BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Abnormal tire wear?
      09-24-2024, 12:43 PM   #1
VzuR
Drives: 2013 335i F30 M-Sport
Abnormal tire wear?
Apologies if this has been discussed on the forum previously.
F30 335i running ExtremeContact DWS 06 tires. 3 years, 22,500 on the tires. Put fronts and rears on at the same time.
Rears at 3 2 3 and fronts are 4 7 4. Staggered setup so rears get around 25,000 and fronts supposedly 50,000.
Attaching some pictures.
Is 4 7 4 abnormal wear pattern on the fronts? Firestone tech was hounding me for an alignment.
Just purchased 4 new tires to replace these.
Thank you!
      09-24-2024, 12:45 PM   #2
VzuR
pics attached
2013 335i F30 M-Sport | Borla S-Type Exhaust | Black Kidney Grills | Carbon Fiber Performance Spoiler
      09-24-2024, 09:06 PM   #3
LA430
Drives: 430i
Inside rear should wear a bit quicker due to camber.
If middle is less worn than outsides it would point to an under inflation issue.
What size tires and what do you have them inflated to?
      09-28-2024, 03:31 AM   #4
SD Convert
Drives: 2017 430i convertible
Lower the pressure in the back by 1 PSI and increase it in the front by 2 PSI.
Check again on the next set of tires.
2017 430i w/ Strut Brace / M-Perf brakes / M-Sport anti-sway / 255/40/18 square / iDrive-6
      11-17-2024, 08:47 AM   #5
Luke R
Austria
Drives: MINI Cooper
Isn't it normal for the front tires to wear a little bit more on the edges due to turning?
