BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Anyone know why my car is having a rough idle when my fans are on?
proTUNING Freaks
      11-10-2024, 02:27 AM   #1
hamid161
hamid161's Avatar
Drives: BMW 440
Hey,
Just wanted to ask if anyone knew why my car is idling very weird whenever I turn on the fans inside the cabin. I would understand if the rpm’s went up when I turn the a/c on but the idle just keeps fluctuating. I have a 2017 bmw 440i and it’s also around 92k miles if that matters. I provided a video below so that you can hear what I am experiencing. Any suggestions would be much appreciated.
rough idle
      11-10-2024, 08:04 AM   #2
scubajim
scubajim's Avatar
93
Drives: 16 BMW 435 F33
If nothing looks obvious, I would try pulling codes. If you don't have a method to check, you should. Some inexpensive options are the BimmerLink app with a OBD scan tool like Veepeak or an inexpensive scanner from the Creator line that will work with your car. Available on Amazon.
