04-22-2018, 07:26 PM | #1 |
Rep 3
Passenger side headlight issues
Hi guys, I have a 2014 328i, got a passenger side low beam malfunction, replaced the bulb, still not working, then it started giving me passenger side high beam, low beam and parking lamp malfunction. Then the high beam and parking lamp started working but the low beam still won't light on. I verified voltage at the connector but the light still won't work, I even tried multiple bulbs with no luck. Could this possibly be a bad headlight module? The car has regular oem halogens.
05-03-2018, 09:34 AM | #3 |
Rep 2,382
Agreed. I was going to say check for melted wiring, but it seems to be working according to you. If you have access to ISTA+, that would help out.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
05-07-2018, 06:44 PM | #4 |
Rep 1,487
Drives: 2108 X3 xDrive30i
Its not the bulb. You've got something going on further up the line. Check for any worn or split wiring. That would be my guess.
