03-01-2019, 09:20 AM | #89 |
Rep 3,860
Well hello from your north Scandinavian neighbour
How do you measure the distances or better asked - where from? 20-23 cm make no sense as a value - too low to be from the ground, too high to be from the rim highest point...?
03-01-2019, 10:49 AM | #90 | ||
Rep 1,500
Drives: F36 435xd
Will provide a picture later. North Scandinavian neighbor as in Norway or Finland?😊
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
03-01-2019, 10:54 AM | #91 |
Rep 3,860
Still not sure how you measure, but of course it is the delta I am/was most interested in. 2,5cm is exactly what ACS advised me when I asked them.
Norway
03-02-2019, 03:22 PM | #92 |
Combined Applications Group
1056
Rep 680
340xi 6spd
H&R Supersport 28877-2 15mm front 20mm rear spacers 245/35/19-255/35/19 Kumho WINTERCRAFT WP72 Dinan Bumpstops Rear only rubs on HUGE HUGE dips
03-03-2019, 03:52 PM | #93 |
Modder of everything I own
147
Rep 491
I've been fighting issues with my right front axle since lowering my xDrive, I've been trying to determine why I blew out my inner CV joint on 3 axles in the last year. The last one was definitely due to the support bearing bracket breaking, it could be the cause of all of them failing after lowering due to my destroying my right front corner a couple of years ago, it may have been cracked since then allowing flex at the axle support bearing.
Anyway, if anybody is interested I'd like to compare the height of my car lowered to others to see where mine falls, I'm sure others are lower. If anyone lowered with an xDrive wouldn't mind, and has an opportunity, could you measure the height of the front diff from the ground and the height of the center of your front wheel hub as well. It's cold here so I have to wait a bit to measure mine until the snow melts lol. This is the thread I created for this issue if you're interested https://f30.bimmerpost.com/forums/sh....php?t=1514736
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
03-04-2019, 11:05 AM | #94 |
Rep 1,500
Drives: F36 435xd
This picture should show what I mean. Mesured by the yellow line.
Brgds
03-04-2019, 11:10 AM | #95 |
Rep 3,860
My goodness, how did you come up with that ☺️
So not even to the center of the axle? Will check mine to compare. Thanks
03-04-2019, 12:33 PM | #96 | |
Rep 1,500
Drives: F36 435xd
Top of the arch is a fixed spot. Top of the axle is a fixed spot. So delta between those points gives difference before and after. Just as good as center of axle would do.
Brgds
03-04-2019, 12:33 PM | #97 |
Rep 3,860
That's right. Just curious if the starting point is the same as well.
03-04-2019, 12:41 PM | #98 | |
Rep 1,500
Drives: F36 435xd
Otherwise it would be useless 😉
Brgds
03-04-2019, 02:44 PM | #99 |
Rep 3,860
I meant whether my starting point is the same as yours will measure
03-04-2019, 02:52 PM | #100 |
Rep 1,500
Drives: F36 435xd
Ahhh got it👍😄
Brgds
03-04-2019, 02:55 PM | #101 | |
Rep 1,500
Drives: F36 435xd
A little lower than mine. And mine should have been a little lower in the front at least....
Brgds
03-04-2019, 03:21 PM | #102 | |
Rep 3,860
Here is my front: Nowhere close to 23,5 cm....
03-04-2019, 03:24 PM | #103 | |
Rep 1,500
Drives: F36 435xd
Is currently working in Gothenburg....
Brgds
03-04-2019, 03:28 PM | #104 |
Rep 3,860
No worries no deal-breaker!
You have been extremely helpful already with your shared experience and recommendation! Just to confirm again - the car does not get unpractically low, right (speed bumps, bad roads, etc.)? Just remembering that the Xdrive is supposed to be 15mm higher than RWD if not mistaken ... meaning with the springs it is becoming about 10mm lower...
03-04-2019, 03:34 PM | #105 | |
Rep 1,500
Drives: F36 435xd
But coming from a lowered E91 on Bilstein B16 IRC coilovers, everything is a bit high.... As mentioned before it's much better looking than stock and still usable as a daily. But I am considering some coil overs when the current setup is worn out.
Brgds
Skyhigh1879.00 |
03-04-2019, 06:15 PM | #106 |
Yoda of mods
1670
Rep 3,004
Drives: X5 RWD
Dinan springs on my xi.
SteveInfante604.00 |
03-06-2019, 05:34 AM | #107 |
Rep 9
Hi all, new to the forum!
I have the F33 435d xDrive (with Adaptive Suspension) and am looking to get some Eibach Lowering Springs (25/20mm). I've been informed that the Gran Coupe (F36) shares the same springs as the Convertible (F33) - however, with the difference in weight is this really the case? |
03-08-2019, 03:04 PM | #108 |
Rep 2
Its very close to flush. Wheels are PUR FL04. https://purwheels.com/?wheels=fl-series-fl04
03-08-2019, 03:45 PM | #109 |
David
786
Rep 2,010
Just ordered some ACS, hopefully it all works out, my main concern is it being level, regarding drop height anything from 20-30mm will work for me.
03-19-2019, 12:14 PM | #110 | |
Rep 1,062
Going with Dinan springs + bumpstops and Koni Sport yellows. The Eibach with the stock dampers was too bouncy in the end. |
Operator Mo64.50 |
