10-21-2024, 03:35 PM | #1 |
Rep 35
Should there be an angle over the jack pad adaptors? - Terrified First Time DIY
Hi everyone. This is my first ever time working on my car and I'm really excited to do my first oil change, but I'm also terrified I'm going to drop my car on myself or the jack stands.
I jacked the car up and got it to the point in the attached screenshot. The stands held the weight, but I was too scared to do any work on the car because I felt like the adaptors should have been perfectly flat to trust them to not slip. So I lowered the car and posted this instead of going through with the oil change. I saw some other users had these stands and adaptors so I got them. My mechanic friend says that the slight angle is normal when only jacking up the front of the car. I have everything I need to jack the car up on stands, but I'm worried that the jack pad adaptors will slip. I'm only doing the front wheels, and I'm using a nearby parking lot. Is this much angle normal? I'm lifting a 2017 440i convertible. Torin Jack Stands Pittsburgh 2 ton Car Jack Standard Adaptor |
10-21-2024, 04:50 PM | #2 |
Rep 17,070
I only use jacks when I need to get the car high enough to do serious work underneath, or when I'm doing tire rotation, and then I use four of them. For just an oil change it's ramps.
10-21-2024, 05:54 PM | #3 |
Rep 35
10-22-2024, 02:42 PM | #5 |
Rep 541
This is sketchy to say the least.
You should put them directly on the jack stands, and not use this adapter with this particular style of jack stand. If you can, I would swap these for the ESCO or Harbor Freight equivalent which have a rubber flat top. |
10-22-2024, 02:51 PM | #6 |
Rep 35
Update: I asked a mechanic friend who said that the slight angle was inevitable if I'm only jacking up the front, which makes sense to me actually since the car is at an angle.
He told me to put the jack under the car to catch it, put chocks on the rear wheels and shake the car while on the stands to see if it falls. If it falls then better it fall on the jack + stands instead of me. I shook it as best I could and it didn't fall. So I kept the jack in place, added chocks, and went for it. The hardest part of the whole process was just getting the oil filter housing out. I can't believe it's in such a tight spot. Getting the drain plug, replacing the housing with a new filter, and filling the car were a breeze. Also, jacking it for a second time was much easier than the first. this time there was less of an angle because I got the placement a bit better and I used the stands on the lowest setting. I'm really proud of myself. |
10-22-2024, 02:55 PM | #7 | |
Rep 35
Heres what they look like: |
10-22-2024, 05:38 PM | #8 |
Rep 17,070
+1. A lift requires the 'hockey pucks' as well. I have mine permanently attached to the plastic jack pads with stainless steel screws. The reason for the shape of the jack pads is that the BMW jack has a rectangular head that fits inside the jack pad opening. A lot of good that does us, since BMW stopped supplying jacks when they brought out the 3 series.
10-23-2024, 11:19 AM | #9 | |
Rep 541
I'd rather have the jack stand "bite" the plastic a bit and attain some extra friction than have two metal surfaces sliding against each other. Here's what I suggest using in place of these ones: https://www.harborfreight.com/3-ton-...ads-58789.html |
10-23-2024, 12:17 PM | #10 | |
Rep 35
How many years have you been using them? Aren't you worried that they will crumble while you're working and fall? |
10-23-2024, 12:48 PM | #11 |
Rep 17,070
10-23-2024, 01:21 PM | #12 | |
Rep 541
Cost me 10 whole dollars. They're glass filled nylon fiber blocks (PA6 GF35), a strong plastic material with strength properties similar to common types of metal. This is the same plastic they make things like power tools out of. The ESCO/HF jack stands are excellent and do away with the need for "jack pad adapters" - all you need is a hockey puck for some stand off between the jack and the body of the car. |
10-23-2024, 01:36 PM | #13 | |
Rep 35
Please correct me if I have this wrong. So you're saying you use a circular topped jack stand, and a hockey puck, instead of a regular jack stand and jack pad adaptor? This sounds like the exact same setup... And you've been using them for years without needing to replace anything since the original ones when you bought the car? |
10-23-2024, 02:19 PM | #14 | |
Rep 541
Note how the jack point is entirely engulfed by the rubberized load bearing section of the jack stand. When the car is lowered, the plastic point sinks down into the rubber top of the stand and creates a sturdy union of the two. This is the closest replication to a 2 post shop lift you're going to get. |
10-23-2024, 02:49 PM | #15 | |
Rep 35
I have this Floor Jack and didn't put anything on top of it because I thought the plastic was enough to prevent scratches, but I may grab a hockey puck to be extra safe. I actually do like the look of this setup and may swap out my current stands because I was not a fan of the metal on metal. When I shook the car it didn't budge at all. I wonder if the people that emphasized not putting the plastic directly on the jack top were referring to the metal topped ones that look like Vs. |
10-23-2024, 02:57 PM | #16 | |
Rep 35
I'm just worried about them crumbling at the wrong time while I'm under the car since they don't have the rectangular insert. I'm 100% sure BMW knows that this makes it more inconvenient, but part of the BMW experience is being able to tell people how inconvenient our cars are. So we feel like we have some insider information when in reality it's just a common grievance we bond over. Going through struggle together builds relationships. |
10-23-2024, 04:48 PM | #17 |
Rep 541
You're overthinking this.
The jack point blocks are strong plastic that are virtually unbreakable. People use the old Y style jack stands as well, it just gouges them up a little. The jack pad adapters are designed for jacks that might not have the right "cup", not jack stands. |
10-23-2024, 06:29 PM | #18 |
Rep 17,070
These are the hockey pucks we're talking about, so named for their resemblance to...hockey pucks. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The jack point blocks are hardly indestructible. Mine got chewed to the point I had to replace them. Not by me, but by a tire shop that didn't use hockey pucks. That's when I replaced them but not before permanently attaching pucks to them. |
10-23-2024, 07:18 PM | #19 |
Rep 65
Yes, you can break the plastic jacking points. But Billfitz is absolutely correct - just use ramps for an oil change. It's much easier, you don't risk damaging the plastic jack pads, and you don't risk other damage by using the wrong central jacking point. I only use jackstands for brake or suspension work.
Billfitz8877.00 |
10-23-2024, 11:10 PM | #20 |
Rep 17,070
Even when I do a full jacking I use the ramps. It's a lot easier to lift the car high enough in the front when you've already got it lifted by that eight inches or so.
10-24-2024, 10:56 AM | #21 | |
Rep 330
10-24-2024, 05:01 PM | #22 | |
Rep 35
Also, I live in an apartment building and don't have a ton of storage space, so the ramps aren't as convenient to keep around as a jack and jack stands. Additionally, I want to do tire rotations eventually so I'll need to learn to use jacks one way or the other. |
