03-13-2017, 12:48 PM | #67 | |
Rep 444
So couple the lousy cold bite with the dust levels which are beyond unreasonable and i'm finally switching from the original pads to the powerstop z23 pads. I'll swap this week or next and report back findings. I went this direction as the f80/82 guys have reported favorable pedal feel and lack of dust with the z23 pads, and they are literally the same pads as the m sport/performance on f3x models. |
03-13-2017, 04:09 PM | #68 | ||
Rep 1,067
Keep us posted, I'm curious to hear your findings. |
03-31-2017, 04:01 PM | #69 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
The rear "black" dust plate that comes in every BBK kit won't even fit an 235i/335i/435i as the axle is bigger and the plate mounting points are just simply smaller. The plate just has a larger diameter to accommodate the bigger rotors of the bbk on lower series cars than 35i etc. 35i sportline and m sport line cars already come with larger brakes and the bigger dust plates no need to change them. I indeed did not know this when I was doing it and I tried like hell to make the rear backing plate fit and it simply would not! It took me a while to realize and understand the mounting diameter on the dust plates the "black" ones mounting point is smaller than my rear axle from my 335i. Hope this all makes sense it can get confusing. And for the record for me I took about 4.5-5 hours to the entire BBK and that's using jacks, bleeding and VO coding. The 10 hour labor from a dealer is insane. It does make sense if they have to pull rear hubs. Good Luck
FBO-PS1 and stuff
03-31-2017, 04:04 PM | #70 |
Dejan
1753
Rep 4,197
OMG to VO code the HO-wort for SPBR literally takes 7-8 minutes. If they are charging you hours for this you need to back hand them!
FBO-PS1 and stuff
03-31-2017, 04:17 PM | #71 |
Dejan
1753
Rep 4,197
You have to VO code SPBR under HO-wort write it to the vehicle and then code it to the DSC module itself. Once you activate FA it should populate under HO-wort it will also confirm it in vehicle profile that you have sport brakes. Refer to the photos attached.
If you don't there will be brake pedal softness and clamping force will be different on the calipers.
FBO-PS1 and stuff
03-31-2017, 06:58 PM | #72 |
Rep 444
By the book it's still "extra effort"
03-31-2017, 07:00 PM | #73 |
Rep 444
Heads up I'm willing to put money that all "soft pedal" issues are the crap m performance pads.
I'm so far loving life one week in on the powerstop z23 pads. Cold bite is exactly what one would expect on these cars with these brakes. |
03-31-2017, 07:09 PM | #74 | ||
Dejan
1753
Rep 4,197
There was some posts a while back discussing this very thing. The original BBK for USA market had different pads (less dust) than those of regular M sport cars (more dust). When the complaints poured in BMW decided forget the brake dust complaints and changed all brake kits to the grippy dusty ones because they as a lot more bite. That combined with the coding all was cured.
FBO-PS1 and stuff
03-31-2017, 08:23 PM | #75 |
Rep 444
Agreed. In general this thread has focused on people who are paying dealers for the work so for the masses I would expect to pay a few bucks for the coding on top of the install.
Having said that, I installed myself and coded myself so I'm in your camp of 'be creative' folks! And I'm not sure the history of the m perf pads but on the kit I purchased ~dec 2015 the cold bite is non existent and the amount of dust produced is worse than a f1 car on the Montreal circuit. So glad they are now in the garbage! |
04-02-2017, 12:59 AM | #76 | |
Rep 1,986
Thanks |
04-02-2017, 10:57 AM | #77 | ||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
04-02-2017, 07:52 PM | #78 | |
Dejan
1753
Rep 4,197
As for coding I agree get creative. Coding usually goes for $100 bucks for a full session. I don't know what dealers inclusive prices are for the coding part, I'm sure it's an hourly rate. I need to see where I can buy these power stop pads...
FBO-PS1 and stuff
04-02-2017, 08:23 PM | #79 | ||
Rep 444
Jadar1752.50 |
04-03-2017, 08:14 PM | #80 | |||
Dejan
1753
Rep 4,197
Thanks for the helpful tips.
FBO-PS1 and stuff
04-10-2017, 11:25 PM | #82 | ||
Rep 1,015
04-11-2017, 08:53 PM | #83 | ||||
Rep 397
2016 BMW 328i M Sport 6MT (Mineral Grey over Coral Red)
*BPC DME Custom Stage 1 Tune *Evolution Racerwerks Competition Intercooler & Chargepipe *M Performance Big Brake Kit |
04-12-2017, 06:21 AM | #85 | |||||
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
04-12-2017, 06:25 AM | #86 | |||
Rep 10,346
I suspect some problems are due to air in the lines because the tech isn't bleeding both sides of the caliper and/or giving the caliper a little tap to get all of the air out. I have M-Sport Line brakes and the initial bite is a tad little soft, but it's definitely easier for me to be smooth with the braking.
"Drive more, worry less. "
04-12-2017, 06:26 AM | #87 | |||
Dejan
1753
Rep 4,197
In FA editor find the HO-wort folder and add SPBR. Then you should see SPBR_18_zoll_sportbrake populate under vehicle profile. Write that to vehicle. Go back to expert mode READ FA and make sure that SPBR is in HO_wort.
FBO-PS1 and stuff
04-15-2017, 08:13 AM | #88 | |
Dejan
1753
Rep 4,197
There has been a lot of info and confusion about these BBK kits and what they came with and sizes etc... The USA market was not to receive the better pads that provided the large amounts of brake dust. But later through numerous complaints about "mushy" BBK feel even after VO coding BMW made moves and decided the same pads go across the board and us Americans will stop crying about brake dust and get a better feeling brake. I entered the part number once on real oem and it lists them as a cross reference and states discontinued. Bmw later added the same pads even in the USA across the line to the famous dusty pads.
FBO-PS1 and stuff
