04-02-2017, 06:43 AM | #46 | |
Rep 3,958
http://www.zf.com/usa_canada/en_us/s...ome_sachs.html |
04-02-2017, 07:55 AM | #47 |
Rep 1,296
My source was this post: http://f30.bimmerpost.com/forums/sho....php?t=1295921
04-02-2017, 10:04 AM | #48 | |||
Rep 3,958
04-03-2017, 03:35 PM | #53 |
Rep 3,958
I don't mind the M Performance Suspension kit not lowering the car by that much. Extreme drops come at the expensive of drivability and performance. This is probably why BMW, Ohlins, and AST recommend only a 10mm drop beyond the 704 Sport suspension.
04-03-2017, 06:49 PM | #54 | |
Mr. Discombobulator
160
Rep 162
Yes, it's the optimum rate of drop for this vehicle. Firmed up, yes. Still relatively smooth in most cases. Once I switch from the run-flats that'll make it a little smoother.
'14 MSport 335i | Melbourne Red | MPE | MPBBK | MPS | MPLSD | xHP Stage 3 | MHD Stage 2
04-04-2017, 03:19 PM | #55 | |
Rep 3,958
I also ordered these additional items: Partnumber: 83420428190 BOX-SECTION WAX SPRA Partnumber: 31106856004 FOAM SEAL The foam seal showed up here: http://www.realoem.com/bmw/enUS/show...diagId=03_3994 But not in the ETK breakdown of the M Performance Suspension kit. |
04-19-2017, 01:00 PM | #57 |
Rep 1,296
Just read the M2 M performance suspension is made by KW.
http://blog.**********s.com/quick-sn...tails-modauto/ EDIT: link's blocked but that was on Mod Bargain's blog today. Wondering if the 3 series is from them too, would make sense. Anyway, i'm very happy with my KW DDC set now that i've softened by anti roll bars
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 04-19-2017 at 01:07 PM.. |
05-02-2017, 09:42 PM | #58 |
Rep 3,958
Pictures of BMW M Performance Suspension Kit
05-03-2017, 05:54 AM | #59 |
Rep 1,296
Not sure why but this looks my bilstein-ish than KW-ish
As a comparison, the M4 GTS definitely look like (and are) KWs without the branding.
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
05-03-2017, 09:04 AM | #60 | |
Rep 258
Drives: F30 320i (328i ECU) M-Sport
M4 GTS are original KWs.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler F32 bottom V-bar F80 bottom reinforcement plate Koni Sport, M-Performance springs, M135i Anti-roll bars |
05-16-2017, 09:41 PM | #62 |
Rep 54
Also live in Houston and curious as well.
One question, total newbie when it comes to springs/suspensions, how come this one (link below) is so much more cheaper than getbmwparts....$380 vs $1500 https://www.bmwpartspros.com/partloc...catalogid=8798 Also BMW website has it at $980, I know both BMW website and bmwpartspro doesnt include spring in price, but cant be that much different |
05-17-2017, 02:26 PM | #63 | |
Mr. Discombobulator
160
Rep 162
"hardware not included." That price they have listed is close to what the springs themselves cost, nothing else.
Polo088161616.00 |
05-18-2017, 08:14 AM | #64 |
Rep 54
06-25-2017, 06:48 AM | #65 | ||
Rep 3,958
I attempted to install my M Performance Suspension yesterday but experienced a fail along the way so I'll be attempting it again in approximately 2 weeks. The short story is that I applied the wrong torque setting to the hex bolts that fasten the front top hat to the strut tower. My car originally came with M10 (steel) bolts that are spec'd to 41 ft. lbs. + 90 degrees. The M Performance Suspension kit comes with the weaker M8 (aluminum) bolts that are spec'd to 21 ft. lbs. + 90 degrees. The M8 bolts sheared off inside the top mount and I had to spend an extra hour or two dissembling the front spring/strut assembling and extracting the partial bolt.
Regardless, here's a few items that you may want to order since the M Performance Suspension kit doesn't have or doesn't have enough of if your install doesn't go perfect: - Strut bar to strut tower Torx bolt - Extra M8/M10 top-hat (guide support) to strut tower bolts - Sway bar to strut nut - Steering knucke bolt + nut - M12 self-locking collar nut (if you somehow need to disassemble the front spring strut assembly, you'll need a new nut and these are also used in the rear to secure bottom of strut to control arm) - Hex screw + self locking collar nut (secures rear control arms to wheel carrier) Quote:
