BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > F36 Inconsistent Steering
      09-28-2022, 04:14 AM   #1
nastynick83
Drives: 330xd M-sport
All,
I've recently bought a 420d Gran Coupe (F36) 2016 after a 3yr gap from BMW (went to a Tesla M3 P, which was awesome but wasn't doing the miles).
I've had several BMWs in the past; 330xd, 420d, 120d, 116ed but this one doesn't feel 'right' in the steering department...
The easiest way I can describe it is that the power steering is inconsistent and almost goes to sleep. When driving on a straight bit of road it's fine - but then as you start to apply steering input there's an initial resistance and then it's not smooth - think notchy. Then in contrast, when you are driving on a twisty road, the steering feels exceptionally light as though the power steering is working on overdrive.
Tyres are standard fit, Potenza's with >5mm tread and 31psi (tried different pressures too).
Anyone got any ideas? It's in BMW on Monday for EGR recall (software update).
Nick
      09-28-2022, 04:35 AM   #2
Markos ZimZimma
Drives: 2015 BMW F31 335i
Originally Posted by nastynick83 View Post
All,
Nick
Doesn't sound great, is it worth asking BMW about it on Monday? They might want +/- £200 for a diagnosis. Presume all BMWs of that age have electronic steering (bar M cars) so it could be software related perhaps.
2015 F31 335i
      09-28-2022, 05:33 AM   #3
Abzynthe
Abzynthe's Avatar
Drives: BMW 440i Gran Coupe LCI
Maybe it has variable sport steering or servotronic steering?
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3)
      09-28-2022, 05:51 AM   #4
johnung
johnung's Avatar
All,
Nick
With steering symptoms on the F3x always check the big cylindrical bushings on the front upper control arms. See photo. They're big oil filled rubber things. They leak if they are shot. Replace the pair of control arms with aftermarket like Lemforder.
People think the electric steering is to blame for the F3x vague steering but it's mostly these bushings.
      09-28-2022, 06:35 AM   #5
nastynick83
Brilliant - thank you! I will take a look (read: ask BMW to take a look on Monday)
Nick
      09-28-2022, 06:36 AM   #6
nastynick83
I'm a glass half-full, kinda guy and did think whether software may resolve, which is what I believe the EGR recall is going to do.
Agree with the plan on asking BMW to investigate by throwing money at the problem. Was keen to see if anyone else experienced something similar to help point BMW in the right direction
Nick
      09-28-2022, 06:55 AM   #7
HighlandPete
Drives: BMW F11 535i Touring
That's a strange set of symptoms.
In a straight line, there is no power to the rack. Only when the torque sensor is 'loaded' does power get applied. Notchy, could indicate erratic assistance. Then the light feeling through the 'twisties'... appears over assisted.
I wonder if the torque sensor is playing up.
Couple of thoughts which may give more clues... does it behave same/different in Comfort vs. Sport mode? (Ensure chassis/steering is checked).
Does it respond differently, if the steering input is gentle, compared to quick more aggressive inputs?
      09-28-2022, 07:00 AM   #8
johnung
johnung's Avatar
Nick
Just to give you an idea of cost, see photo. The name brand aftermarket companies like Lemforder, TRW, Mehle, make them for BMW and are less than half the price of Genuine BMW. An independent BMW shop shouldn't charge more than 2 hours labor to install a pair.
      09-29-2022, 06:08 AM   #9
nastynick83
I'm finding it hard to describe the symptoms other than 'it doesn't feel right'...
It behaves the same when in comfort or sport - the latter just being slightly heavier steering (but still gets un-naturally light when used).
When steering gently - example, making small corrections to steering while on a motorway - you go to make a slight steering adjustment and there's the initial resistance. So it feels like you can never make a small adjustment smoothly without having to apply more force than expected.
When steering more aggressively - this is when the steering starts to get exceptionally light and just feels completely disconnected from the road. Example a drive on a B-road with lots of bends.
So it feels like when doing small movements less frequently that it's gone to sleep but when steering actively that it's on overdrive.
I'd point the finger at the power steering - not giving consistent power assistance?
Nick
      09-29-2022, 06:29 AM   #10
Wibbles
Coding ECU's remotely
Wibbles's Avatar
484
Drives: M3LR & E70 40d
It's likely to be the SZL that is at afault - I had the same symptoms on an M135i with variable sport steering - basicaly the steering angle sensor is at fault, so the car's ecu's cannot detirmine how much assistance to give.
