04-28-2021, 03:47 PM | #353 | |
Rep 2,047
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
04-29-2021, 02:43 AM | #354 |
Rep 749
Drives: F31 320d xDrive M Sport
You can modify the shift points
04-29-2021, 05:05 AM | #355 |
Rep 2,047
Are they static or dynamic - as in adapting to your driving style?
04-29-2021, 07:15 AM | #356 |
Rep 8,502
I think of it as three modes of operation for the shift maps :
Gentle driving - XHP has pre-defined shift points (up/down) for each ratio. Dynamic - the shift point for each ratio will increase if the car is being driven with a heavier right foot. WOT - the shift point is at, or close to, the rev limiter Shift points can be adjusted manually by way of a % adjustment for gentle and dynamic driving, and a WOT shift point can be set for each transmission mode (Drive / Sport / Sport+ / Manual). For example with my 330d I have different WOT shift points for D (4000), S/S+ (4300), and M (4500). There's no point having a shift point >4250 on my car, because peak power occurs at that rpm, but a 4500 shift point in manual mode gives a bit of tolerance when the car is on track in M mode.
M_Postr37.50 |
04-29-2021, 08:09 AM | #357 | |
Rep 2,047
04-29-2021, 10:26 AM | #359 |
Rep 2,047
It's 3000 in D but higher in S. Just surprised me as I'm used to much higher revving in D with sport+
04-29-2021, 12:32 PM | #360 | |
Rep 865
I think with XHP sport+/D is sort of dynamic. If on a light throttle mine will go into the highest possible gear like comfort, but will change down much sooner than comfort and hold lower gears if it sees that you are using more throttle input and harder braking, keeping the revs high if you are using full throttle. As soon as you go back to pootling it will go into highest gear again. This is more obvious on a petrol with wider rev range than diesel. I don't really use sport+/D, it's comfort or sport+/S dsc off for me. But I think you want the sport+ pops and crackles around town don't you! |
04-29-2021, 01:32 PM | #361 | |
Rep 2,047
06-03-2021, 10:04 PM | #362 | |
Rep 381
10-22-2022, 09:19 AM | #363 |
Rep 45
Has anyone flashed their car from an iPhone using an rj45 adapter? I'm looking into this adapter https://www.ebay.co.uk/itm/353614323...#38;media=COPY at the mo and just wondered if anyone has flashed their vehicles with one?
Were there any issues doing this with an iPhone over a laptop? |
10-22-2022, 09:47 AM | #364 | |
Rep 2,128
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
Bean8013.00 |
10-22-2022, 03:44 PM | #366 |
Rep 8,502
My advice is to just buy the Thor dongle. I've never had any problems with mine and I've flashed the transmission several times.
