02-24-2021, 11:46 PM | #1 |
Rep 31
2014 328i xDrive stalling at low rpm
It started about a week after I installed a cold air intake and changed the muffler. I would start the car, wait for it to warm up like usual but then it would just start stalling once it drops below 1000rpm for the idle. I usually idle around 600rpm, but now I dont idle at all, since whenever the car gets below 1000 it just starts running really rough then shuts off. I can add gas it keeps the car going, but no matter how long I run the car for it never idles properly. I just changed the spark plugs because someone had a similar problem for me and all they did was change the plugs, but no joy. I'm about to take it to the mechanic to see what they come up with. any ideas?
02-25-2021, 07:35 PM | #2 | |
Rep 31
02-26-2021, 01:33 AM | #4 |
Rep 31
Yes, after a bit of running the car from sport to eco, the code P0172 came up. This might be because when I first changed to the cold air intake, I cleaned the MAF with MAF cleaner. After clearing the code, I cleaned the MAF again, but no luck. But before I had changed the coil pack, there would be a code for misfire on the second cylinder, which is also why I changed the coil pack there. Sorry should've included the misfire code in my original post, but after running the car at idle for around 5 minutes, no other code but P0172 came up. (Running rich bank 1)
03-01-2021, 02:28 AM | #5 | |
Rep 31
03-01-2021, 07:10 AM | #6 |
Rep 16,060
I would have put the stock intake back on the car. BTW, the stock intake is a cold air intake, so there's little to nothing to be gained by replacing it. The liquid coming out of the exhaust is probably water. It's supposed to do that.
03-05-2021, 03:38 PM | #7 | |
Rep 31
But after taking out cylinder 2's spark plug, I saw it was covered in carbon, meaning the fuel injector on cylinder 2 is spewing. I replaced it myself, about $200 including tools, and had to re-code the value for the fuel injector into the computer. I start the car up and; it runs perfect. No more stall, no more misfire, and all the boost has returned. Turns out after all my troubleshooting it was a faulty fuel injector. Thank you everyone for the help |
