09-24-2021, 04:43 PM | #15974 |
Rep 40,753
No. E-Sys is for Coding and Programming. For Diagnosis, you need ISTA+.
09-25-2021, 09:35 AM | #15977 |
Rep 40,753
PM sent.
09-25-2021, 11:15 AM | #15978 |
Rep 8
09-25-2021, 11:21 AM | #15979 |
Rep 40,753
PM sent.
09-29-2021, 01:09 PM | #15981 |
Rep 40,753
PM sent.
09-30-2021, 08:27 AM | #15982 |
Rep 35
Hi,
Can you tell me what's the difference between coding on running engine or ignition? Most of the people recommend to do it on ignition. Are there any contraindications, that coding on running engine can brick something? |
09-30-2021, 09:58 AM | #15983 | |
Rep 40,753
Coding with Engine running ensures all ECU have adequate Voltage, and so long as you do NOT code DME / DDE (Engine ECU) with Engine running, then you have nothing to worry about.
09-30-2021, 08:10 PM | #15984 |
Rep 35
OK, thanks for answer, that's what I was thinking about. I was aware of suddenly lost of power, because of low battery.
But I can't understand why people recommend to do it on ignition only 🤔. The same case when we talking about esys or bimmercode, even manufacturer of bimmercode says in manual that should be use on ignition. Confusing. |
10-02-2021, 10:59 AM | #15986 |
Rep 40,753
Your Receive PM function is disabled. PM me when working.
10-04-2021, 05:01 PM | #15987 | |
Rep 22
10-07-2021, 04:41 PM | #15989 |
Rep 40,753
PM sent.
10-07-2021, 05:02 PM | #15991 |
Rep 51
Hi Shawn, where i can find the latest cheat code for F36. i want to see if i can change the setting from 6.5" to 8.8" screen, it was because i bought a aftermarket 10.25" screen. and i would like to change the screen setting.
thank you so much |
10-07-2021, 05:14 PM | #15992 | |
Rep 40,753
You want to change from 6.5" to 8.8" to install a 10.25" screen?
10-13-2021, 02:15 PM | #15994 |
Rep 40,753
PM sent.
