BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Msport Brakes Vs. Stock BMW Brakes
      12-22-2014, 09:31 PM   #23
fscuderia23
fscuderia23's Avatar
114
Drives: 2014 F30 335i EBII + PPK/MPE
this is probably irrelevant but it must be said… i have the m-sport brakes on mine and the brake dust that these create are insane… im cleaning my wheels every few days because otherwise my wheels look more gunmetal and less the original silver
still like others have said for $650 its well worth it
      12-23-2014, 10:55 AM   #24
R_C_S_//X3M
Launch Control Specialist
R_C_S_//X3M's Avatar
Drives: 2018 Mineral White BMW M3 CP
Can the M Sport brakes be retrofit to a car that was ordered without them? I am only seeing the Brembo performance brakes available.
      12-23-2014, 11:13 AM   #25
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
I believe it would be a straight bolt on.
I am leaning towards the M Performance upgrade which has the pretty red, yellow, orange color options! Its "only" $2K but that includes new rotors, etc.
      12-23-2014, 11:27 AM   #26
R_C_S_//X3M
Ebay has them for $1698.00
http://www.ebay.com/itm/BMW-M-Perfor...9a95cc&vxp=mtr
I am going nuts deciding between them or just painting the current ones. I painted my last set and they came out great. If I could locate the M Sport kit for a half the price of the Performance ones it would be a no brainer.
      12-23-2014, 11:41 AM   #27
tboooe
tboooe's Avatar
925
I thought the M Sport brakes are a $600 upgrade???
Thank you for the link. FYI it does not include rear rotors. The kit from ECS is $2300 but includes everything:
http://www.ecstuning.com/ES2587028/
      12-23-2014, 11:50 AM   #28
R_C_S_//X3M
My car does not have them and I can't seem to locate them aftermarket. It seems they are only available for a build from the factory. Looks to be that my only option is paint or close to 2g's.
      12-23-2014, 11:56 AM   #29
tboooe
tboooe's Avatar
925
That does not sound right. Have you talked to your dealer?
      12-23-2014, 12:00 PM   #30
R_C_S_//X3M
I have. You would think I asked him how to split a hydrogen atom.
      12-23-2014, 12:08 PM   #31
tboooe
tboooe's Avatar
925
Thats just plain dumb. I get why certain options are only available at time of order but the M Sport calipers are simple bolt on. I guess its a way for BMW to make us pay out the nose ($2300 versus $650). Bastards.
      01-04-2015, 01:09 PM   #32
Musashi
Drives: BMW 335i XDrive Laguna Seca
BMW is actually pretty honest about it. $ 650 factory update does not charge any bit of extra for on the line assembly, and only for the extra Al callipers and rotors- a MUST MUST if you care about aesthetics, looks, and NOT HAVING THEM ROTOR CAPS RUST.
$2300 is also a bargain after-market cost, considering they need 6 hrs physical labour, the whole 4 rotors ($1200) + $1000 caliber kit AND the software update. $2300 is a steal. These are sports rotors that can brake at track speed and perform nearly on par, or on par, with Ceramic discs.
What I do wish for is the 'supposedly' upcoming aftermarket Ceramic brake rotors, several manufacturers are working to engineer mass production for mainstream cars (including Brembo). The two advantages would be longevity, possibly production line holes (so no after-drilling) AND little to no dust!! I would pay 5k for such a kit lasting 500 000 kms.
      01-05-2015, 09:28 AM   #33
crono06
crono06's Avatar
Drives: 2013 335i and 2018 X3
Also keep in mind that for $650, they are just substituting the stock brake set. For $2300, you're basically paying for the entire (extra) brake set.
      01-05-2015, 11:17 AM   #34
tboooe
tboooe's Avatar
925
Fair enough...I will admit the price doesnt keep me from doing it though!!!! Yellow calipers for the win!
      01-05-2015, 11:52 AM   #35
crono06
crono06's Avatar
Tbh, the M Performance brake kit is a relative bargain. Aftermarket seem to generally be in the 3k neighborhood, but of course they come with other things such as bigger pads and upgraded lines.
