03-13-2019, 10:25 PM | #67 |
Rep 415
The e20 log is a little strange, boost/load is quite a bit off target. Some of your older logs had some erratic boost control too. A slightly leaner afr might give you the room to run e20 at this load.
With the e40 m2 logs I expected to see a fairly clean e20 log on yours. M2 on oem flash has a richer afr which adds extra stress to the hpfp. On a proper map with a more suitable afr i’d expect to see a higher ethanol tolerance over the jb4 setup. This hpfp upgrade might just be suitable for the stock turbo guys looking to max out performance there. Hopefully your tuner can get you an e20 specific map to test. |
03-14-2019, 02:19 PM | #68 | |
Rep 1,288
03-15-2019, 10:09 PM | #69 |
Rep 415
B58 on Stock turbo and fuel system running e85 on BM3.....
AFR is leaner but it shows that the hpd5 evo can support e85 with the required tuning. Last edited by Daleb; 03-16-2019 at 10:30 AM.. |
03-19-2019, 04:18 AM | #71 | |
Rep 2,418
Momir@MHD
(A Dane in China) |
03-20-2019, 04:29 AM | #72 |
Rep 11
03-24-2019, 08:29 PM | #73 |
Rep 3
I was having HPFP problems so i decided to give this a try.
Before: https://datazap.me/u/racemepunk/4th-...16-20-21-22-24 After changing HPFP: https://datazap.me/u/racemepunk/4th-...-5-17-21-22-24 i have been waiting for my tuner to poke at the HPFP to see if it will hold up. |
sea_m2c83.00 T_H_O_M_A_S192.00 |
03-27-2019, 07:07 AM | #74 | |
Rep 415
When fitting the b58 hpfp did you use the sealing o-ring the n55 hpfp uses? I notice the b58 hpfp does not use one. |
03-27-2019, 10:22 AM | #75 | |
Rep 3
2013 F30 335i xDrive Stock turbo, VRSF 5" intercooler, catless downpipe, Injen air intake, FTP charge pipe + boost pipe, Walbro 450 fuel pump, 2017 430i HPFP and MHD E30 custom map. I used the o-ring from the N55.
2013 F30 Mineral Gray 335i xDrive Sport Line, FBO, MHD E30 Stage 2
BeerHerder250.50 |
03-27-2019, 01:20 PM | #76 |
Rep 155
Hey, can you try full E85?
03-27-2019, 01:43 PM | #77 |
Rep 1,115
Anyone know what the max psi we can get out of this? Mine stock N55 HPFP hits 2,900psi according to BM3 logs. Haven't seen anything higher with the evo pump in people's logs. Not even sure if the MHD logs are measuring the same thing as the BM3 ones.
03-27-2019, 04:35 PM | #78 |
Rep 3
I spoke to 2 different tuners and they both said 40% is the most the N55 fuel system can support.
03-28-2019, 07:39 AM | #79 |
Rep 155
03-28-2019, 09:04 PM | #80 | |
Rep 284
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
03-28-2019, 10:39 PM | #81 |
Modder of everything I own
147
Rep 491
With the Walbro LPFP I run 50% all the time, and I ran as high as 60%. I am PWG N55.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
03-31-2019, 11:18 PM | #82 | |
Rep 296
04-04-2019, 08:57 PM | #83 |
Boost Addict
369
Rep 362
JordanTune just released full E85 flash for B58...stock fueling.
So we just need to find how to calibrate the B58 pump correctly to our N55...
S55 M2C | Three Pedal Club | E30TU
04-05-2019, 03:50 PM | #84 | |
Rep 63
I wonder if the tables exist for the N55 so it can run the B58 pump full E85. Hoping some of the tuners can chime in. I do know that for full e85, it can only handle it on stock turbo. If you upgrade the turbo with the B58, the hpfp can not supply for E85 at higher boost levels.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless 2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30 |
04-05-2019, 04:42 PM | #85 | |
Rep 1,139
04-06-2019, 05:58 PM | #86 | ||
Typical Car Guy
55
Rep 25
Look how the outlet of the pump separates into 2 hoses to our 1. (Part 5) Now look why, there are 2 separate fuel rails where we have 1. And this is just the tip of the fueling iceberg as this is only the equipment side. I do not know the compression differences, where the AFR's lie - whether the B58 runs more lean or rich, etc. If a tuner would like to jump on the N55 using a B58 hpfp, we can see what its made of. There have been articles saying the B58 is also fueling limited and Mission Performance and APR has already started looking at an upgrade for the B58. So please note that this is not the end all for the N55 hpfp woes, its just a great step forward without having to spend +$2k.
'15 435i ///M Sport
CTS Intake • VRSF CP/Race FMIC/DP/TIC • MST Inlet • xHP S3 • 3.5 TMAP • Dorch S1 HPFP • Wedge Tuned |
Jpup26.00 |
04-08-2019, 04:20 PM | #88 | |
Rep 171
Hey Thomas, Do you have any additions pictures (like the ones on N54 Tech) of the cuts you made to the B58 pump in order to get it to fit? I see the picture that shows where the new mounting hole is drilled which seems pretty clear. I notice that you also cut off part of the mounting bracket though and would like to see what that cut looks like if possible. Looking to do my pump install this weekend and begin logging/testing. Thanks! -Chris
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i |
