07-09-2014, 05:26 AM | #1 |
Pace Car Driver
1548
Rep 3,164
Dynamic Brake Force Display.
I don't see this discussed here on F30POST. The BMWUSA site is hard to navigate. Is this a thing for the F3# platform?
The Dynamic Brake Force Display show drivers behind you how heavily you’re braking and allow them to react in good time. This drastically reduces the danger of a rear-end collision. The brake lights themselves are divided into two zones. During normal braking, only one zone is illuminated. When heavy braking is detected, Brake Force Display increases the intensity of the brake lights by illuminating the second zone as well. In addition, the hazard lights are activated just before the vehicle comes to a standstill. The hazard lights are deactivated automatically when the vehicle accelerates or by pushing the button. ..... or must this be coded ...... Last edited by G30 B58; 07-09-2014 at 06:05 AM.. |
07-09-2014, 06:17 AM | #2 | |
Rep 808
07-09-2014, 06:57 AM | #3 |
Rep 1,252
my hazard lights are activated when i brake really hard , but not sure about the part.
"increases the intensity of the brake lights by illuminating the second zone as well. In addition"
Docrace 6266
07-09-2014, 08:57 AM | #4 |
Power Wagon Owner
Rep 9
When you brake hard, the brake lights are flickering (go on/off quickly). I noticed this once, when my rear window was very dirty and showed me the glow of the top brake light.
This is also described in the German manual (07/2013). Maybe in the US, the lights are intensified instead of flickering... |
07-09-2014, 02:49 PM | #6 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
US cars don't have it - it's against DOT regulations - along with a lot of other useful things...
07-10-2014, 12:25 PM | #7 |
Now in the dark side !
65
Rep 1,136
Like rear fog lights.
But, as mentioned, can be coded.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
07-10-2014, 03:41 PM | #8 |
Rep 1,604
09-11-2015, 06:41 PM | #11 |
BMW Fanatic
331
Rep 1,076
Yes.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
404boycaleb1.50 |
09-11-2015, 06:44 PM | #12 |
BMW Fanatic
331
Rep 1,076
FEM_Body:
ESS_AKTIVIERBARER_AUSGANG > bremslicht_blinkend
09-11-2015, 06:46 PM | #13 |
BooGooBird
17
Rep 79
09-11-2015, 06:48 PM | #14 |
BMW Fanatic
331
Rep 1,076
Are you sure? I have these settings stock as the car is Euro spec, so if it will help, I will copy paste all my ESS_ settings and post them here. Hopefully that will get it working for you
09-11-2015, 06:52 PM | #15 | |
BooGooBird
17
Rep 79
Thanks!! |
09-12-2015, 12:17 PM | #16 | |
BMW Fanatic
331
Rep 1,076
I haven't forgotten about the settings list, but E-Sys is facing some problems following my Laptop's SSD swap. Will post shortly.
09-12-2015, 12:49 PM | #17 |
BooGooBird
17
Rep 79
09-12-2015, 11:44 PM | #18 | |
Rep 100
2014 Mineral Grey 335xi ZMM, ZPP, ZCW, ZDA, ZTP.
Performance: FBO; MPE, Brembo M BBK, ER CP, ER DP, Phoenix IC, JB4, KW V2, Mechunik Front Tower Strut Brace, Michelin PS AS3+, JL Audio W6 10" HO sealed/ported box, and a bunch of other stuff you probably don't care about either. |
09-14-2015, 04:08 PM | #19 |
BMW Fanatic
331
Rep 1,076
09-14-2015, 04:25 PM | #20 |
BMW Fanatic
331
Rep 1,076
ESS_BFD_VERWENDETE_LEUCHTEN Description (Translated): Comment = Indicates how BFD is to be represented by the tail lights 0 = BFD SEPARATE LIGHTS 1 = BFD FRAZ LIGHTS 2 = BFD TAIL LAMP Set to: BFD_SEPERATE_LEUCHTEN (Values from ECU: Werte 00) ----------------------------------- ESS_AKTIVIERBARER_AUSGANG Description (Translated): Comment = Emergency Stop Signal , Appearance: 1 - BFDII - area enlargement 2 - flashing brake light Set to: bremslicht_blinkend (Values from ECU: Werte 02) ----------------------------------- ESS_ZEIT_SEIT_ABS Description (Translated): Comment = minimum time of the ABS braking ( TABS ) after the signal image ESS is enabled . [ Value x 50ms ] Set to: Wert 01, Wert 02 (Values from ECU: Werte 06) ----------------------------------- ESS_DEAKTIVIERT_BEI_NSL Description (Translated): Comment = suppress BFD ( surface enlargement ) with active function NSL . Changes to this parameter must be semantically