BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Battery Replacement 11.5 years old
      10-18-2023, 09:36 AM   #1
davethefish
davethefish's Avatar
Drives: 2012 F30 320i Sport
I suppose it has been on the cards for a while...
... not daring to put the heated seats on in winter
i think 11.5 years is all i am going to squeeze out of one battery
i ordered a new battery from tayna, and decided to pay the extra tenner and get the Varta,
as that is what is currently in it.
and used the bimmer link app to an icar pro OBD2 reader to register it.
the hardest part was lifting the heavy old battery out!
i did notice there were no transit plugs in the breather vents,
so used the one from the original battery to cap the opposite end to the breather pipe connection.
MOD's/DIY list
Bonnet Badge Repacement, LED Door Sills, 35%VLT Window Tinting, 442m alloys, Stainless Steel Pedals,
Front and Rear Disk Replacement, GTechniq C1 Detail, Gladen HIFI upgrade, LED DRL's, 90mm Stainless Tailpipe, Complete Leather Reupholstery.
      10-18-2023, 09:52 AM   #2
Literally about to do this myself; although I've gone with Exide as always stuck with them and never had any issues
I took the boot apart yesterday to see what battery was fitted (original dated from 2015) but down to 51% capacity; so thought best to replace it now before the temps start to properly drop
Will pop the new one onto trickle first and then fit it tomorrow sometime
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
      10-18-2023, 10:09 AM   #3
davethefish
it's pretty simple 10mm socket on the strap above the battery and the clamps,
13mm socket on the battery clamp down on the r/h side, thats a bit fiddly to get to.
i was having to charge mine about once a month as only doing short trips.
battery had 50% before i took it off.
but i never used stop start. so that has probably helped it last so long...
MOD's/DIY list
danb19792615.50
      10-18-2023, 10:22 AM   #4
Bachu1
Drives: Bmw 330d m sport
This might be a thick question, how can I find out the battery life left on my battery?
danb19792615.50
      10-18-2023, 10:32 AM   #5
Allworth
Drives: X1 xDrive20d (E84)
I have recently fitted BOSCH which is made on same factory as VARTA to replace OEM 12 years old battery, it has no tube for discharge too, so got to use an existing one.
On BMWs as battery state of charge goes below certain values some functions like rear window heating, start / stop will be suspended even if the car is running.
1995 E34 525td auto • 2016 F30 320ed auto
danb19792615.50
      10-18-2023, 10:37 AM   #6
Allworth
  • use diagnostic software
  • use multimeter
  • wait for warning icon to come up
Bachu180.00
      10-18-2023, 10:40 AM   #7
I've got Bimmerlink & Bimmercode on my iPhone; Bimmerlink will tell you what state the battery is in etc
      10-18-2023, 10:41 AM   #8
Yup; took me 2mins to access it. Very similar to how it was in my E39 touring (same location etc)
I've got a decent extension set that'll reach the clamp bolt fine etc...
Stop/start off in mine too; hate that feature
      10-18-2023, 10:55 AM   #9
Bachu1
Thanks guys
      10-18-2023, 10:58 AM   #10
HighlandPete
Drives: BMW F11 535i Touring
  • use multimeter
Is that giving you the SoC, (State of Charge) or SoH, (State of Health)?
Even good batteries can drop in SoC, depends on the driving profile.
      10-18-2023, 11:13 AM   #11
Allworth
SOC.
SOH if you do it multiple times.
      10-18-2023, 11:19 AM   #12
TurboWeasel
Drives: BMW 330D
I've always replaced them every 5 years regardless, in all my cars.
      10-18-2023, 12:32 PM   #13
HighlandPete
Many BMW users have batteries that last much longer than 5-years in our UK climate.
I ran my 535i battery to 10-years and then changed. Didn't want to risk another winter.
Garage checked the energy capacity, (SoH) and it was recording 67%. Not bad for a 10-year old 'original' BMW (Banner) battery.
      10-18-2023, 04:55 PM   #14
davethefish
heres a couple of links to the part and app i used.
the OBD 2 reader depends on your vehicle,
i think the new G series require a more expensive OBD link CX reader.
https://bimmercode.app/adapters/
but my 11 year old F30 is fine with the icar pro @ £23
you can read your battery and fault codes without buying the app at £30, to make sure your OBD 2 reader is working...
but can't register the new battery, or reset faults without buying the full version...
icar pro for F30
https://www.amazon.co.uk/dp/B071D8SY...roduct_details
bimmer link app
https://www.bimmerlink.app/
MOD's/DIY list
danb19792615.50
Bachu180.00
      10-19-2023, 03:32 AM   #15
Bachu1
icar pro for F30
bimmer link app
Thank you for the info... otherwise i would of asked to come to yours as I'm local to Bedworth :-)
danb19792615.50
      10-19-2023, 03:44 AM   #16
The Bimmercode/Bimmerlink apps are well worth having in your arsenal IMO
This is the OBD dongle I use and it's faultless:
https://www.amazon.co.uk/Vgate-BLE-i...s%2C93&sr=8-16
Such a better option over the likes of Carly for BMW IMO which you have to pay for, yearly!
I've also got a Creator C410 OBD code reader which will register a battery to your car too; it won't code a different spec battery though
https://www.amazon.co.uk/Creator-Bat...ps%2C93&sr=8-3
Again, another tool well worth owning IMO; small enough to leave in the car at all times too, very much plug n play
      10-19-2023, 03:58 AM   #17
TurboWeasel
Drives: BMW 330D
It's an old preventative maintenance habit I can't shift, and possibly also a bit of car related PTSD from trying to start my old 1980s jalopies on a cold, dark winter morning
To be fair, start-stop is defaulted to off on my F30 so I can probably get a few more years out of it
danb19792615.50
      10-19-2023, 05:24 AM   #18
I tend to fit a new battery to any new car I buy; not done it with this as I've had other priorities this year (ie my body has been trying to kill me)
Now I'm all fixed; I'm on catch up
C320348.00
      10-19-2023, 07:15 AM   #19
New battery fitted
What a sod it is to get to the 13mm bolt that clamps the battery down! My fat hands had no chance of getting in there to put it back in situ; long magnetix extension used and that only just nipped it into place
      11-02-2023, 06:04 AM   #20
davethefish
that gap for the 13mm bolt looks a lot tighter than on my car, mine was a bit fiddly but still easy to do...
MOD's/DIY list
      11-02-2023, 06:10 AM   #21
It's hard work; no way I could get my slab hands in there
Long extension with a 13mm socket with blue-tac in it to hold the bolt and soon nipped the threads and just retightened it
      11-02-2023, 03:30 PM   #22
sensible
sensible's Avatar
770
Drives: BMW 420i M-Sport Gran Coupe
I notice that the Ah and A on the new battery are slightly different to the original. Did Bimmerlik work okay, as I thought it could only register like for like.
