10-13-2023, 09:28 AM | #287 |
Rep 114
Hello,
First, This Gergo Borlai, sounds great in my car: This Eric Moore, not enough: So, For the kick and upper end of the bass drum spectrum, I'm going to have custom panels made to add 6"5 to the bottom of the door for the MATCH UP 10DSP subwoofer output: 4 Ohms 2 x 90 Watts or, 2 Ohms 2 x 160 Watts My system is HK front fully active (with new tweeters, HK 4" and 10" woofer under the seat (currently 35 hz to 250 hz). Adjusting crossover frequencies is not a problem. Theremore (my underseat woofer are bridged), even if I think that there is no point in hoping, I'm trying to get some stereo bass that we hear from Toni Braxton "Sposed to be". Here (stay focused), I need your advice for the best choice between these 2 solutions or any other better proposal : https://www.ground-zero-audio.com/wp...GZUK-165SQ.pdf https://www.focal.com/sites/www.foca...ical_sheet.pdf Then: To feel the bass, including the ones I don't hear; powered by, 500 Watts x 1 @ 4-Ohm Efficiency 84.1% @ 4-Ohm or, 500 Watts x 1 @ 2-Ohm Efficiency 81.6% @ 2-Ohm I need your advice for the best choice of 15" in a 50 to 70 liter enclosure between : Rockford Fosgate P2D2 or P2D4 and Dayton Audio UM15-22 or any other better proposal. Thanks for your help |
10-13-2023, 10:29 AM | #288 |
Rep 17,058
IMO there's no point in adding more speakers. If the current in-door 4" are inadequate I'd replace them with 6.5". You don't say what your 10" under the seat are, but if they truly handle 35-250Hz why do you need more? If you run them to 250Hz and the 4" above 250Hz the 4" should be quite sufficient. If they actually reach 35Hz there's no reason to add a sub. BTW, there has been no such thing as low frequency stereo since the 1970s. All content below 80Hz is summed to mono.
10-13-2023, 02:40 PM | #289 |
Rep 824
If your going to do lower doors
SI TM8 in the lower doors and forget about underseat 10 inch Replace 100 mm HKs with SI M3 carbon for wider dispersion ( 90 mm ) GB10 tweeters ( bmw snap in tweeter version ) SI SQL15 in the trunk And a ton of sound deadening in the trunk because it’s going to rattle beyond belief |
10-13-2023, 04:45 PM | #290 | |
Rep 114
On "sposed to be" Toni Braxton, the deep, heavy bass moves from left to right: unusual, but excellent. The 4" and 8" (not the 10", I made a mistake) are stock HK. As I said, the 6"5 seems essential to get what my ears and emotions expect. I haven't worked on the settings yet, but it's not the bass that missing, it's the sensations. The 15" and 6.5" generate waves that have more range and will give me the possibility of many combinations. |
10-13-2023, 05:43 PM | #291 | |
Rep 114
On the other hand, the TM8 seems an excellent answer to my problem, especially as it fills in perfectly where the performance of my 8" starts to fall off, they seem to complement each other perfectly but I don't have the 150 watts needed to push them and that's a pity, the 90 watts I have won't be enough. |
10-13-2023, 06:15 PM | #292 |
Rep 824
SQL15 & 12 will go louder than the punch for the same power and with 400- 500
Watt bass can easily get to high 120db. Your Dayton idea is also worth considering as well. . I’m running 400-500 rms into a high excursion 12 inch and still working through trunk treatments to tame rattles. It does shake the car. 90 rms watts into doors running 8 inch speakers will go loud. They will need quite a bit of door treatment at that power level. But the advantage with your door idea is you can run them to 300 hz to better cover midbass and change the door mids up to match. |
10-13-2023, 06:42 PM | #293 | ||
Rep 17,058
10-14-2023, 10:48 AM | #294 | |
Rep 114
I'm sure you'll be able to help me find a solution to my needs, given the constraints of the sound environment of a "coupé". Maybe you can say what do you hear in the low frequencies of "Sposed to be"? What frequencies do you hear? And What goes from left to right? I hear them in 30 to 100hz. But I'll make measurement of this. In the studio, a bass drum is recorded then, frequency samples are added to get that heavy, punchy sound. What in my car will produce this heavy, punchy sound? Overlapping frequencies from a 15" subwoofer and the underseat 8" woofer, provided they don't cancel each other out? |
10-14-2023, 11:04 AM | #295 | |
Rep 114
The TM8 is a choice I'm keeping for if I have to change my under-seat woofer because it's too big for the door. |
10-14-2023, 12:30 PM | #296 | |
Rep 17,058
One cannot rely on their ears. It's typical for listeners to think what they're hearing in the bass is at least a full octave lower than what's actually there. Measurements are the only way to know. Even if there is content in the low bass what you mainly hear is the midbass, the result of equal loudness.
10-15-2023, 01:28 PM | #297 |
Rep 114
What do you think about adding a subwoofer and leaving the 8" HK on a smaller range.
