09-07-2019, 04:14 PM | #23 |
Cheapskate
4575
Rep 5,013
Maybe that's why I had no complaints. I didn't even have 5000 miles on my car before i upgraded wheels and tires. But I expected them to be horrible on day 1 based on the feedback here, and they drove and performed just fine. I felt a bigger difference going from stock suspension to springs and then coilovers.
car_driver148.50 |
09-09-2019, 06:03 PM | #24 |
Senpai
781
Rep 1,174
biggest complaint is that they got rid of the spare tire. why would get rid of the spare. if you have a flat at least you can change the wheel and be on your way.
but even if you have runflats you still need to take you car to the shop and its out of commission for who knows how long, first to set the appt and second to actually order the tire and wait for it, and if you have one car than you are outta luck. at least if you have a spare you can take the wheel to the shop and still use the car.
IG: it.g.ma_g87
car_driver148.50 |
09-10-2019, 05:49 PM | #26 | |
Curmudgeon and Pedant
693
Rep 3,488
One time I was on a road trip, carried one of my summer tires (it was winter) for a spare. I do carry an inflater/pump; have had to inflate a tire in the parking garage once or twice after overnight air loss. |
09-10-2019, 06:05 PM | #27 |
Rep 520
Drives: 2016 435i
If you have not switched from a RFT to a normal tire you do not know what you are missing. Just the ride noise alone will make you switch. RFTs are the noisiest tires you will ever run.
2016 435i MSport ZHP #85
Styx58.00 |
09-10-2019, 10:50 PM | #29 | |
Rep 331
Drives: M140i F20 LCI-2
I also carry these items: * Space saver spare wheel. * Jack; Torque wrench & Breaker bar kit. * Wheel lug tool (reverselogic.us)
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. Last edited by DrGadget; 01-10-2020 at 08:18 PM.. |
Machinebuilder280.50 |
09-11-2019, 03:02 AM | #30 | |
Rep 941
This...My 30 profile 20" tires absorb potholes much better than my 45 profile 18" new RFTs. And the noise!
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
Styx58.00 |
09-11-2019, 04:16 AM | #31 |
Rep 1,828
I carry a small compressor and tire sealant and recently picked up a plug kit. Also have a few basic tools in my trunk, including a folding lug wrench. Haven't had a flat yet, but if I did, I wouldn't be stranded. Will probably add a scissor jack to the mix.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
09-11-2019, 04:23 AM | #32 | ||
Rep 1,828
09-14-2019, 03:52 PM | #33 |
Rep 165
I have had my 2017 440i for 34 months, I have 16,400 mi and my tires are shot ( Pirelli P-zero RFT's). I had RFT's on my 2004 C5 Corvette, replaced them 3 times (about 30k each time) until the 4th time I went with non-run flats. Wow, what a difference.
Now, I have 14 months left on my warranty on the BMW and what I would like to know is: if I replace RFT's with non RFT's, will BMW use this as an excuse to say no to warranty items that are related to tires, I.e., NOT something like a horn replacement ( done two weeks ago) or an instrument cluster replacement ( done 3 months ago)? |
11-06-2019, 05:20 PM | #34 |
Rep 440
Drives: 2013 335i xDrive
I took off the OEM Continental runflats yesterday. They weren't wore out but I was tired of the harshness. Replaced them with OEM sized Goodyear "normal" tires. Man, what a difference. Never, ever, will I run runflats again. There's a reason tractors no longer have steel wheels, and it's not cost.
I'm not completely useless, I can be used as a bad example.
DL335D585.50 |
11-07-2019, 12:27 PM | #35 |
Rep 848
Drives: BMW 435i
A week ago I mounted my non-runflat winter tires on my car and it's been an eye-opening experience.
Based on the mountains of anecdotal evidence regarding runflats I had no doubt there would be a difference, but I wasn't prepared for exactly how big of a difference I've experienced. I fully understand going from 19" to 18" would soften the ride a bit due to a taller sidewall, but what has really impressed me was how less brittle the road feel is over imperfections and the reduction of tire noise. I'm running the Pirelli Sottozero 3s which have a pretty agressive, directional tread. They aren't *that* quiet, but they are still quieter on than the S001 runflat summer tires on every type of road surface I've encountered. |
11-07-2019, 02:15 PM | #36 | |
Rep 774
you mean like they do with the X1 i just paid to have the spare put into?
11-07-2019, 02:18 PM | #37 | |
Rep 774
i wonder how much of that is also winter vs summer tires. i have 18 inch sottozero 2 winter runflats and they are quieter and ride is a little smoother, maybe due to softer compound. The ride is noisier and harsher with my 18 inch pilot super sport non runflats.
11-10-2019, 11:41 PM | #39 |
Rep 1,031
Drives: Like a bat out of hell.
I had a flat and called AAA. They arrived promptly after 90 minutes of wait and then had to tow me for another 30 minutes to the nearest tire store. So it was only 2 hours wasted!
AAA gold membership does not guarantee rapid response. |
11-11-2019, 03:19 AM | #40 | |
Rep 23
GenXer1403.00 |
11-12-2019, 09:46 AM | #41 |
Rep 848
Drives: BMW 435i
You're roads are substantially better than those in the US, so the runflats probably aren't as big of a problem from a ride standpoint, though I'm surprised they aren't louder.
11-12-2019, 04:56 PM | #42 | |
Rep 941
2013 e92 M3
11-12-2019, 05:15 PM | #43 | |
Rep 848
Drives: BMW 435i
We're fortunate to not have the same level of weather related pot holes you and others living in the northern tier see, but we have our share of seams between concrete segments of the roads and cracking from the wild temperature swings. Each one of those is a sharp impact that is amplified, rather than blunted, by the stiff runflat sidewalls. |
DL335D585.50 |
11-13-2019, 11:30 AM | #44 |
Rep 4
I just moved to 19" non-RF tyres from 18" RFs. Only really moved up in size because my current alloys had a lot of curb damage. Anyway, not a fair comparison - but the 18" RFs were more a more comfy drive. Probably more to do with more tyre depth than anything though.