      01-05-2015, 10:05 PM   #36
becausephilchow
Drives: 08 E90 M3
If you have a 335i or a 435i with the MSport Package, you already have the "M-Performance" Brakes.
The Calipers are identical, it's simply just the Rotors are Blank on the MSport, and Slotted/Dimpled on the M-Performance. Calipers are also just a painted a different color.
So yes, IF you wanted, you can simply order the M-Performance Rotors for the 435i/335i MSport Brakes, and you would essentially have an "M-Performance "Brake.
As for them on the Track, I reckon with some proper pads, stainless steel lines and good brake fluid, they should hold up relatively well. They will still fade i'm willing to bet, as they're not a true BBK ala a BREMBO GT/StopTech/AP Racing, but, it'll still be more than enough for light tracking.
Any true track enthusiast is likely going for one of the ones I listed above anyways.
      01-06-2015, 08:02 AM   #37
R_C_S_//X3M
Pretty sure the rear calipers on the M Sport package are different then the stock calipers on my M-Sport 435i GC.
I decided just to paint mine with G2. I did my 335is with the G2 and they came out fantastic. I own a metal fab shop so was able to prep them perfectly. Took all the cast marks off them then painted. Was about a 4 hour project. Ordering Estroil Blue for the calipers and still have a black kit I will use for the rotor heads.
https://www.dropbox.com/sh/s9rdn97yk...0nOm9Qcva?dl=0
      01-06-2015, 08:06 AM   #38
crono06
crono06's Avatar
I think there is some confusion here.
The "M Sport brakes" are the same as the "M Performance brakes" with the exception of the slotted/dimpled discs.
The stock brakes found on an M Sport vehicle =/= M Sport brake option.
      01-06-2015, 08:32 AM   #39
tboooe
tboooe's Avatar
925
So the $650 option for M Sport brakes is only for blue painted calipers and rotors?
It seems the 428i calipers are different than 435i ones. On my 428i Gran Coupe with M Sport option my calipers look very different from the M Performance ones:
      01-06-2015, 09:33 AM   #40
crono06
crono06's Avatar
That is correct. The M Sport brake option gives you blue calipers and I believe there are different rotors thrown in. The calipers will look exactly like the yellow ones except for the color. Both the front and rears will look like that (but the rears are 2 pots vs the front 4 pots).
If you didn't get the M Sport brake option (stock M Sport brakes), then they'll just be grey/silver calipers. They may look different, but I'm not 100% sure since I've never had a detailed look at them.
      01-06-2015, 07:59 PM   #41
becausephilchow
Drives: 08 E90 M3
Okay, lets give another quick breakdown.
335i/435i MSport has the SAME BRAKES as the M-Performance. Just painted Blue, and they have Blank Rotors. Everything else, is the same. You could simply swap on the M-Performance Discs, and you would have an MP BBK, just with Blue Calipers. These are 370MM/340MM
328i/428i/M235i/M135i MSport has the 350MM M-Sport Brakes, in Blue. It's essentially the same caliper, but the "Bridge" is different. You cannot swap on the M-Performance Discs, you need the whole upgrade to get the 370MM/340MM Combo. These from factory, I believe are 350MM/340MM.
      01-07-2015, 02:16 PM   #42
crono06
crono06's Avatar
Phil, since you're in HK, I think the packages might be different.
In Canada/USA, we have the following combos:
Stock 335/435 brakes - Plain silver/grey with no emblems or paint
Optional M Sport Brakes - These are the blue ones that you mentioned with blank rotors
M Performance Brakes - Yellow/red/orange with slotted/dimpled discs
      01-07-2015, 08:32 PM   #43
becausephilchow
Drives: 08 E90 M3
I believe that's what I mentioned no?
I also had a Stock 335i F30 before, and it had the 4-Piston 350MM Fronts, and the rears were just a normal caliper.
And yes they were Silver/Grey.
      01-08-2015, 07:55 AM   #44
crono06
crono06's Avatar
Okay, my apologies then. Must have misread somewhere along the lines lol.