This will allow me to manage the ranges separately for finer tuning. Something like: 20 Hz - 63 Hz : Sub (15" UM15-22){1 x 500 W} 63 Hz - 120 Hz : Bass (8" HK under seat) {1 x 500 W@4ohms} 120 Hz - 500 Hz : Low-midrange. (6.5" GZUK 165SQ) {2 x 90 W@4ohms} 500 Hz - 3500 Hz: Midrange. (4" HK OEM) {2 x 75 W}. 3500 Hz - 20000 Hz : Tweeter |
10-15-2023, 02:51 PM | #298 |
Rep 824
With the HKs you’d be better off running them in stereo if you can. The response of the left and right drivers isn’t in sync and the drivers side has dip after 100 hz.
Also the HK become more muddy as the power levels increase. Running 60hz up running 24 DB LR4 filters they can take quite a bit of power though, I wasn’t hearing excursion limits with 140 rms on tap. Here’s a graph of my current woofers with no eq or filters to illustrate the the differences with a 45hz - 175 hz sweep Blue graph is drivers side with no people in car. |
10-15-2023, 03:39 PM | #299 | |
Rep 17,058
10-20-2023, 09:09 AM | #300 |
Rep 8
I am just looking for some advice RE: wiring as i just received my 10dsp and mobridge DA1.
DA1 power supply - From jmciver pic on page 2, it looks like the helix is being powered by the match up's pin 10 & 20 from the system controller. The manual says do not connect this which has got me confused? are these actual live outputs which can be used to power the da1? Remote - The da1 has a remote ouput so was going to use that for sending signal to the match up but if this is the case, if the power is being sent from the match up to the da1, it wouldnt be able to send the remoute out if its receiving its power from the matchup? any guidance on the above would be very much appreciated. |
10-20-2023, 05:21 PM | #301 | |
///M SubDriver
1918
Rep 2,794
While it is not very clear in the manual (and the harness connector did not come with a manual), pins 9, 10, 19 & 20 are connected to the main power input to the amp, basically acting like a power pass through. This will allow you to power other devices, like the SDMI25, without the need to run separate power lines for the SDMI25. The warning in the manual to not use those pins is so you don’t use those pins to connect the amp to the car for power - you are supposed to use the main power connector for that purpose. As for the remote signal, the Remote Out signal from the DA1 goes to the Remote In of the UP10. The DA1 tells the UP10 to turn on when the DA1 has a sound signal. The remote signal does not provide power to the amp. However, in your case since you are not using the SDMI25, which is made by Audiotec, it might be better to run separate power lines to your DA1 and just connect the Remote In/Out between the DA1 and UP10 along with the audio lines.
i4 ///M50 - 2024 G26 Dravit Grey Metallic
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic |
10-21-2023, 03:00 AM | #302 |
Rep 114
You may need to match Mobridge connectors with Match harness 1.9 + SDMI
10-21-2023, 01:30 PM | #303 | |
Rep 8
I set it up in the car today but getting no warning tones in the car It started to rain and i was losing light so decided to look into it in the morning. somethings not right somewhere it seems. Got a most signal still out the connector going into the da1 so i know thats not the issue. Will check the lives etc and start the process of elimination. |
10-21-2023, 02:56 PM | #304 | |
Rep 824
With Mobridge “no warning tones” usually means the device needs to be configured to BMW and that the 4 sinks ( chime, pdc, hands free, Nav announcements ) need to be mapped to left and right channels. Download the Mobridge windows or Mac app and connect to the DA1 via usb. Menus are straight forward to configure. App will also do an online check and will download any firmware updates for unit. |
10-24-2023, 01:27 PM | #305 |
Rep 114
I'm back for the best choice between these 6.5" door speakers, connected to the MATCH UP10's subwoofer outputs.
100-120 hz to 500 hz 2 x 90 Watts @4 Ohms with: GZUK-165SQ https://www.ground-zero-audio.com/wp...GZUK-165SQ.pdf or, 2 x 160 Watts @2 Ohms with: ES165-KX2 https://www.focal.com/sites/www.foca...ical_sheet.pdf |
10-24-2023, 03:53 PM | #306 |
Rep 17,058
Neither. If you're using them from 100-500Hz the Fs is too low. It should be between 70-90Hz. Besides, both have a ludicrous price. No 6.5 inch is worth more than $100 USD.
I wouldn't use larger than a 5 inch, there's more selection with the best specs, and no need for a 6.5 inch if you're only using it down to 100Hz. There's also no reason to use either a 5 or 6.5 inch to only 500Hz. Most are capable to at least 3kHz. |
11-02-2023, 05:13 AM | #307 | |
Rep 8
I haven’t had an opportunity to tune correctly but out the gate, the underseat woofers sound terrible compared to how they were with the hk amp. Sounds like their polarity is backwards, that’s how poor they sound?? I did check the polarity in the dsp and it’s not that but is the best way to explain how they sound. I need to get my mic off my colleague so I can start tuning and see what the actual problem is. Also I noticed the volume of phone calls is a lot lower than they were before? Need to spend some time with it but at least I have sound back in the car, although I don’t want to listen to it like it is. |
11-02-2023, 05:52 AM | #308 | |
Rep 824
The Mobridge is set so that factory eq via nbt can be maxed without digital clipping. Also recent software updates have more gain available. But you now have a flat signal with no processing to start with. Try the underseats with +6 db gain compared with your mids as a starting point to restore bass . You may need to flip polarity with mids if your using 12 db filters. But mic / RTA obviously will show what is happening. |
