BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Car won't read my engine oil level!
      06-08-2015, 04:19 PM   #1
BimmerF32_430i
BimmerF32_430i's Avatar
311
Drives: 2012 335i
I'm at operating temperature (nearly 240 or so) on a level surface, and car is in park with handbrake on. No matter how many times I try my car refuses! It'll stop around 16%, and then get my hopes up and get all the way to 76% and stop again. Last time it literally took me half an hour just to get the reading. I turned the car off and back on and tried it and it worked last time. Tried it again today and it didn't work. It's just frustrating and It makes me wish we still had a dipstick reading method sometimes.
Is there something I'm doing wrong??
      06-08-2015, 05:48 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Dealer.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      06-08-2015, 07:18 PM   #3
carzaddict
Drives: 2015 Cadillac Escalade ESV
i dont think it'll be possible to diagnose...just go to the dealer
2015i Cadillac Escalade ESV
      06-09-2015, 02:27 PM   #4
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
That happened to me once, it was because my engine was too hot (Also at operating temperature ~120C) . Left the engine bay open for 5 minutes with the weather slightly windy. After that started car (Temperature slightly dropped), and was able to read oil level.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      10-12-2015, 08:02 AM   #5
lokito
lokito's Avatar
Puerto Rico
Drives: 335i ///M Sport
So I have been running the same issue lately. But have got no luck on getting the process running past 17%. I tried around 5-6 times. It kept saying to put the car at a leveled ground and pointing North, which I did. When I took it to the dealer, they stated it was normal, which I don't believe it is. Did you take your car to the dealer? Did they diagnose the problem and got it fixed?
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      10-12-2015, 11:45 AM   #6
BimmerF32_430i
311
Drives: 2012 335i
No it just resolved on its own. There was one point where I tried for an hour or so to get a reading and failed. Turned the car off and back on and tried again and it worked. If it keeps acting weird try that
      10-12-2015, 12:29 PM   #7
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
It happens to me on Summer days. It's the excessive temperature from the weather conditions. My solution was to park in the shade, open engine cover and let it cool down for 5 minutes then run it again. Lemme know if that works, this could be the reason given you're in Texas.
      10-12-2015, 06:20 PM   #8
lokito
lokito's Avatar
Puerto Rico
I'll give it a try in the morning after the car warms up. Hopefully that's the issue.
      11-04-2015, 04:47 PM   #9
robbnc
Drives: 2006 BMW 325I sedan
This happened to me once. After disconnecting the battery and re connecting it the problem never came back.
      11-18-2015, 10:06 AM   #10
DiceK
Drives: 320i
My car is at the dealer for this issue right now.
Rabbits chewed through 3" of the wiring harness. They also got my ambient temperature sensor.
      11-18-2015, 10:28 AM   #11
Polo08816
Drives: 2014 335i M Sport
Did you coat your engine bay with carrot juice?
      11-18-2015, 10:42 AM   #12
DiceK
Drives: 320i
Haha, nope, but I have to say this is the first car where I've had this problem.... Not a cheap one either, looks like the oil level sensor shorted out and died.
      11-16-2024, 08:08 PM   #13
JamesBMW123
JamesBMW123's Avatar
Drives: 2014 bmw 335i xdrive
This is happening to me and I was quoted an oil pump replacement as the fix. Did you ever find a solution?
      08-08-2025, 04:55 PM   #14
tluckey001
Drives: 2014 BMW 328i
Oil level not reading after oil change
Lots of reading on how to fix the problem. Same as many others. Oil level measurement only gets to 17%. One post stated only started after an oil change. Same as me, so I took a look at the oil filter and made sure the cap was tight. It could have been a bit tighter. Making sure the cap was on tight fixed the problem. Lots easier than replacing temp & presure sensors or the thermostat.
