05-31-2024, 04:27 AM | #23 | |
Rep 12
johnung5038.50 |
05-31-2024, 12:37 PM | #24 | |
Rep 5,875
Do you have BMW 17” or BMW 18” wheels? BMW 18” can fit any F3x brakes. BMW 17” will fit Front 340’s but not 370’s. I cannot recall off the top of my head if Rear 345’s just fit under BMW 17” wheels or not. Don’t listen to anyone who badmouths Hawk 5.0 brake pads. I have used them on all my cars for years and recommended them to many people who have all had great experiences. IMO They are by far the best street performance pads with great bite, instant warmup and low light dust. Several years ago one of my buddies was badmouthing Hawk, thinking he had installed 5.0. When I asked him to show me, it turned out that he had incorrectly installed an older model Hawk pad that didn’t meet his requirements. IMO avoid ceramic pads like Akebono. It seems like every brake pad brand has a ceramic model. People buy them solely on the promise of low dust. Their performance is no better than average. It’s much better to clean wheels well and apply a ceramic coating to prevent dust and dirt from sticking. Then stuff washes right off. |
05-31-2024, 08:35 PM | #25 |
Rep 5,875
So if you buy those new calipers and wish to change the color, I highly recommend G2USA Caliper Paint. They ship internationally. It’s a two part epoxy paint that doesn’t fade of chip. You brush it on and it flattens out as it dries to a smooth sprayed on looking finish. It comes in standard and custom colors
Note: Very important to only paint when air temp is within their specified range or it can get clumpy on the brush. Follow instructions carefully See photo of my buddy’s blue calipers that he painted in G2USA custom Ferrari Red. |
06-02-2024, 11:47 PM | #26 | |
Rep 1,453
Too bad you didn't go with the 2-piston rear Brembos. You missed an opportunity to suffer immensely trying to change pads on those calipers. It's a huge contrast compared to the fronts where you could assign an 8-year old to do the job. The fronts are ridiculously easy.
06-02-2024, 11:55 PM | #27 | |
Rep 1,453
06-03-2024, 12:07 AM | #28 | |
Rep 5,875
I was able to get several coats on. That paint goes a long way. As I was finishing up I noticed that the paint was getting clumpy on my brush. Sure enough the temperature had risen a few degrees above the allowable range. Only one brush is included in the kit. I found the same acid type brush with the aluminum handle at Harbor Freight. They were something like $3 for a pack of 36 brushes. They are great for applying glue, small paint jobs, etc. Great throw away brush |
06-03-2024, 03:54 AM | #29 | |
Rep 12
I bought this set for about 500E total with almost new OEM discs, for that price I can live with 1 piston at rear |
06-04-2024, 05:41 PM | #30 |
Rep 10
Yes, its such a pain trying to find a right spot on the rear to hit a hammer without damaging caliper paint.
12-06-2024, 04:57 AM | #31 |
Rep 5
good day guys, i have F22 M240i 2017, i want to downgrade and install 300x20 instead of 345, will i have problem on something? ( reason is remove unsprung weight ) as i know brake shoe should be D=160MM and 300x20 all is 160mm ( who have 185mm they cant install it, for example some of f30 and f32 b58, all f22-f22 b58 there is 160mm)
12-06-2024, 12:07 PM | #32 | |
Rep 177
_ObiJon402.50 alohasurftoad3515.00 |
12-06-2024, 06:36 PM | #33 | |
Rep 10,942
12-07-2024, 04:43 PM | #34 |
Rep 2,286
I'd say they are one of the least dusty pads I've used, more so if you just look at performance ones. Even with hard (and I mean to the point of straw/purple discs and the pads going off) the dust is light coloured and washes off with soap only. Very different to pretty much every other pad I've used, apart from ceramic, and my experience of them is that they're shit.
12-07-2024, 04:48 PM | #35 |
Rep 2,286
If it was a chinesium copy of an AP race caliper or an Alcon I'd say you aren't getting like for like (although unless it was very heavily machined for weight loss I'd still not be concerned about it being dangerous). Brembo OEM however are utter garbage and always have been, and likely are made in china from the same quality of material as these replacement ones. There are a few sources of these now for Subarus and Evos which came with Brembos and aside from the lack of paint are absolutely equal of the original from a finishing perspective. Is there a chance they may have issues in them? Possibly. Is the line pressure of the brake likely to blow even a substandard caliper apart if it isn't leaking? Definitely not. A brand new copy caliper vs a knackered 10-20 year old one with galvanic corrosion? It isn't even a contest, it would be the new copy every time for me.
12-09-2024, 01:22 AM | #36 | |
Rep 5
as i looked it will work, only handbrake size should be 160mm there is 2 type of it F30 F32 is 180mm and F20 F22 and some F30 (320i-328i) is 160mm rear brake pad height is 90mm, if we install 300mm rear disc, pad will work only 70mm wich i think it wont problem and remove 3KG per axle will noticeable, its only good on drag racing, not for track for sure Last edited by mica69; 12-09-2024 at 03:59 AM.. |
01-04-2025, 09:55 AM | #39 |
Rep 3
Hello, I have a 328i xDrive with stock 312 mm front brake discs. Can I change only the front ones to 340 mm and leave the rear ones at 300 mm? Is it good upgrade?
Thank's in advance! |
