BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Air pipe rattle
      05-16-2024, 10:41 AM   #23
Billzorrr
Drives: E46 330cd F33 430D
Got the same issue on my F33 430D.
Upon investigation, there appears to be a a little clip/Holder underneath the bonnet catch that the air intake pipe is suspended from. After looking at mine and noticing it wobbles and vibrates like crazy, i had a look through some drawings of the intake and it appears there is meant to be a little rubber gromit or such inserted into this holder which lifts the pipe into the correct position and stops the rattle.
The bushing is £2 from bmw. £10 on ebay. I'm yet to install and see if this does solve the problem but Im sure it will. Just involves removing the crash bars and bonnet latches to be able to pull apart the intake and push the bush in the holder.
      05-16-2024, 11:05 AM   #24
TurboWeasel
Drives: BMW 330D
Pop up a picture of where you mean when you get a chance, but good info.
That rattling stopped on mine after wrapping some felt around the portion of ducting that attaches to the grille. The factory felt rubs off over time.
      05-18-2024, 03:59 AM   #25
mapyn
Drives: f30 330d saloon
Billzorr can you share a link to the ebay part. I know which bit you v mean but don't know what to call it
      07-04-2024, 09:03 AM   #26
Mazt
Drives: 430d
Hi could you show me the part as I can’t find it.
Cheers
      07-05-2024, 03:08 AM   #27
Mazt
Drives: 430d
Please ☺️
      07-05-2024, 04:04 AM   #28
TurboWeasel
Drives: BMW 330D
He probably means parts 14 or 16 on this diagram.
https://www.realoem.com/bmw/enUS/sho...diagId=13_1489
Mazt0.00
      07-10-2024, 02:55 PM   #29
Mazt
Drives: 430d
Yeah think your right but that won’t solve it
      07-13-2024, 09:06 AM   #30
mapyn
I reckon he's referring to these,
https://www.ebay.co.uk/itm/364639168...edia=WHATS_APP
      07-13-2024, 12:03 PM   #31
Mazt
Drives: 430d
Going to try this
      11-24-2024, 01:16 PM   #32
David-AC
Spain
Drives: 430d F36
Originally Posted by Mazt View Post
Going to try this
Hello Mazt.
Have you achieved solve the problem? How have you done it?
430d F36 LCI & Z3 Roadster
      11-24-2024, 04:32 PM   #33
sl13
Drives: 335d xdrive Msport
I had the same thing, I just jammed a twig in-between the outer and inner pipes. Works a treat!
