04-13-2024, 07:45 AM | #1 |
Rep 1
320I Xdrive - Drivetrain
Hi All,
New joiner, so I apologise if this has been asked regularly or before. I had a ‘Drivetrain Check Soon’ error come up. A check on the Foxwell scanner revealed an implausible signal from the Turbo Coolant Pump. This is a recurrent error - it’s been in to the main dealer for a few months ago - they said it’s not a problem & cleared the code. I cleared the code using the scan tool & rescanned. No fault found. However, the car still gives the ‘Drivetrain Check Soon’ warning when shutting the engine off. Repeated scans show no errors at all. …any ideas how I clear the warning from the dash? Thanks in advance, Rob |
