11-07-2024, 02:30 PM | #1 |
Rep 48
Drives: 2019 BMW 430i Gran Coupe
Lowering Springs or Coilovers
Hello, I wanted to hear opinions on Lowering Springs vs Coilovers. The basics are pretty obvious but I have heard that on bimmers coilovers aren't as recommended since they already have a pretty decent suspension.
Is it really worth it going for Coilovers and spending the extra money instead of going for lowering springs? This would be for an F36 430i that is my daily driver. |
11-07-2024, 03:22 PM | #2 |
Rep 4,701
because stock dampers are not designed for most lowering spring offerings, it's performance and lifespan will be compromised. so, it depends on how low you desire...
1)ST coilovers if you want it low to low+ 2)Eibach Pro-Kit+stock dampers* if mildly lowered is adequate enough *if affordable, instead of stock dampers, i suggest upgrading to Bilstein B4 M-Technik OEM+ replacements under the Eibach Pro-Kit, as it will perform and even ride better though slightly firmer. |
cfm56d7b6728.00 |
11-07-2024, 06:20 PM | #3 | |
Rep 10,942
11-07-2024, 08:08 PM | #4 | |
Rep 48
I'm not too sure on the budget as I was only expecting to spend around 1200 for Coilovers based on the previous research I had done but it was not quite that extensive so not too sure if that is a reasonable budget or not. I would like to keep the comfortability of the stock suspension since I'm not planning to track the car or street race it which is why I was leaning towards the lowering springs since they are quite a bit cheaper and thought they would be a pretty straightforward mod. |
11-07-2024, 08:25 PM | #5 |
Rep 10,942
The budget appears to be a bit low if installation and 4 wheel alignment fees are considered.
The debate of lowering springs vs coilovers continues in various discussion threads. Lowering spring have one disadvantage: the resulting suspension height or dynamics cannot be changed. If you want to have the option of tuning the suspension after initial installation, coilovers are the better choice. |
11-07-2024, 08:47 PM | #6 |
Rep 224
Drives: 2018 BMW 330iX Sedan
Looks really good as it is, IMO. You don't have the unsightly xDrive gap and reverse rake. I would just leave it, especially if you don't want to lose the comfort level.
BimmerF3624.00 alohasurftoad3515.00 |
11-07-2024, 09:13 PM | #7 | |
Rep 48
I know that debate is pretty much old as time and was kind of considering lowering springs mainly for a short term thing and have coilovers installed sometime later but it feels shortsighted and a waste of cash at the end. |
11-07-2024, 09:15 PM | #8 | |
Rep 4,701
if 1"-1.5" is desired, imo you'll have go with ST coilovers or a cup kit(spring/damper combo) comprised of H&R Sport or Eibach Sportline(not Pro-Kit) springs over Bilstein B8 struts/shocks |
cfm56d7b6728.00 |
11-07-2024, 09:15 PM | #9 |
Rep 48
Thank you! Yea rwd comes with its perks lol. I'm planning on keeping it stock for at least a couple of months but wanted to do some research.
11-07-2024, 09:31 PM | #10 | |
Rep 48
I have a question regarding the kits then how does it compare with a coilover one? Aren't coilovers pretty much a spring/shock combo? It's something I never really understood when it comes to coilovers as they are always marketed the end all be all but I know there are other parts to a suspension system. |
11-07-2024, 09:40 PM | #11 | |
Rep 4,701
from your pics, i believe Eibach Pro-Kit springs over your stock dampers is all you need. just a tad bit lower and a rake fix, which the Eibachs do, will look perfect. |
11-07-2024, 09:57 PM | #12 |
Rep 4,701
if you are not doing the installation yourself. the rears are basically easy, however the front suspension removal and disassembly(via spring compressor) labor cost can be a big part of the total cost of doing this.
. a front "coilover" install is easier than swapping out springs |
11-07-2024, 11:02 PM | #13 | |
Rep 48
11-08-2024, 01:02 AM | #14 | |
Rep 4,701
https://eibachshop.com/index.php?p22...w-4-gran-coupe Eibach E10-20-031-03-22 is for a RWD F36 430i/428i Amazon has'em for $290xx shipped if Prime |
11-08-2024, 09:07 AM | #15 | |
Rep 48
Also have to see if my autoparts stores have those spring compressors. |
11-14-2024, 04:38 AM | #16 |
Rep 1,649
If you don't know what you want, just go with lowering springs.
Eibach Pro drop a "Low slung suspension" car (aka M Sport) 13mm at the front and 5mm at the rear, so as said, the front biased rake dissappears quite nicely. If you're doing it for handling and ride improvements as well, then ditch the M sport dampers as they are trash. |