Swap out the stalks, which contains the SZL and see if it makes a difference.
      09-29-2022, 06:29 AM   #11
MY340i
Drives: Various
Hi Nick,
Let me know how you get on with this as have it on my car and its driving me mad. I've done the following so far
1) changed tyres and tyre pressures
2) Hunter alignment and tracking done
3) EPS software update as there were some technical bulletins saying this could solve it
4) had suspension visually checked, no obvious issues
5) diagnostics ran on car, no obvious issues.
looking to be either one of three things:
1) new SZL
2) Steering rack is on its way out, in which case it will need to be replaced.
3) full suspension refresh, ARB etc.
      09-29-2022, 06:32 AM   #12
MY340i
Drives: Various
Hi wibbles - this could very much be the case with mine, as my steering is much like that is described above.
But nothing showing on diagnostics atm.
I had intermittent cruise control failure, and the local indi changed the wiring harness and that seems to have resolved it.
They said if error comes again then the SZL will need to be changed which is coming to £450 + Vat + fitting + coding. does this sound about right?
      09-29-2022, 06:55 AM   #13
Wibbles
Wibbles's Avatar
484
CC failure is another symptom because the CC uses the steering angle sensor.
Mine did not show up on any diagnostics either, I only found out that was the issue when I retrofitted a heated steering wheel and needed to swap out the stalks and SZL for a different part to suit the new wheel.
Price wise, you could fit and code that yourself for £100 - depending on part cost for a used SZL.
      09-29-2022, 07:40 AM   #14
MY340i
Drives: Various
nice one thanks. Good to know a used SZL can be used.
Infact I've just taken the 340i for an extended test drive, first time since getting it back from the steering wheel loom being replaced.
Seems to be behaving properly now. Not sure if its resolved, or maybe just a placebo effect in my head, but steering now feeling good again.
      09-29-2022, 07:48 AM   #15
Wibbles
Wibbles's Avatar
484
The SZL is not VIN locked and does not need coding as such - the steering angle sensor can be reset with diagnostics but if you purchase a used part with the same part number as the one on your car, will be plug and play
MY340i811.00
      09-29-2022, 08:04 AM   #16
HighlandPete
Not following how the SZL is linked to the steering issues posted above, as the F3x models with their EPS, don't have a conventional steering angle sensor.
The steering angle sensing is performed from within the rack, using motor position.
The information on the steering angle in the F30 is not recorded by the Electronic Power Steering EPS via a separate sensor on the steering wheel and instead is computed based on the angle of the EPS motor position in relation to the steering wheel.
New: The rotor position sensor is at the same time the steering angle sensor.
The EPS does not determine the steering angle using a separate sensor on the steering wheel. Instead, the EPS unit determines the steering angle from the motor position angle of EPS unit motor on the steering wheel. The EPS sends the rack position to the ICM control unit via FlexRay. To do this, the EPS calculates the absolute position of the rack from the current rotor position of the servomotor and from the number of complete rotor revolutions from the neutral position (i.e. straight-ahead driving position).
      09-29-2022, 08:25 AM   #17
Wibbles
Wibbles's Avatar
484
The SZL also feeds it's info into the ICM and is used in conjunction with the rack.
Where have you taken that information from ISTA/NewTIS?
      09-29-2022, 08:28 AM   #18
HighlandPete
BMW training and NewTIS. Same for other models like the F10 5-series.
I agree there may be a data transfer from the SZL, but it is not a SAS as the older HPAS systems.
      09-29-2022, 09:53 AM   #19
nastynick83
What is an SZL?
Nick
      09-29-2022, 10:23 AM   #20
MY340i
Drives: Various
What is an SZL?
Nick
BMW Steering Switch Unit (also referred to as SZL, center steering column switch, and switch unit in the steering column) is mounted on the BMW steering column where various switches, including a wiper, turn signal, and cruise control, are mounted.
      09-29-2022, 01:42 PM   #21
nastynick83
So if I read that correctly; symptoms could point to needing a new steering rack?
      09-29-2022, 01:45 PM   #22
nastynick83
Hi Nick,
1) new SZL
Glad that I'm not going crazy and others have had similar issues. I'm also impressed you understood my symptoms from my description.
I'll keep you posted.
Nick
