10-21-2021, 06:00 PM | #1 |
Rep 80
Pushing around 500-540 whp with custom tune.
After long consideration I have decided to upgrade the hpfp and get a custom tune. I'm going for the Full E85 by Cary Jordan and they said I should be looking around 500whp-540whp. Any tips on running this much power on N55?
2014 m sport 435i rwd fbo upgraded turbo VRSF Chargepipe, vrsf race fmic, and hi flow downpipe BMS aluminum elite intake Stage 2H 93 bootmod3 ngk 97506 Cold spark plugs 0.020 PR Ignition Kit Vargas stage 1 upgraded turbo 93500 miles xHP stage 3 transmission tune 3.5 Bar Tmap Sensor MST Inlet FTP Outlet Dorch Stage 2 HPFP |
10-21-2021, 08:32 PM | #2 | |
1296
Rep 3,532
10-22-2021, 12:55 AM | #3 |
@lbb_kev
490
Rep 514
I'm not familiar with the Vargas, but 500-540whp seems high for a stage 1 turbo. Assuming the turbo is good for that power goal at full E85, keep in mind that you might encounter LPFP issues at 500+ whp if you're still on the stock LPFP depending on the tuning strategy.
I'm doing about 600-620whp on full E85 on a Walbro 525 lpfp and it's about at the limit.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | Dorch Stage 3 HPFP | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
10-22-2021, 01:16 AM | #4 |
Rep 2,357
Good luck with that. Vargas write 45-70whp over stock on their own website. Cary is quite the sales man
(A Dane in China) |
10-22-2021, 06:34 AM | #5 | |
Rep 2,639
10-22-2021, 07:37 AM | #6 |
Rep 415
You’ll need a stage 2 turbo to make that sort of numbers.
Peter at pure turbos eu makes 530-550whp with ps2, upgraded hpfp and a hcp map on most of the 35i engines they do. Solid recipe to make that kind of numbers. |
10-22-2021, 11:04 AM | #7 | |
@_sunbish
282
Rep 611
must be using the same dyno as this guy https://www.2addicts.com/forums/show....php?t=1859639
If the log comes back good and you aren't happy, go get your custom e85 tune from CJ for a little more oomph. Last edited by 5w20; 10-22-2021 at 11:19 AM.. |
10-22-2021, 01:19 PM | #8 |
Rep 7,598
I'll just add +1 to basically everything above:
1. Reaching 500whp with stage 1 turbo will be very difficult/impossible 2. Full E85 will require LPFP upgrade, which potentially requires EKP upgrade as well. Stock LPFP runs out of steam around E70 on stock turbo, maybe a little earlier for you. Plus, lots of diminishing returns after about E50-60. 3. Try the BM3 stage 2+ OTS map before you spend money on a custom tune. (With HPFP and around E50) |
10-22-2021, 01:29 PM | #9 | |
1296
Rep 3,532
10-23-2021, 12:17 PM | #11 | |
Rep 221
Paul Johnson E50 Custom tune (stock turbo) --- 408 whp PTF Stage 2+ E30 tune (with E50 fuel) --- 415 whp I also wouldn't trust any tuner that tells you they can make 500whp on stage 1 or stock turbo, even with fuel e85. Max HP on stock or stage 1 turbo is probably 430whp (stock turbo) and 460-475whp (vargas stage 1). |
10-23-2021, 01:51 PM | #12 | |
Rep 2,639
10-24-2021, 04:32 PM | #13 | ||
Gettin It Figured Out
1820
Rep 2,669
+2 on EKP .
10-24-2021, 09:01 PM | #14 |
Head Fry Cook at McBurgertown
507
Rep 1,005
The manifold itself will flow enough to reach those numbers, but I'm not sure the compressor and exhaust wheels on a S1 will flow that much.
Probably hit reversion (exhaust gas backed up into the cyclinders) and sky-high exhaust gas temps before you get that much airflow through an S1. |
10-28-2021, 12:35 PM | #15 |
Rep 87
Im on PS2 LPFP HPFP + Meth, 93 made 500 flat on my dyno, I think the stage 1 turbo will blow if you tryn to run it past 450WHP,
If my tuner suggested me to run something like that knowingly it wouldn't/Not meet my goals and have me pay, I'd have major trust issues. |
10-31-2021, 10:26 AM | #16 |
Rep 190,750
Send Cary your mod list and he'll let you know how much power his map can safely make
tklgarage0.00 |
11-01-2021, 10:08 AM | #17 |
@_sunbish
282
Rep 611
11-01-2021, 11:49 AM | #18 |
Rep 190,750
Ah, I did not realize, "they" referred to Cary. My bad
11-25-2021, 12:18 AM | #19 |
Rep 59
I have a similar setup but w PS2. See below. Question is do you guys think I need the turbosmart diverter instead of the BMS bov adapter and is the ekp needed with my fp upgrades? Also should I run eXX mix or 110oct for Dyno max pulls?
Dyno on 12/3/21. Custom Jb4 map6 currently e30 2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package |
11-28-2021, 09:19 PM | #20 | |
Rep 7,598
You need to check with Walbro on the demands of that LPFP to see if it requires a EKP or not. |
11-28-2021, 10:00 PM | #21 | ||
Rep 5,392
11-29-2021, 07:09 AM | #22 | |||
1296
Rep 3,532
johnung4528.00 |
