09-25-2018, 11:35 AM | #45 |
Rep 6,731
We haven't tested the rear 345mm brakes with our 17" ARC-8 just yet, but we do know that our 17x9" ET30 and 17x9.5" ET35 will clear many 355mm setups with 5mm spacers. While they may be a direct fit with no additional modifications, we'd suggest at least being prepared to run spacers (and potentially roll the fenders as a result) if attempting to fit 17s over these brakes.
--Dylan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
10-08-2018, 11:36 AM | #47 |
Rep 6,731
Nothing for 18" ARC-8 wheels at the moment. You can check out all of our current group buys at any time at: https://www.gangup.com/apex/
--Dylan
01-14-2019, 05:35 PM | #48 |
Rep 6,731
19" ARC-8 setup - our favorite F30 street fitment so far:
Front: 19x9" ET28 with 245/35-19 tires Rear: 19x9.5" ET33 with 275/30-19 tires Suspension: D2 Coilovers Owner: @ashtoncarlisle on IG
Alpine-F80200.50 |
01-23-2019, 12:36 PM | #49 |
Rep 253
Sick! Looking to do this same fitment more or less on Dinan springs so not as low, do you think this will work with 225/40 and 255/35 tires?
02-08-2019, 08:28 AM | #50 |
Rep 94
Do you know if the arc 8 17x9et30 will clear the f30 340mm with the oem 4 pot Brembos????
McQueen201474.50 |
02-08-2019, 08:57 AM | #51 |
Rep 129
Hi, I have 2 questions:
1. Is the 19x9 +38 a flat face? What's the best tire size to run for mix street/track duties? 2. Is 18x9 +30 flush or poked on a non-lowered car? What's the best tire size to run for mix street/track duties? Asking for F30 M Sport fitment. Thank you Last edited by reyoasian; 02-08-2019 at 09:03 AM.. |
02-08-2019, 02:30 PM | #52 | |||
Rep 6,731
The 18x9" ET30 is pretty aggressive on a stock suspension, and may poke unless negative camber is dialed in. If you go with this size, I recommend 255/35-18 with the appropriate negative camber dialed in, which will help with both performance and tire wear. --Dylan
Alpine-F80200.50 |
02-16-2019, 11:27 AM | #53 | |
Rep 94
Hi Apex, I got several confirmations (from people who have installed the f30 oem 340mm bakes on 17" ARC-8s) that the wheels will clear the brakes. As soon as I get them mounted I will post fitment pictures. These are the brakes I was referring to: f30 oem 4 pot brembos for the 340mm rotors |
02-27-2019, 01:47 PM | #54 |
Rep 253
Dang, wanted to order the ARC-8 19x9.5 +33 / 19x9 +28 in Hyper Silver this week but it looks like the 19x9 +28 won't be available for a couple months.
Would it be possible for me to do the 19x8.5" +20 up front? Wouldn't that be about the same fit as 19x9" +28 up front? Last edited by Alpine-F80; 02-27-2019 at 03:03 PM.. |
02-27-2019, 03:00 PM | #55 | |
Rep 6,731
--Dylan
05-28-2019, 12:58 PM | #57 | |
Rep 6,731
Front & Rear: 18x9" ET42 with 245/40-18 tires - Front spacers may be required with certain aftermarket suspensions. You can also check out our fitment guide here for other setups that will work: https://support.apexraceparts.com/hc...-Fitment-Guide Hope this helps! --Dylan
12-09-2019, 04:03 PM | #58 |
Rep 6,731
Strong, light, affordable. Choose three.
01-09-2020, 03:25 PM | #59 |
Rep 741
whats the offset?
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
01-09-2020, 05:23 PM | #60 |
Rep 6,731
Thanks for the question!
The offsets for those wheels are: Front: 19x9" ET28 Rear: 19x9.5" ET33 -Tom
01-09-2020, 05:24 PM | #61 | |
Rep 741
if i wanted a more concave look.... lower offset? assuming i went 19x9.5 all around.
01-09-2020, 06:29 PM | #62 | |
Rep 6,731
Our wheel profiles (level of concavity) are independent of the offset and depend on the design of the wheel. Oftentimes lower offset wheels are more concave, but that is not always the case and should not be applied as a general rule. When looking at wheels on our website in the specifications section you can see what profile the wheels are. In the case of ARC-8s, profile 1 is a wheel with a flat face and profile 3 is maximum concavity. The 19x9.5 ET33 is a profile 3 wheel (the most concave). In order to fit that wheel all the way around you would need to run 255/30-19 tires and front spacers. Depending on your tire choice, a rear fender roll may be required. Thanks! -Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by Expert@ApexWheels; 01-09-2020 at 06:38 PM.. |
F36GC_NYC159.50 |
04-03-2020, 04:06 PM | #63 |
Rep 466
18" Stagger Setup on F30 340ix
I reused the 18x8.5" ET38 APEX ARC-8 Front and 18x9.5" ET35 APEX ARC-8 Rear wheels I had on my E90 and now on my 340ix. Looking at the Apex Wheel site for this model it looks like that setup was good. Tires are 225x45/18 and 255x40/18. The car is not lowered and no rubbing issues thus far. My only complaint is that the rear wheels stick out about 3/8" outside the fender well in the rear. The fronts I had put on 5mm spacers to balance the look out but thinking 10mm spacers maybe better. Any thoughts on this setup?
04-03-2020, 07:14 PM | #64 | |
Rep 6,731
-Tom
04-07-2020, 08:15 AM | #65 | |
Rep 466
04-07-2020, 02:57 PM | #66 | |
Rep 6,731
-Tom
