BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > DSC ABS faults, one time
      08-11-2020, 02:27 PM   #1
bgalakazam
bgalakazam's Avatar
Drives: 2015 328i
2015 BMW 328i  [0.00]
Completed a long 1000+ km trip this weekend. Yesterday got a few faults for ABS and then DSC and the car would only stay in Comfort and say drive moderately. I couldn't get to ISTA that day and today the error went away. The day was very hot, but I doubt that would make the malfunction. Here is a list of codes I scanned today, all show Existent: No.
Code:
1B0A21 Rough road detection: no wheel speed signal received
421474 Output speed and wheel speed: Impermissible deviation
480686 Wheel speed sensor: Drive-off recognition, rear right
48071B Wheel speed sensor: Voltage supply, short circuit, rear right
480AB1 Wheel speed sensor: sporadic fault, rear right
480AB4 Wheel speed sensor: Plausibility, signal fault, rear right
CD944D Signal (actual wheel speed, 46.0.1) invalid, transmitter DSC
CF2F02 Signal (actual speed of rear left/front left/rear right/front right wheel, 0x254) invalid,
D017A3 Signal (actual number, signal edge, wheel, 64.1.2) invalid, transmitter DSC
D017C5 Interface DSC (actual speed, wheel, 46.0.1): Signal invalid
D017C6 Signal (actual wheel speed, 46.0.1) undefined, transmitter DSC
D36D58 Signal (wheel torque, powertrain 1, 0X08F) invalid, transmitter DME/DDE
I also have stage 2 Bootmod3 if that matters at all.
Should I replace the sensor proactively or just wait until another fault appears? The error looked sporadic and there were no issues in driving.
      08-11-2020, 02:33 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Clear the fault, then run the sensor test. I don't know if your software can do that, my Foxwell NT510 can. I had this happen one time, cleared the codes and tested the sensor, which tested good. This was over two years ago, it never happened again.
      08-12-2020, 12:44 AM   #3
Polo08816
Drives: 2014 335i M Sport
+1. Clear the faults and see if it occurs again. The faults seem to indicate something is wrong with the rear right wheel speed sensor.
      08-18-2020, 12:42 PM   #4
bgalakazam
bgalakazam's Avatar
Drives: 2015 328i
Error keeps comming back and then going away after a power off. I'll start with the speed sensor as it's easiest and cheapest.
      08-18-2020, 01:07 PM   #5
Billfitz
Billfitz's Avatar
All of those codes would be caused by a defective or unplugged speed sensor.
Polo088161652.00
      08-13-2024, 11:39 PM   #6
Jaylato
Jaylato
Jaylato's Avatar
Drives: 2014 BMW 640i XDrive
Did you ever find a fix?
      08-14-2024, 10:48 AM   #7
Billfitz
Billfitz's Avatar
He hasn't posted here for more than a year.
      11-22-2024, 10:22 AM   #8
RawGeneticssss
Drives: BMW 435I Gran Coupe
Tryna look for fix’s to these codes
12A308 - Oxygen sensor after catalytic converter, dynamics, from rich to lean: Slow response.
12BE08 - Oxygen sensor after catalytic converter, dynamics, from lean to rich: Slow response.
1B0A21 - Rough road detection: No wheel RPM
signal received.
1 B0A66 - Driving speed, wheel RPM sensor rear/right, signal change: Not plausible.
CD944D - Signal (wheel RPM, 46.0.1) invalid, transmitter DSC.
CF2F02 - Signal (actual speed of rear left/front left/rear right/front right wheel, 0x254) invalid, transmitter
      11-22-2024, 12:03 PM   #9
Billfitz
Billfitz's Avatar
Let sleeping zombie threads lie. Start your own.
