BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > 335i xdrive N55 coolant/cooling system hose(s) replacement?
      11-11-2024, 07:24 PM   #1
vcu_ece2324
Drives: 2013 BMW 335i xDrive
Hi, Im planning on preventatively replacing my water pump and Tstat on my 2013 335i xdrive (89k miles) next month. Besides the water pump, Tstat and mickey mouse flange im also considering replacing some or all of the major hoses associated with the cooling system. However given my limited time (~1 week off of work due to the holidays) to do this i may choose to replace only the most essential hoses, at least at first. Does anyone have any advice on which are the most essential hoses to fail or need to be replaced?
      11-11-2024, 11:53 PM   #2
thatgarrett
thatgarrett's Avatar
Drives: 2012 335i Sport
2012 BMW 335i  [8.58]
You’ll want to get the overflow tank line (the skinny one running from reservoir to the top of the radiator) as those are fragile. If you are upgrading to an aluminum Mickey Mouse flange, make sure to get an OEM o ring- the ones with the kit have been known to fail and it’s not fun to repeat the repair. Most of my hoses on my 2012 still look and feel great, aside from the overflow one that I had break on me.
Nothing wrong with preventative maintenance, but replacing the pump and thermostat isn’t as common a preventative item here as on previous generations. Piece of mind isn’t a bad thing but if you are looking to save a bit or throw it at other preventative maintenance, that is an option. You done your chargepipe yet?
      11-12-2024, 09:30 PM   #3
vcu_ece2324
Yes, i've done the chargepipe. Removing the stock plastic one was more of a pain then i expected but the FTP one popped on easily enough. Thanks for the headsup on the mickey mouse flange O-ring. Just added it to the shopping cart. Glad to hear that the water pump +T Stat isn't as common of a preventative maintenance thing as in previous gens but this car is my daily and peace of mind is definitely worth that.
