BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > Ideal winter tyre setup for 2017 340i xDrive
      08-01-2021, 09:33 PM   #1
F30FanGuy
F30FanGuy
Drives: 2017 340i xDrive MPPSK
Hi All,
New member here! Just love the F30 generation 340i. I just got a pre owned 2017 340i xDrive, and wanted to know what wheel and tyre size would be ideal for snow conditions here in Toronto. I would prefer a non staggered setup if it is more economical and could work.
Current Vehicle info:
2017 340i xDrive
Estoril Blue
Track handling package
M Sport Brakes
Front wheel/tyre setup: 225/40 R19 89Y
Rear wheel/tyre setup:255/35 R19 92Y
I would appreciate inputs and some guidance
Thanks!
      08-01-2021, 09:50 PM   #2
cfm56d7b
Are you planning to buy a dedicated set of wheels for the winter setup?
      08-01-2021, 10:50 PM   #3
F30FanGuy
F30FanGuy
Hello! Yes planning to buy wheels + tyres dedicated to winters.
      08-02-2021, 01:50 AM   #4
Kooner23
Drives: F30 335i & E92 328i
My friend has 245/40/18 square on an xDrive 340i for his winters. It fills up the wheel gap more but the sidewall will be taller if you don't mind that look. A lot of tires are available in that size as well.
      08-02-2021, 12:01 PM   #5
frazervalley
Drives: 2015 328i xdrive
Welcome to Bimmerpost.
Not what you are asking, but if I owned a car like yours, I would garage it and drive a beater with very good snow tires in the winter.
I understand this may not be an option for you. I very much like the colour and the engine in your car, enjoy!
      08-02-2021, 12:49 PM   #6
ak22
ak22's Avatar
Drives: 2018 F30 340i xDrive
I'm running a 225/45/18 square setup on my 2018 340i xDrive.
i128316.00
      08-02-2021, 07:54 PM   #7
F30FanGuy
F30FanGuy
Haha! Thanks! yeah that might not actually be an option. Yeah the B58 is really nice. Especially with the M power kit and Exhaust.
      08-02-2021, 07:56 PM   #8
F30FanGuy
F30FanGuy
Gotcha. I will most prob run the same square setup as well. The -1 size will help with potholes and all.
Ive heard a lot about the Bridgestone Blizzaks. But looks like these cost north of $250 a piece! Any suggestions for a more economical tyre?
      08-03-2021, 06:53 AM   #9
Th3Walrus
Drives: 2020 X3MC Alpine White/Sahkir
What ak22 said. 225/45R18 square setup is the proper size. 245/40 is too wide for the winter, although you'd likely be ok in Toronto.
Blizzaks are the way to go. Start looking for a used set on Kijiji. I got mine last Oct, used for 3 winters on a set of replica black BMW BBS look rims for $1100. The guy paid $3600 new for them, and returned his leased 4 series early after losing his job due to Covid.
If you think $250 a tire is expensive, you're in for a huge surprise if you have to replace one rear 255/35R19 run flat due to a screw in the sidewall.
      08-03-2021, 07:55 PM   #10
Bongoxxx
Drives: 2018 340 XDrive
I’m running 225/45/18 square setup with Nokian Hakkapelitta R3s
I run Blizzaks on my wife’s car, blizzaks are a bit noisy compared to the Hakkas.
Current: 2023 Volvo XC60 B6 Ultimate Thunder Grey on Blonde Polestar Enhanced
Previous: 2018 340 xDrive M-Sport Mineral Grey
Previous: 2016 328 xDrive Alpine White
      08-04-2021, 08:27 AM   #11
casualDIYer
Drives: 340i xDrive M Sport
In my experience with the exact same car, 225s are too narrow for the rear. I have tried a 225 for a week on x-ice3 tires and found myself breaking traction on occasion. A 235 might be the better choice for a square setup to resolve the traction issue.
      08-04-2021, 09:29 AM   #12
i128
i128's Avatar
Drives: 340iX (6MT) - X3///M40i
225/45/18 all around is the perfect size.
Im running Sottozero 2 's Runflats
Great in slush and ice, not the best in heavy powder, or deep snow.
What I like about them the most is that in "the dry" winter conditions they don't feel like the typical mushy winter rubber. - you can actually somewhat drive spiritedly.
      08-04-2021, 11:34 AM   #13
F30FanGuy
F30FanGuy
Thanks i128. I was actually looking at a set of wheels + Tires.
Wheel = 18x8.5 M5 Replica 5x120 35HS.
Tyre = 225/45 R18 SottoZero3 RFT 91H
What Im wondering is whether the 35 offset is good enough to clear the M-Sport brakes? Basically what would be the ideal wheel width and offset for running the 225/45 R18 on the 340i with the M-Sport brakes in the back and front?
      08-04-2021, 12:15 PM   #14
Th3Walrus
8.5" is a little wide and will slightly stretch a 225 tire. 8" wide is better for 225.
      08-05-2021, 07:19 PM   #15
Bongoxxx
Lol - I can break traction with any width tire in the winter
Narrower tires are better for cutting through snow, slush etc in winter driving conditions to ensure a better contact patch. It’s the main point of downsizing….
Th3Walrus340.50
      08-05-2021, 10:07 PM   #16
F30FanGuy
F30FanGuy
Thanks for the inputs everyone! Could anyone answer whether this wheel spec will clear the M-performance brakes?
      08-06-2021, 12:56 PM   #17
DrifterX
DrifterX's Avatar
Drives: 2016 340i M Sport 6MT+RWD
225/45/18 is ideal, you don't want to be driving on very wide tires in winter, especially in slush.
I run this tire size on 18x8.5 ET35 wheels
I have the M Sport brakes (same as the M Performance brakes), most 18" wheel spoke design should work but I recommend test fitting prior to installing the tires
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch
      08-08-2021, 10:52 AM   #18
F30FanGuy
F30FanGuy
Thanks for the info! Much appreciated!
      09-18-2021, 12:58 AM   #19
Rox335i
Drives: 14' 335i, 17' X6 35i
I'm running 18 inch m5 replicas right now for winters. No damage to the wheels and only problem is that they turn a bit yellow after a year or 2 of winter. That's what happens if you buy cheap wheels IMO.
      09-18-2021, 01:07 AM   #20
Rox335i
Here are the m5 reps.
