BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: LCI IHKA Climate Control Display Retrofit - IHKA3 Required
      11-14-2017, 02:50 PM   #45
HHH575
Drives: F30 M Performance
Just retrofitted everything to my 2013 F30, I have changed climate control panel and IKHA to IKHA3, all coded. Climate panel working, but always white digits.
After this retrofit I get issue - I am getting only cold wind into interior, even if I set temperature to 26C, it is still cold... Hot air start coming when I set 27-28C (maximum).
ISTA-D see footwell and ventilation temperature at passenger side +70C, I think this is reason, any ideas what is wrong? Maybe I installed wrong version of IKHA3 (I have automatic climate control with heater) - or I should see any errors in this case? Maybe I have to do any additional wiring changing IKHA to IKHA3 as mentioned gribouille1210 before ?
      01-30-2018, 07:13 AM   #46
icetuto
Drives: F20
Hello my friends, i have a bmw f20 from 2016 (it has ikha3) but i dont have the dual-zone air conditioning... is it possible to install this one on my f20
i've tried to search on f20 forums but no luck...
EDIT: btw i have this one :
      01-30-2018, 10:51 AM   #47
atzebmw
Drives: Tesla Model 3
No, that doesn't work.
More changes are necessary for that.
      01-31-2018, 08:18 AM   #48
icetuto
Drives: F20
thats what i tought... i need to have bi-zone climate controls, well bet luck next time ahahah
Thanks
      02-02-2018, 12:41 PM   #49
paul6763
England
Drives: 430d msport
hello i have a 2015 f30 the ikha 3 module is installed on esys but when i try to read code data it just comes up with a red error and wont read any ideas
      02-02-2018, 01:31 PM   #50
atzebmw
What is the error message?
      02-03-2018, 06:48 AM   #51
paul6763
England
Drives: 430d msport
hi its the following
severity 2051 error code 49184
object with name not found
ihka3 ethernet does not map to a item
thanks
      02-03-2018, 11:50 AM   #52
atzebmw
At the start of the E-sys Launcher did you choose the right car series (F030 for your car)?
And at the connection window did you choose "VehicleInfo=F020" without DIRECT?
And then "Connection via VIN"?
      02-04-2018, 05:56 AM   #53
paul6763
England
Drives: 430d msport
thanks for reply yes right car selected can get into the rest of the stuff ie kombi hdu and so on as i have been coding other stuff. ivwas wondering if itvis because i upgraded the hdu system to pro with the larger screen ??
      02-04-2018, 08:16 AM   #54
atzebmw
The psdzdata are up to date (newer than the software ot the car)?
      02-04-2018, 08:44 AM   #55
paul6763
England
Drives: 430d msport
tried it again and its went in. not sure why it wouldnt for the last few days coded it but still orange have i the right head unit ??
part no.. 6411 9320 341 01
      02-04-2018, 09:01 AM   #56
atzebmw
64119320341 is wrong.
It is the old climate control unit for cars up to 03/2014.
      02-04-2018, 11:18 AM   #57
paul6763
England
Drives: 430d msport
6411 9363546-02 is this the one i need
      02-04-2018, 11:50 AM   #58
atzebmw
Which month was your car built?
Is it a LCI?
And what's the problem with the control unit or what do you want to do?
      02-05-2018, 03:22 AM   #59
paul6763
England
Drives: 430d msport
hi was wanting the climate control to be white during the day. november 2014 build
thanks
      02-05-2018, 03:48 AM   #60
atzebmw
Yes, then the 64119363546 is right.
      02-05-2018, 06:26 AM   #61
paul6763
England
Drives: 430d msport
thanks
      02-05-2018, 09:09 PM   #62
whosagrubb
whosagrubb's Avatar
Drives: '15 F36 435i / '07 E90 328i
Hmmmm.. My F36 has a build date of 9/14, but when I look at the IHKA module in Bimmercode it shows up as "IHKA VA02". Is that just because it's Bimmercode I'm looking at and not e-sys, or is the IHKA module in the car not the IHKA3 even though it was a late 2014 build?
      03-02-2018, 05:29 PM   #63
Drimacus
Drives: 2013 F31 320d Luxury
Hi everybody, nice to meet you, I'm Enrico from Italy.
I have a 07/2012 build date 320d Luxury F31.
I bought a Automatic air cond unit code 64119363546
Only after reading this post, i saw that is necessary a IHKA3 ECU to make it work.
I have some questions to manage it:
Does it need a change of pin of connector of FEM or IHKA?
It's a simply CODE?
What is the right part number of the ECU IHKA3 i must buy to make it work?
Thanks to everyone will try to help me.
      03-10-2018, 05:57 AM   #64
Drimacus
It's definitely not possible? Please let me know.
Thank you!
      04-06-2018, 12:50 PM   #65
peter2
Drives: F20
Hi.
I retrofit white clima controller to my F21 07/2014 pre LCI (with IHKA3 factory fitted).
I VO Code IHKA3 but my CON Ecu still have Error Code :
801410 CON:no current coding data stored
801411 CON:control unit is not encoded for the vehicle
How I can VO Code CON ECU (not available in E-SYS) ??
Kind regards.
      04-07-2018, 01:54 PM   #66
IK6SPEED
Drives: BMW M3 / AH3
It's a simply CODE?
Originally Posted by peter2 View Post
Hi.
Kind regards.
From other thread
steps are:
1) Install IHKA3 Controller Unit
Known to work for mod:
64116820235
64119390099
64116842986
2) Install LCI Screen Display unit
3) Move the IHKA ECU connection from the slower KCAN Network to the higher speed KCAN2 Network by moving the 2 wires from pins 22 and 23) on FEM A173*7B to pins (10 & 11) on FEM A173*10B. There may or may not be wires already connected to pin 10 and 11 depending on if your car has HU_NBT Professional with Navigation or not. Make sure to properly connect the H to H and L to L when reconnecting and wires are not reversed.
IHKA -> KCAN_H Pin 22 to Pin 34 FEM A173*7B
IHKA -> KCAN_L Pin 23 to Pin 33 FEM A173*7B
IHKA3 -> KCAN2_H Pin 22 to Pin 10 FEM A173*10B
IHKA3 -> KCAN2_L Pin 23 to Pin 11 FEM A173*10B
4) change car build date (Zeitkriterium) up to at least a 2015 Model Year (07/14) in VO.
5) update car to latest istep level
6) Performed a "TAL-Calculating" and then a "TAL-Processing" to update the IHKA3 BTLD, SWFL and CAFD files.
7) Run Rheingold to clear all warnings and errors before starting your vehicle.
8) Start vehicle and run it until the A/C LED stops blinking.
Complete thread at http://f30.bimmerpost.com/forums/sho....php?t=1274250
