04-12-2021, 11:38 AM | #23 |
Rep 3,873
10-15% louder in Comfort, 70% louder in sport it basically becomes a straight pipe exhaust in Sport, with no mufflers or resonators on the way. Only the Downpipe and cat still suppressing some of the sound/noise.
But believe me - it is more sound than noise! It's fantastic. And the tune adds burbles and gunshots (in Sport). But you can also continue driving in Comfort with negligible impact on the comfort level, which is brilliant.
04-12-2021, 11:42 AM | #24 | |
Rep 1,641
04-12-2021, 11:43 AM | #25 | |
Rep 1,641
04-12-2021, 11:52 AM | #26 | |
Rep 709
04-12-2021, 12:02 PM | #28 |
Rep 3,873
There is a slightly more pronounced drone in Comfort around 2000 rpm. Same in Sport, but the sound there is "all over the place" and you don't really stay around 2000 rpm too often
Th3Walrus340.50 |
04-12-2021, 12:15 PM | #29 | |
Rep 1,560
My exhaust is not much louder than the stock exhaust and defiantly does not have any gunshots pops. It can have a burble under deceleration, but it isn't loud. It is louder on cold starts, but gets quieter in about 30 seconds. Is it possible that the cars you have heard have had other exhaust modifications. If you want loud, you should hear my Camaro!
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
04-12-2021, 12:50 PM | #30 |
Rep 7,602
I saw my name in here so ill just throw in my 2c here for OP.
1. The OTS maps from MHD and BM3 are totally fine, and you are not going to compromise reliability of an otherwise mechanically sound car, especially from a stage 1 map. But, if you are going to lose sleep over it or constantly be worried about it if you flash tune, then maybe this isnt the path for you, because your overall enjoyment of driving the car will be reduced even if you gained HP/TQ. 2. A simple piggyback like a JB+ may be a viable option for someone in your situation. It's a bit of an archaic way to increase HP is the world of flash tunes but its simple and it does work. Drivability will likely not be nearly as good as a flash (nor will overall power increase). Typically not the path i would recommend but might be something worth trying to see if you like it since it has a low price point and can be resold. 3. You need better tires. I had the S001 RFT and i would spin 2nd gear from a roll once tuned/FBO (N55). I got PS4S and i can hook 1st gear from a slow roll and nearly dead hook 1st from a dig. And LSD will of course help as well, and provide better traction/handling in other situations (i.e., cornering). |
04-12-2021, 01:10 PM | #31 |
Rep 139
Sounds like MPPSK is perfect for you. The engine tune gives you 20hp and 39lb/ft. The exhaust is a high quality variable valved system that closes in Comfort unless going at high speed, and opens in Sport/Sport+ and sounds GREAT. The sound is in my opinion loud but very reasonable with the valves open. If you're feeling mischievous, you just let off the throttle at 4k+ or downshift to 3rd or 2nd and you will have gunshots. Sometimes isolated loud pops or full on AK-47 depending on when you do it. Its plenty fun and I believe it'll increase your car's value because this system is from BMW.
