BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Help
      10-21-2024, 01:29 AM   #1
steve430dxdrive
steve430dxdrive's Avatar
Drives: 430D XDrive
Help
Bit of an issue, got in the car this morning. Car started perfectly fine, got half a mile up the road and then lost all power then coasted to a stop and then died, now I’m getting engine start not possible, plugged in my bimmer link, no obvious codes but my battery does look like it’s had it, only reading just over 11volts, would this be the reason, surely the car wouldn’t have started 5 mins earlier?
      10-21-2024, 02:33 AM   #2
Allworth
Drives: X1 xDrive20d (E84)
What is the car mileage, how old is the battery, how old the is the car?
1995 E34 525td auto • 2016 F30 320ed auto
      10-21-2024, 02:39 AM   #3
steve430dxdrive
Drives: 430D XDrive
2014, ive had it 4 years and its done 125k
      10-21-2024, 03:06 AM   #4
Check the negative battery terminal and see what the date is...
11v is low though; so it's deffo time to replace it
Tayna do next day delivery; their Exide AGM battery is all that you need, no need to pay more unless you're desperate
Edit - seems it's out of stock; this Bosch will do just as good plus you get their 5 year warranty
https://www.tayna.co.uk/car-batteries/bosch/s5a13/
Don't forget it needs to be registered to the car; if desperate, see if a local Halfords has the Yuasa AGM battery equivalent, or maybe the Bosch
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298
MY340i808.50
ABall111.00
      10-21-2024, 04:43 AM   #5
Allworth
Is likely still OEM battery, there is a manufacturing date stamped on a battery. 10 years is plenty and is wise to replace it.
Your car started but then stopped after 5 minutes may suggest a depleted battery, poor wire connection or malfunctioning alternator.
I would advise doing a check that all terminals have a solid connection.
Then disconnecting all wires from the battery to ensure there is no parasitic drain, check the voltage then, reads low - charge it up.
10 years is roughly a mark when batteries die, especially when start/stop is always on and lots of short trips.
      10-21-2024, 04:53 AM   #6
steve430dxdrive
Drives: 430D XDrive
Well the AA guy tried a battery pack and when I tried turning it over it wasn’t even cranking, sounded like something was jammed…..I’m dreading it now
      10-21-2024, 05:02 AM   #7
Allworth
'something jammed' when cranking is a sound of a bendix not engaging when low voltage.
Next would be to check wires for solid connection/decay on battery and those connected to starter motor / alternator.
      10-21-2024, 05:39 AM   #8
steve430dxdrive
Drives: 430D XDrive
But would this cause the car to loose drive, as it did start perfectly ok?
      10-21-2024, 06:01 AM   #9
xenon
xenon's Avatar
England
1515
Drives: 2021 G21 330i M-Sport
Surely it's a pre-engaged starter, not Bendix?
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      10-21-2024, 06:35 AM   #10
bishbosh
Drives: F30 335d
2014 BMW 335d  [0.00]
I presume the car is now being recovered to a garage?
One check will be if the engine will turn over manually with a long ratchet. If so, that should rule out a snapped timing chain.
if I've helped - an Appreciate would be, er, very appreciated!
      10-21-2024, 08:05 AM   #11
steve430dxdrive
Drives: 430D XDrive
It’s been recovered and is going up on the ramp tomorrow fingers crossed it’s not that
      10-21-2024, 09:29 AM   #12
Allworth
It will all come out in a pan, keep us updated, likely electrical issue.
if it had no bendix, which is acting as a clutch between starter itself and an engine, it would have been engaged even when engine is running, which would ruin starter motor immediately.
      10-21-2024, 09:45 AM   #13
xenon
xenon's Avatar
England
1515
That's not how a pre-engaged starter works. There is no clutch or Bendix - the solenoid engages the starter pinion into the flywheel and when the engine starts the solenoid de-energises and the spring pulls the pinion back out. All BMWs with conventional ICE engines use pre-engaged starters, not inertia (Bendix) starters.
Ian
danb19792650.50
      10-21-2024, 11:08 AM   #14
Allworth
Nope, I am not disputing how it works.
In early 2014 in a partnership with Bosch they made a significant changes how its working, I don't want to describe this here, you can google it, but it will sound similar to what OP described, you can connect 11v battery to your solenoid if you want to hear it.
      10-21-2024, 03:46 PM   #15
xenon
xenon's Avatar
England
1515
Be grateful if you can post a link; I can only see pre-engaged starters when googling.
      10-28-2024, 09:03 AM   #16
steve430dxdrive
Drives: 430D XDrive
Just to update you it had nothing to do with the starter, 2 out of the 3 timing chains had snapped, need new valves, new camshafts, a couple of pistons….i had absolutely no sign of this happening with any symptoms at all.
      10-28-2024, 02:51 PM   #17
bishbosh
Drives: F30 335d
Not a good outcome, what have they quoted for the repair? I didn't think it would be an electrical issue which is why I'd mentioned the timing chain.
How often was the car serviced btw?
      10-28-2024, 04:12 PM   #18
steve430dxdrive
Drives: 430D XDrive
Serviced between 5 and 10k, the cost is the cost so it’s getting done
      12-08-2024, 09:13 AM   #19
steve430dxdrive
Drives: 430D XDrive
So all the work has been done, car starts fine and drives well….my question is as it has new valves etc etc will it have worse fuel consumption than normal?
      12-08-2024, 12:25 PM   #20
bishbosh
Drives: F30 335d
It might be a little worse as the valves, etc bed in. But I'd expect it to improve over time.
      12-09-2024, 04:30 AM   #21
Simon89
Simon89's Avatar
127
Drives: GLC43
I wouldn't expect fuel consumption to be worse and the engine should be running better due to less build up?
Current: 16' X256 AMG GLC43
Previous: 13' F30 330D XDrive
      12-10-2024, 03:44 PM   #22
steve430dxdrive
Drives: 430D XDrive
And now when the engine gets warm and the start stop kicks in every now and then it’s very slow to restart, the battery has plenty of juice it, I’m thinking the starter motor is on the way out, any ideas? From a cold start it’s fine
