11-17-2015, 10:19 AM | #1 |
Rep 1,129
Drives: '16 340i AW MSport
20" Wheel / Tire OEM Fitment Question
So I'm going to get some 20's they are:
20x9 et 35 20x10.5 et 45 What tires would be the absolute closest to OEM? My guess is: 235/30 in the front 275/30 in the rear or should I go 285/30 in the rear? Thanks |
11-17-2015, 01:20 PM | #2 |
Rep 5,140
235/35-20 and 275/30-20 has almost identical diameters, both about 1% taller than OEM size.
235/35 and 275/30 will look a bit stretched on 9" and 10.5" wide wheels though. |
11-17-2015, 02:03 PM | #3 |
Rep 1,129
11-17-2015, 02:10 PM | #4 | |
Rep 5,140
But I dont think you should go wider than 275 on the rear wheels to avoid rubbing. You might consider 245/30-20 and 285/25-20, 1% shorter than OEM size. But you need to confirm that rear fitment since it's a very aggressive setup. The 235/35 and 275/30 combo is probably your best option after all. |
11-19-2015, 10:29 AM | #5 |
Rep 1,557
I run 245/35 with 275/30 without issues. You can run 285/25 or 295/25, but will depend on how low you want to go and the tire is getting pretty thin for my tastes and wheel protection.
I think once the fronts need replacing I will look at possibly a 245/30. Get a little lower profile since I like to tuck a little more up front. Picture included so you can see the profile. |
11-24-2015, 05:39 PM | #6 |
Rep 25,980
Maybe consider 245/35 and 285/30, especially if your car is equipped with xDrive.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
11-24-2015, 11:03 PM | #7 |
OCXG30
42
Rep 77
Drives: BMW 540i M sport
275 will rub on dips and if your hauling people expect rubbage
11-28-2015, 11:21 PM | #8 | |
Rep 49
245/35/20 20x8.5 33mm offset 275/30/20 20x9 44mm offset With no problems Last edited by Usmc1028; 11-28-2015 at 11:23 PM.. Reason: Pic didn't post. |
11-29-2015, 05:23 PM | #9 |
Rep 1,129
12-02-2015, 05:01 PM | #10 | ||
Rep 1,657
12-07-2015, 12:41 AM | #12 |
Rep 49
Style #36116853816 245/35/20 20x8.5 33mm offset Style #36116853817 275/30/20 20x9 44mm offset Black Chrome off of a F10, and Stock Sport Suspension. Last edited by Usmc1028; 12-07-2015 at 12:43 AM.. Reason: Added words. |
12-07-2015, 12:44 AM | #14 |
Rep 49
12-07-2015, 01:46 AM | #15 | |
Rep 5,140
Your wheels are style 356. The 11-digit numbers you provide are BMWs part numbers, which is good to know when you order the wheels from a dealer. |
12-07-2015, 11:18 AM | #16 |
Rep 49
We dont ever use the style # at the dealer, so im not use to using it. So use to useing the last 3 of the part number.
12-28-2015, 10:43 PM | #17 |
Rep 198
Hi,
My car came with 225 35 20 front and 255 30 20 rear. I want to change them with all season and get 225 35 20 front and 275 35 20 rear Continental DWS. Would that still be ok (rear)? |
12-29-2015, 11:27 AM | #20 |
Rep 198
255/30-20 275/30-20 Difference
Diameter inches (mm) 26.02 (661) 26.5 (673) 0.47 (12) 1.8% Width inches (mm) 10.04 (255) 10.83 (275) 0.79 (20) 7.8% Circum. inches (mm) 81.76 (2076.59) 83.24 (2114.29) 1.48 (37.7) 1.8% Sidewall Height inches (mm) 3.01 (76.5) 3.25 (82.5) 0.24 (6) 7.8% Revolutions per mile (km) 774.99 (481.56) 761.17 (472.97) -13.82 (-8.59) -1.8% |
12-29-2015, 04:51 PM | #21 | |
Rep 5,140
12-29-2015, 09:52 PM | #22 |
Rep 198
The PZero i have on the car look horrible.
I need to get wider tires for the rear. Just that i have to find out the max size i can go with for the 8.5 rim. |
