14B PIN 52
It's that correct?
      01-18-2022, 05:30 PM   #4
Jhnblckwood
Not sure sorry I only did rear pdc. Did u remove the code for rear pdc then added the single code for both? Idk if it would let u so that but I would definitely check the wiring and connections and coding. If all else fails u can try flashing. My rear pdc didn’t work until I flashed but since ur rear is already working I’d be surprised if it needs flashing but I can’t say for certain. Check n double check your wiring. Imo
      01-21-2022, 05:41 PM   #5
Mitraks
Mitraks's Avatar
So I check all wiring and I looks correct.
I speak with one guy and he said I need another rem module. What do you think ?
      01-22-2022, 12:12 PM   #6
Siki78
Siki78's Avatar
136
Drives: F30,G30
Do TAL calculation with esys and you will see if you need other REM
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      01-26-2022, 08:52 PM   #7
Jhnblckwood
Are the pins in the rem there? I hope that’s not the case bc I bought a rem with rear n been meaning to do front pdc. Hate to have to get another rem. Pls lmk.
      01-27-2022, 07:10 PM   #8
Mitraks
Mitraks's Avatar
I check and my rem is fine , when I use ISTA it's shows "short circuit" so I guess I do something wrong with pins , I use 928999 pins
I use 0.35 cable like it's shows on diagram so maybe I suppose to use 0.5 cable ?
      01-29-2022, 02:27 PM   #9
Jhnblckwood
I doubt that’s the issue. Make sure the pins are fully in on the rem connector and just verify the wiring n double check all connections.
      01-29-2022, 02:29 PM   #10
Jhnblckwood
U can try to upgrade the istep if u run out of options. The rem I bought came from a car with rear pdc n after installing rear pdc it still don’t work until I flashed it. The istep might be too different from ur car. Worth a shot.
      01-31-2022, 07:20 AM   #11
Mitraks
Mitraks's Avatar
So , all pins are connected correct and this is what BimmerLink show me
I don't check connecting X187*1B/X187*1S yet
Any ideas?
      01-31-2022, 10:56 AM   #12
Mitraks
Mitraks's Avatar
ALRIGHT
I check X187*1B and it was totally f*ck , so I just connect wire to wire AND IT WORKS.
Thanks you all for help
      02-02-2022, 12:48 PM   #13
Jhnblckwood
ALRIGHT
