10-11-2018, 10:27 AM | #1 |
Rep 2,318
Post your reaction when you found out you bought a PWG F30
I brought the car home and started looking up downpipes and JB4. That's when I learned I was plagued with a PWG car.
10-11-2018, 05:35 PM | #3 |
Rep 279
Hmm....I was happy to find out I could run more e85.
....makes up for the slightly smaller downpipe.
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
the dope steez403.00 |
10-11-2018, 06:30 PM | #4 |
Rep 1,827
Do research pre-purchase? For me, "meh..." I'd rather be happy with what I've got while I've got it. Not worth worrying about because it doesn't diminish my enjoyment of the car.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
Pittcrew34.00 Dheeth-G80225.50 |
10-11-2018, 06:30 PM | #5 |
Rep 808
10-11-2018, 06:39 PM | #6 |
Rep 2,357
What is the problem with your PWG car?
(A Dane in China) |
10-11-2018, 07:22 PM | #7 |
Rep 1,693
10-11-2018, 07:24 PM | #8 |
Rep 1,693
ALL the info that was available at the time said it should be EWG. It's near-impossible to see down there on the spot with the seller to physically check and I though I had no reason to check as RealOEM seemed to indicate 7/2013 onwards was EWG. RealOEM doesn't even list the PWG turbo for my car at all but it is PWG!
10-11-2018, 07:58 PM | #9 | |
Rep 10,473
Even in my classified for my sold Pure Turbo from July I listed that it was compatible with a 2014 535i. https://f30.bimmerpost.com/forums/sh....php?t=1519951 |
10-11-2018, 08:09 PM | #10 | |
Rep 1,693
10-11-2018, 10:06 PM | #11 | |
Rep 10,473
Obviously the correct info was available as I listed it in an ad on this site in July. |
10-11-2018, 10:35 PM | #12 |
Rep 2,499
I thought I had it bad because I had the old TPMS. It's annoying buying wheels on the forums since most people have the newer TPMS.
To be honest, I doubt there's really a huge difference. Unless you're taking the car to a drag strip, it's nice to just have a good boost in power which you get with both PWG and EWG cars. My past car had an N54 and with a tune it felt like a beast. |
10-11-2018, 11:25 PM | #13 |
Rep 1,934
Theres nothing wrong with the pwg. You feel it's bad because you sere thay ewg is revered as "better" just because it has a revised part and can hold a bit more power.
Just tune it. You will be fine.
10-11-2018, 11:27 PM | #14 |
Rep 2,318
/thread
10-12-2018, 06:33 AM | #16 |
Rep 2,318
I've done everything besides upgrade the turbo. PWG turbo falls on its face after 5.5k RPM and there's nothing you can do about it unless you replace it
10-12-2018, 07:18 AM | #17 | |
Rep 1,827
If so, maybe the N55 platform wasn't the right place to start to begin with?
10-12-2018, 07:29 AM | #18 | |
Rep 2,318
EWG makes about 70whp more than PWG from 5.5-7k rpm which is huge |
10-12-2018, 07:31 AM | #19 |
Rep 1,827
Ah. Gotcha. Well, PS2, it is!
10-12-2018, 11:35 AM | #20 |
Rep 470
I'm not sure what OP is on about. I have PWG in my X3 and if I ever need to make more power up top, I'd just go PS2 and be done with it.
The N55 with PWG is a very well balanced engine. If you wanted power headroom you should have gone with an N54 due to the forged internals & dual turbo setup. I'm going to have a hard time justifying that much power though. 400 whp on an X3 is wicked fast and plenty to have fun with on public roads, as well as on the track. |
harkes1077.00 |
10-12-2018, 11:45 AM | #21 | ||
Rep 529
Weren't you the one that posted the dyno comparison of what I assume is ewg vs pwg and it showed a 20whp difference?
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
10-12-2018, 12:33 PM | #22 | |
Rep 2,318
Granted he EWG is on BM3 and PWG is on jb4, the torque/hp curve should paint you a clear picture EWG: PWG: EWG from peak hp at 5.5k rpm (413whp) to 7k (~380whp) = 33whp drop from the peak PWG from peak hp at 5250 RPM (397whp) to 7k (~320whp) = 77whp drop EWG from peak tq at ~3250 RPM (448wtq) to 5250 RPM (~410wtq) = 38wtq drop PWG from peak tq at ~3k RPM (471wtq) to 5250 RPM (~400wtq) = 71wtq drop PWG is all downhill after 5.5k RPM while EWG is strong all the way through the pull |