equivalent tightened in the PRIO matrix . Set to: Nicht_aktiv (Values from ECU: Werte 00) ----------------------------------- ESS_AKTIVIERUNG_GESCHW Description (Translated): Comment = speed threshold to activate the ESS [km / h] Set to: wert_01 (Values from ECU: Werte = 32) ----------------------------------- ESS_BFD_MAX_ZEIT_US Description (Translated): Comment = Maximum time for BFD actively in country version US / CDN (tTimeOut ) [sec] / 0 : no time limit Set to: wert_01 (Values from ECU: Werte = 64) ----------------------------------- ESS_DEAKTIVIERUNG_REALE_VERZ Description (Translated): Comment = you disable the delay for ESS function (a delay AUS) : Positive values correspond to negative accelerations ; [ Value x 0.5m / s ^ 2 ] Set to: wert_01 (Values from ECU: Werte = 05) ----------------------------------- ESS_AKTIVIERUNG_REALE_VERZ Description (Translated): Comment = Delay for Enable use of ESS (a delay ) Function: Positive values correspond to negative accelerations . [ Value x 0.5m / s ^ 2 ] Set to: wert_01 (Values from ECU: Werte = 0E) ----------------------------------- ESS_VERZ_ZEIT_BL_ZU_BFDII Description (Translated): Comment = USA / CND : minimum delay time from stoplight to ESS ( t BL active ) in area enlargement . [ value x 50ms ] Set to: wert_01 (Values from ECU: Werte = 04) ----------------------------------- Hope this helps!
09-14-2015, 04:36 PM | #21 |
BMW Fanatic
331
Rep 1,076
I found some more modules, not sure if they are relevant or not, but I will post them because they have to do with lighting + brakes.
Edit: Modules posted below. AWBL_VERBAUT Description (Translated): Comment = Below this speed threshold is kept the risk value for WB_GB . ESS_ECE reset ( off ) falls below this speed threshold . From this speed threshold ( upwards ) , an active WBL is ( triggered by emergency braking ) disabled . [km / h] Set to: wert_01 (Values from ECU: Werte=0A) ----------------------------------- WB_GB_GEFAHRENWERT_MIN Description (Translated): Comment = danger value 'G' , wherein the WBL is turned on when the minimum speed is not reached. [ Value x 10 ] Set to: wert_01 (Values from ECU: Werte 00,46) ----------------------------------- WB_GB_DEAKTIVIERUNG_GESCHWINDIGKEIT Description (Translated): Comment = Speed . To turn off the WBL function (if Acceleration value can not be accepted ) [km / h] Set to: wert_01 (Values from ECU: Werte=1E) ----------------------------------- WB_GB_ENABLE Description (Translated): Comment = automatic activation WBL at GB ( ECE / US ) Set to: aktiv (Values from ECU: Werte=01) ----------------------------------- WB_GB_AKTIVIERUNG_GESCHWINDIGKEIT Description (Translated): Comment = speed threshold for activating the function warning flashing in emergency braking when ESS was previously active [km / h] Set to: wert_01 (Values from ECU: Werte=14) ----------------------------------- WB_GB_ERSATZ_BEI_ABS Description (Translated): Comment = Replacement delay in ABS - control intervention to calculate the risk value ' G' . [ Value x 0.5m / s ^ 2 ] Set to: wert_01 (Values from ECU: Werte=0A) ----------------------------------- WB_GB_LOESCHZEIT Description (Translated): Comment = time after the risk value ' G' to delete . [sec] Set to: wert_01 (Values from ECU: Werte=03) ----------------------------------- WB_GB_EXPONENT Description (Translated): Comment = exponent for warning Term ( W = a ^ exponent ) for Berechnug risk value G Set to: wert_01 (Values from ECU: Werte=03) ----------------------------------- WB_GB_BESCHLEUNIGUNG Description (Translated): Comment = min . Acceleration in the hazard warning lights flashing again is disabled . [ Value x 0.1m / s ^ 2 ] Set to: wert_01 (Values from ECU: Werte=14) ----------------------------------- Now I'm not sure which light the WBL refers to, but, it's clear that this system has something to do with BFD/Lighting/ESS. Any input would be very appreciated, as this would help expand everyone's FEM_BODY knowledge.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 Last edited by 963mw; 09-14-2015 at 04:56 PM.. |
09-16-2015, 01:06 PM | #22 | |
BooGooBird
17
Rep 79
Thanks man |
