BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Millway Camber Plates
      07-13-2020, 10:51 AM   #155
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
kern417 - thank you for your input. No measurements from before. Stock was a funky -.08 and -1.01 with stock hats.
I'm waiting on the new strut bearing and rubber boot to do a reinstall (hoping to fix that low rattle/knock) and then do an alignment.
      07-13-2020, 12:36 PM   #156
kern417
Cheapskate
4447
Yeah I found I was actually ~-2.5 after that level of adjustment. You can always get ballpark measurements using an angle, tape measure, and some math
exE36M3487.50
      08-22-2020, 02:27 AM   #157
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Checking back in. I pulled the Millway camber plates to chase down a low-speed rattle around town... I have been running the stock mounts the last month. Yes, all is quiet now but my tires are rubbing the fender wells again. Whee!
I recently did the steering rack repair and got rid of the dreaded F30 clunk! (Pretty stoked about that still. The steering feels like new.) But it got me thinking, the steering rack uses a tan, plastic block... easily 4oz of weight. The clunking noise issue with a lot of stock F30s is that block rattling around inside of the steering rack.
Some Millway owner's say there's some noise (NVH, rattle, etc.) around town... and other's who claim it's as quiet as OEM. How many of you have swapped out that steering rack piece? How many have not? And is there a noise or rattle present with the camber plate install?
Oddly when I ran the Millway Race and Poly versions, they both made a similar rattle at low speed, which makes me wonder if my rattle was actually that steering column block. I still have the Millway plates and will probably reinstall to test the idea/theory. And yes, clearly the stock rubber mount hide a multitude of noises!
      08-24-2020, 06:41 AM   #158
kern417
Cheapskate
4447
I'm not sure what noise you're referring to, but my car hasn't had any steering issues in my 2018. I'm just coming up on 16k miles though so not as high of mileage as some.
exE36M3487.50
      08-24-2020, 11:42 AM   #159
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Thanks kern417 ! 16k is pretty low. I had 65k on my steering rack so a few more miles. The steering clunk/rattles are there even without the camber plates - lot of the threads around that alone.
I should be under my car this week and will report back my findings. I'm waiting on those stupid fires out here in NorCal to calm down so I can open my garage and get the work done.
      08-24-2020, 10:48 PM   #160
andino
Drives: F31 328i xdrive
I had about 68k miles or so when I sold mine. I had some clunking from the rack but my bearings also needed replacing in my top mount. There was a significant amount of play in them.
2016 328ix F31 - SOLD!
2006 997.1 C4S
exE36M3487.50
      09-19-2020, 12:56 AM   #161
exE36M3
BMW CCA Member
exE36M3's Avatar
488
OK just checking in. I was hunting down a rattle and theorized that the clunking was from the known steering rack clunk and knock.... and thus transmitting noise through the camber plate. Well I replaced the steering rack block... still getting low speed knocks/rattling from the camber plate.
But overall, I'm still pretty happy with these camber plates. The rattle is of a frequency that you have to have the radio off, no air/fan, and windows up and doing less than 25mph around town with bad roads to even hear it. If you freeway it 90% of the time, have great roads, and use the radio/HVAC... you won't notice the rattle as much.
      09-19-2020, 02:06 AM   #162
Lancelot
France
568
Drives: 2017 m550i
Has the top strut nut been properly tightened? Most shops simply use an airgun but don't use at all the counterhold at the top which is the only way to properly torque that bolt.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      09-19-2020, 09:34 AM   #163
blumagic
blumagic's Avatar
309
Drives: 2014 328i xdrive , 2013 SHO
Check the four bolts holding the rack in place. I got a little out of all of them and it quieted mine down.
Just got my rack fix kit because mines gone too.
Also my front control arms are leaking bad. So maybe check those too, I can see where the outer edge of my drivers side one has come into contact with the subframe.
      09-19-2020, 03:12 PM   #164
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Strut nut...
I torqued it down with the proper tools
I only wish this was the rattle.
Control arm has been replaced less than 10K miles ago.
Steering rack bolts might be an idea. I'll check that next time I am under the car.
