05-07-2020, 01:42 PM | #1 |
Rep 504
World’s 1st True “Plug & Play” High-Performance N55 Engine Oil Cooler from CSF
Like other components of cooling systems, upgrades to oil cooling systems are often overlooked. Overheated oil struggles to lubricate the engine properly – harming internals over time. On any car making significantly more power than factory, or any car tracked or driven hard; upgraded oil coolers are essential for maintaining optimal temperatures – in turn, lengthening oil and engine life.
Considering their expertise and success from other BMW cooling systems, CSF created yet another upgraded oil cooling system. With optimum oil temperatures maintained, drivers can dominate the track without the dreaded “cool down” or “limp mode” breaks. Utilizing CSF’s AC Condenser technology, this innovative dual-core in-series system features an additional 5 rows of super-high pressure multi-channel micro-tubes on the rear side of the oil cooler. The high performance tube spec, along with the high-efficiency multi-louvered fin design allows for maximum surface area contact and ~40% increase in heat rejection. The High-Performance Race-Spec Oil Cooler directly replaces the factory unit, easily bringing engine oil temperatures down to a consistent and manageable level, even under extreme & extensive driving conditions. Features: • Innovative 2-Core In-Series System • Front Core Features 14 Rows, Secondary In-Series Backside Cooler Has an Additional 5 Rows of Cooling for ~40% Increase in Heat Rejection • Converted to a Single-Pass Design with High-Pressure Return Line for Optimal Flow • Made With CSF’s AC Condenser Technology Using a 1-Row Super High-Pressure 26mm Multi-Channel Microtube • High Density, Multi-Louvered Fin Design for Maximum Surface Area Contact • “Drop-in Fit” Requires No Modifications to Install • Accepts All Attaching OEM Components Including Oil Line Connections, Mounting Brackets, and Shroud/Ducting • World’s First and Only True “Plug-and-Play” Upgraded Engine Oil Cooler for the BMW N55 Engine • Requires an Additional 1/2 Quart for Proper Fill-Up During Installation (OEM Cooler 7 Qts./CSF’s Upgraded Race-Spec Oil Cooler ~7.5 Qts.) • Part Number CSF#8145 See More @: https://csfrace.com/csfs-track-ready...-for-bmws-n55/ Watch//Learn More: Track Tested on Hittman Racing's M235i Endurance Race Car Last edited by CSF Cooling; 05-13-2020 at 11:34 AM.. |
05-08-2020, 10:56 AM | #2 |
No 55mph
1621
Rep 8,476
Nice
What vendors are currently handling these?
05-09-2020, 08:05 PM | #3 |
Rep 288
Definitely interested in keeping oil temps low. Especially notice after awhile of pull after pull the oil temp just sits at 250, which is obviously completely normal but I'm all for cooler oil. Thanks for the share!
05-10-2020, 07:21 PM | #5 | |
Rep 1,827
By adding more cooling, you run the "risk" of making your car take longer to warm up to operating temps, which could in turn cause more wear during startups and driving while cold. If your temps start to push up into the 260 range regularly, then I think oil cooling efforts would be worth it. For me personally, I don't track my car, so $500 is a lot to solve something that I don't really see as a problem. YMMV
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
ronanz1819.50 |
05-10-2020, 07:30 PM | #6 | ||
Rep 785
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
05-10-2020, 08:11 PM | #7 | |
Rep 288
1QuikWS61620.50 |
05-11-2020, 12:16 AM | #8 | |
Rep 7,602
05-11-2020, 12:34 AM | #9 |
Rep 2,357
Oil temps are easily lowered in the MHD app - I believe BM3 also has this feature. Only if you see them creeping higher than set target do you need this cooler.
(A Dane in China) Last edited by harkes; 05-11-2020 at 12:42 AM.. |
05-11-2020, 11:07 AM | #10 |
Rep 190,750
Nice
05-11-2020, 09:08 PM | #11 | |
Rep 504
In many racing environments, racers can very rarely get a clean lap with their best time on their 1st or 2nd lap. With this oil cooler installed, racers can focus on staying on track and bringing lap times down with rhythm. |
06-03-2020, 12:49 PM | #13 |
Rep 19
How would this affect us drivers that don't have hotter weather year round? Here in Chicago-land. We will have defiant lower temp then southern states. The little bit (.5 qt) of extra oil wouldn't be bad tho. I do wonder about the potential longer operating temps. Mainly in the winter. I mean I have gone in winter my temps haven't even hit 250 on 20 min drive.
06-03-2020, 01:14 PM | #14 | |
Rep 7,602
06-03-2020, 01:18 PM | #15 |
Rep 19
06-03-2020, 01:26 PM | #16 |
Rep 7,602
Well if you are running stock oil T-stat then theoretically it shouldnt have have a major impact since the T-stat would not be circulating the oil through the cooler until it is up to temp. But once the T-stat starts to open the increased cooling and increase in capacity would prevent the temps from increasing at the rate they would with the stock oil cooler.
06-04-2020, 11:55 AM | #17 | |
Rep 19
06-04-2020, 12:31 PM | #18 | |
Rep 7,602
There's reason no reason to change the oil cooling system unless you are pushing the car to the point where the stock system is inadequate. Running a lower T-stat can have unintended consequences, such as slower warm up to operating temp and preventing the oil from reaching at least 212F to burn off moisture. |
ozymandias435142.50 warcraftjs3.00 |
06-04-2020, 12:52 PM | #19 | |
No 55mph
1621
Rep 8,476
I use the Mosselmann Oil Thermostat - it is hi quality part, worx as a TRUE thermostat same as factory system, but allows for earlier direction to oil cooler than stock. Thermostat is variable & constantly correcting. Mosselmann does not affect stock warm up to operating temp other than releases oil to cooler at a slightly lower temp than stock - oil temps reach at least proper temps to burn off moisture, but are lower than upper end with factory & keeps the temp stable regardless of how much you are beating on the car The other option is the BMS style spool valve - but that does not really control as a thermostat, it simply locks the flow of oil to the cooler at full flow ALL the time If you live in an area where there is winter with cold temps you would NOT want to use the BMS spool valve. This would result in your oil going directly to the cooler from initial start, in outside temps that may be in the teens, or below That is waaaaay too early to have the oil go to the cooler after setting in very cold temps without a chance for the oil to warm up
warcraftjs3.00 |
08-03-2020, 03:10 PM | #20 |
Rep 504
This month, CSF is giving away a complete N55 Cooling Package – Including this oil cooler (for the F chassis) + multiple other products!
You can enter the giveaway on our website + social media: • https://csfrace.com/csf-summer-takeo...veaway-august/ • Instagram @csf_radiators • Facebook /CSFradiators Learn more about the giveaway and enter at: https://csfrace.com/csf-summer-takeo...veaway-august/ Learn more about our N55 products at: https://csfrace.com/bmw-n55-cooling/ |
csf cooling, csf radiators, engine oil cooler, oil cooler, oil cooling, temperatures |
