11-29-2019, 11:03 PM | #1 |
Rep 46
Just installed M Performance Brakes - need some advice
Just installed these brakes along with some Hawk 5.0 pads and new lines.
Was testing them briefly tonight after using a motive power bleeder and coding SPBR. So far, I have a very soft brake pedal on first press, and firms up on subsequent presses. During the bleeding process, I didn't see any more air bubbles before putting the wheels back on. Unfortunately, I ran out of brake fluid to try the DSC bleed, but I'm guessing there's probably some stuck air somewhere. I also noticed that on the driver side, the outer edge of the disc still had the initial coating where the pads didn't touch. All the other rotors are even. Could this be an indication that air might be trapped on this side or do I have two separate issues? Here's an image of what I'm referring to: |
11-30-2019, 01:17 PM | #2 |
Rep 8,778
M-Performance brakes had a rep for soft pedal, and it wasn't cured by coding big brakes in the relevant module.
Hopefully you spotted that you were running low on brake fluid before the level dropped below critical in the brake fluid reservoir. You really don't want to have got air in there. There are two bleed nipples on each caliper. Bleed from the inner nipple first (nearest the dust shield), then the outer. Continuously tapping the caliper with a rubber mallet as you bleed it is a good way of dislodging any small air bubbles that may be trapped. Once you're certain that the braking system is fully bled, you should bed the brakes. The surfaces of the pads and discs need to have been properly settled/mated first, just through normal driving for (say) 50 miles. You're going to need a quiet stretch of (ideally) straight road for this. Warm the discs and pads by doing some light-medium braking. Do 10 consecutive (back to back) hard stops, 60mph down to 5mph, almost enough to trigger the ABS. Do not allow the car to stop. Immediately you hit 5mph, accelerate back to 60 and repeat. The discs and pads will get VERY hot. You should expect some smoke, for them to smell very hot, and ideally you want to see a blue-ash tinge on the faces of the discs (which you'll only be able to check once you've parked the car). Then go for a LONG drive, probably 20 miles, to thoroughly cool the brakes. Plan your route so that you won't need to bring the car to a stop, therefore avoiding very hot pads creating localised thicker pad deposits on the discs. Once the braking system has been thoroughly cooled you can return home and park it overnight to cool to ambient. I wouldn't worry about the unswept area on the discs in your photo. As long as the pads have been fitted correctly it's just indicating that the pad contact area is slightly smaller than OEM. Some pads are chamfered to aid the pad mating/bedding process, but this is normally only on the short edges of the pads (i.e. not along the longer radiused edges).
cfm56d7b6746.00 David Kunitz927.50 |
11-30-2019, 02:46 PM | #3 |
Rep 46
Yessir, I haven't bedded the pads yet but after adjusting the pads a little today I see that they are making full contact now!
I still feel that my brakes are a little too soft, going to try to bleed again once more when fluid arrives and follow your advice on the bedding. You think I should just go straight to DSC bleeding instead of via a power bleeder? Getting Rheingold and all that installed as we speak.. Thanks |
11-30-2019, 04:22 PM | #4 |
Rep 8,778
I use a pressure bleeder and it works fine. No real need for anything fancy or expensive.
20psi is sufficient to push fluid through the braking system, and makes the process of bleeding at the nipples very easy. The correct sequence is LR, RR, LF, RF. I also have someone do 2 or 3 full travel brake pedal pushes (slowly) while I'm bleeding the first caliper - this makes sure that there's also fresh fluid in the master cylinder.
12-04-2019, 05:36 PM | #7 |
Rep 46
I used Rheingold today but kinda confused by the order of bleeding it was telling me.
Basically it said to do Left rear, left front first, with no way to ever do the right side unless i restart the procedure which will then ask me to do the left side again (even though it works for the right as well)? Also there was no way to pause so that you can bleed both valves in the front. Last edited by InceptionBW; 12-04-2019 at 05:46 PM.. |
12-04-2019, 06:16 PM | #8 | |
Rep 3,706
johnung5039.50 |
12-06-2019, 10:10 PM | #12 |
Rep 46
No these are not from the M sport package. They're a little different than the blue ones , front rotor is 370mm and all rotors are dimple/slotted. Got them off a dealer on ebay.
12-10-2019, 12:01 PM | #13 | |
Rep 266
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers |
12-10-2019, 04:45 PM | #14 |
Rep 46
It was at a very slight angle initially so I took out the pins and aligned them more evenly before locking it in. Lastly, make sure there is absolutely no air in the lines so that the new pistons can fully press.
09-08-2023, 11:31 AM | #15 |
Rep 36
i'm having a similar issue where i've had the M-Performance brakes put in. Brakes have been coded and with ISTA the brake bleeding routine has been done yet i still have a spongy pedal? Can anyone help?
10-21-2024, 05:30 PM | #16 |
these BMW can be a pain
Rep 31
Drives: BMW E82 123d 2012
10-23-2024, 02:10 PM | #17 | |
Rep 20
You have air in your system. Pressure bleed the system again. Maybe get on ABS a few times before you bleed. I never do the ISTA bleed procedure. |
10-30-2024, 02:35 PM | #18 |
Rep 185
From personal experience, I can say that it also impacts front/rear braking balance.
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
11-09-2024, 04:59 AM | #19 |
Rep 65
The brake pads are the same between the 340mm and the 370mm, so their contact patch is the same. This leaves the 370mm rotors with some unused rotor material around the edges.
11-10-2024, 03:08 PM | #20 |
Rep 4,132
The above makes no sense - then the unused diametrical space on the rotors must be min 3 cm..... that's is A LOT:
I don't have that much area without contact on my M Sport brakes.
11-10-2024, 04:23 PM | #21 | |
Rep 185
The additional distance from the center allows the same clamping force to generate more braking force. Also, the thermal mass of the rotor is increased. Finally, the cooling vanes extend further out, increasing the cooling airflow.
11-18-2024, 05:13 PM | #22 | |
Rep 65
I own two cars one with 340 and the other with 370mm calipers. They use the same pads. |