      09-19-2020, 06:07 PM   #165
MacklinUSOB
Drives: f30 328i 6MT Sport
I finally am going to be able to install the steering thrust repair kit to my car tomorrow. I'll take a look at the bolts mentioned above while I am under there. Thanks for the tip.
Edit: Repair kit DOES NOT fit earlier racks with the 17mm bolt, the top nut in the repair kit is a few mm more in diameter.
Past: E36 328is & E38 740i
exE36M3487.50
      09-20-2020, 12:22 AM   #166
Lancelot
France
568
Drives: 2017 m550i
Strut nut...
Also check antiroll bar attachment points ? Endlinks?
exE36M3487.50
      09-21-2020, 02:31 PM   #167
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Yep, sway end links and mounts are all tight. So I was doing some reading... how about this one!
"Ball joint for the front tension strut, bolted directly to the wheel carrier/steering knuckle
A loose or worn ball joint can cause a lot of strange problems including knocking noises, tire wear, and poor handling. A ball joint can wear out in numerous ways. The most common type of ball joint wear is when the ball joint itself wears in its housing and a gap develops. This causes play and can create looseness in the front suspension."
I'm at 66k miles. They say these guys last 70k to 100k. But I don't recall ANYONE replacing a ball joint. This could explain the disparity of people with properly torqued suspension components - with some with no camber rattle and some with the rattle. At $150 for a new pair, tempting to give it a try.
      09-21-2020, 02:37 PM   #168
FaRKle!
You can test this by unbolting the LCA/wishbone from the subframe, but leaving it attached to the knuckle and then trying to wiggle the arm around and see if you can get the ball joint at the knuckle end to make noise. Make sure you secure the steering wheel before you try this though or your steering can get thrown off and requiring an alignment after. This can also be done with the tension strut/thrust arm (but I know yours are newer).
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
exE36M3487.50
      10-12-2020, 01:30 PM   #169
exE36M3
BMW CCA Member
exE36M3's Avatar
488
kern417 - so I found a guy with Millways on his 435i with 86k miles. He claims zero chatter. Same set-up as my suspension with one exception, he's still on stock control arms while I am on the monoballs. Are you still on all stock suspension save the Millway camber plates?
UPDATE:
Local race shop retorqued all suspension components. Nothing loose or worn.
      10-12-2020, 01:46 PM   #170
FaRKle!
UPDATE:
I'm pretty sure kern417 has SPL control arms (that have monoballs).
exE36M3487.50
kern4174446.50
      10-12-2020, 02:09 PM   #171
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Thanks FaRKle! Clearly I am TRYING to keep these plates!
kern4174446.50
      10-12-2020, 02:42 PM   #172
kern417
Cheapskate
4447
haha yeah, i have the spl arms now and still no rattles. but it wouldn't hurt to swap and see if it goes away.
      10-12-2020, 06:54 PM   #173
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Thanks kern417! The camber plate rattle thing is such a weird monster. Trying to find a common thread has been a challenge.
      10-14-2020, 01:33 AM   #174
Happy Odie
Thailand
Drives: F30 330e M Sport
Hey guys, anyone in here uses the Millway camber plate with Ohilns R&T coilovers? I found out the the strut nut for Ohlins is 21mm which is bigger than the OEM and other coilovers at 18 mm. I couldn't find the strut nut socket that is thin enough to tight the nut down. Anyone faces the same issue? Thanks!
      10-14-2020, 03:54 AM   #175
Lancelot
France
568
Drives: 2017 m550i
I would ask millway themselves, but considering they also resell ohlins and work in proximity being both Swedish manufacturers that should be the case.
      10-26-2020, 09:56 AM   #176
blumagic
blumagic's Avatar
309
I’ve been dealing with a low speed clicking from the drivers side. I thought it was the rack bushing since I had the clunk with the car off, but it wasn’t that. Thought it might be the end links that were actually shot, wasn’t that.
Threw my phone under the car and recorded video, the bracket that holds the brake line was clicking against the bracket that holds the brake sensor in the chassis. Maybe yours was rubbing too and started a rattle.
Video:
http://https://youtu.be/ovwrIEbnTNw
FaRKle!4016.00
exE36M3487.50
