06-07-2018, 01:10 AM | #1 |
Rep 71
EWG vs PWG - model year vs construction date
So is it model year 2014 n55s have EWGs or is it the ones constructed it 2014. My f32 was made it 2013 but is a 2014 model year
06-07-2018, 07:58 AM | #3 |
Rep 1,499
Mine is a model yr 2014 but build date of October 2013 and is EWG.
gbux20.50 |
06-07-2018, 01:46 PM | #5 |
Rep 115,980
Basically if its a 2014 model its an EWG car on the 335/435
I have seen a couple exceptions to this but the above is a good general rule.. And as noted above JULY is the transition month into the new models. (year over year change) Mike |
06-07-2018, 02:03 PM | #6 |
Rep 10,473
gbux
Apparently EU/UK does not go by the same year designation as USA (for most purposes it’s based closer to Julian Calendar and actually on plate issuance in UK. As thus, important to see where poster is located when looking at this. Also, BMW rolls out changes during the year as needed. For example, NBT and EWG were installed in F3x (with one exception) in July 2013. However, Climate Control IHKA3 was rolled in early 2014 calendar year. As noted above, there are always exception to a hard date as well (in other words early July builds might have had either depending on Factory and Supply Inventory. |
06-23-2018, 04:36 PM | #9 |
Rep 2,499
06-23-2018, 08:50 PM | #10 |
Rep 10,473
What factory was it built in and what is exact date of build out of curiosity?
06-28-2018, 03:21 PM | #11 |
Rep 190,725
Its 07/13 but we recommend a visual check for cars between 06/13 and 08/13
All F32 are EWG by the way
10-13-2018, 03:25 AM | #12 |
Rep 423
10-13-2018, 05:47 AM | #13 |
Rep 1,348
You can visually look at the turbo and check it,s wastewater setup.
This vid shows pwg car Even better pic for comparison hit the link below. Top pic ewg bottom pic pwg. EWG = Electronic wastegate setup PWG= Pneumatic wastegate setup (the long piece you see connected which is vacuum operated.) https://www.google.com/search?q=ewg+...av8x0K0q5-YQ4M
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 10-13-2018 at 05:56 AM.. |
