10-06-2018, 07:54 PM | #1 |
Rep 526
Need some advice to jack up the car
So I am taking it upon myself to perform a oil change myself on my car. I have the low profile jack, jack stands, the oil, the filter. My problem is my car is lowered on eibach springs and I have no idea of how to find out if the jack is in the center jack point in the front of the car. I cant look below and see anything. I am sorry if i am asking a stupid question but this is why i was wanting to do the oil change and other things myself on my car and learn. I just dont want to break or screw up anything and beat myself up over it. If anyone can give me some instructions, tips, advice id greatly appreciate it.
Thank you. |
10-06-2018, 08:09 PM | #3 |
Rep 526
10-06-2018, 08:39 PM | #4 |
Rep 799
If one 2x4 isn't enough, use 2 on each side. Lay one down on each side and lay a second one down on top of the first ones sitting about 6" behind the bottom one. Basically it'll look like two steps. The bottom piece would be longer than the top piece. This is the way I jack up my car.
10-06-2018, 09:44 PM | #6 |
Rep 1,827
I agree with the ramp suggestion, whether it's the RhinoRamps or homemade. If you need help locating the center jack points:
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
10-06-2018, 10:40 PM | #7 |
Rep 2,499
There are two methods I have used: (these steps assume you've already chocked the appropriate tires and the parking brake is set.
1) Jack up the rear jack point (in front of the rear tire). If you jack it up enough the front jack point (behind the front tire) will get high enough to put up onto a jack stand. Lower the car now onto the jack stand on the front point. Then, move your low profile jack to the central jack point, jack it up, and the rest is straightforward enough. See here (at the 1:00 mark): Note, when you lower the car again, remember to do it in the reverse order. If you lower the front, you'll get the jack jammed under your car. -OR- 2) Jack up the front jack point and place a few 2x8s cut into 2ft long pieces or a few bricks or pavers under the tire. Lower the front tire onto your bricks/wood then you'll have enough room on the central point to place your jack. Keep the wood/bricks under the tire even when it's not touching. It's a good backup and you won't forget to use them when you lower your car again. -OR- 3) Use the two jack method. If you can find a cheap used jack or borrow one, just jack up on side jack point, then slide your low profile jack into the central jack point. **Also, I like to use those jack pad adapaters. Aluminum ones on eBay are about $10 each. They're not necessary though. |
10-06-2018, 10:52 PM | #8 | |
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP |
eluded3035.00 |
10-07-2018, 02:07 AM | #9 |
2JZ-GTE
3035
Rep 3,992
Use some 2x4s as others noted.
10-07-2018, 08:01 AM | #10 |
Rep 16,081
And really fast. Thirty seconds and you're ready to go. When I need to have more clearance in the rear I still use the ramps to get the front up first, then jack the back using the rear jack positions.
10-07-2018, 01:37 PM | #11 |
Rep 12
These are the goods for a low vehicle. I use a Harbor Freight low profile jack and it gets wheels off the ground with the frame supported 12". Larger floor jacks may not fit.
Makes jack placement a breeze, compared with your normal jack stand. Well worth the price for me. http://www.jackpointjackstands.com/
GREY GHOST oooo 2019 440i Coupe o Mineral Grey Metallic o ///M Sport Design o Track Handling Package o Executive Package o Black Kidney Grilles o Digital Instrument Cluster.
Black Dakota Leather with Blue Stitching o Aluminum Dark Carbon with Pearl Gloss Chrome highlight o 18" V-spoke Orbit Grey 398 wheels with Michelin PSS tires. |
10-07-2018, 01:45 PM | #12 |
Rep 2,653
Rhino ramps worked perfect for me. I was weary about them but after using them for my Jeep Grand Cherokee a few times I'm a fan.
10-07-2018, 01:54 PM | #13 |
Rep 5,776
Just to add to that, I was never really a ramp guy until I got this car and realized that for oil changes and DP change they are great and safe. Still use a jack to take wheels off.
jh_f301307.00 |
10-07-2018, 02:28 PM | #14 | |
Rep 1,827
Absolutely worth the $40 investment in RhinoRamps. More than enough clearance for oil changes, even on a lowered car. I also use them to lift the car up high enough to fit my jack if I do need to take the wheels off for whatever reason. Roll up the ramps, jack the car up off the ramps while keeping them in place, then when I'm done, lower the car back onto the ramps, clear out the jack and roll off the ramps.
10-07-2018, 08:40 PM | #15 |
Rep 526
I appreciate the advice guys, would these ramps be enough clearance?
https://www.harborfreight.com/13000-...set-63956.html 6-1/2 Ton Capacity (6500lbs per ramp) Extruded traction grooves 35-1/2 in. L x 12 in. W x 8-1/2 in. H 6 in. max lift height 17 degree ramp angle Integrated rubber stops to prevent ramp slip. Would this be enough to clear my lowered car? Reaoson im asking if these specific ones are ok is because i have a gift card to this store and would rather use that if needed than to spend cash. |
10-07-2018, 09:47 PM | #16 | |
Rep 257
2021 i3s AC Schnitzer BMW CCA #67486 |
10-07-2018, 09:55 PM | #17 | |
Rep 1,827
10-07-2018, 10:00 PM | #18 |
Rep 526
10-07-2018, 10:16 PM | #19 |
Rep 5,776
Yeah, you will have to use boards. My car is not lowered and is an M-sport but without boards it hits the ground hard. I think the boards I use are about 2 inches thick, nearly as wide as the ramp and about 2 feet long.
