BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 F32 Misfires, Fuel injection Deactivated
proTUNING Freaks
      11-12-2024, 12:08 PM   #1
mcsweeto
Drives: 2015 M-Sport 435i xDrive (6MT)
Ugh. How bad is this? Took off at a green light in first, not WOT but a pretty decent clip and got a CEL with drivetrain malfunction. DME says
DME active codes -
140001 - Combustion misfires, several cylinders: Fuel injection is switched off.
140010 - Combustion misfires, several cylinders: detected.
140201 - Combustion misfire, cylinder 2: Fuel injection is switched off.
140210 - Combustion misfire, cylinder 2: detected.
- DME shadow (inactive) codes -
140011 - Misfire: Fuel injection deactivation.
231501 - Fault entry: Send buffer full.
Something tells me I am doomed.
MHD Stage 2+ / VRSF Catted DP / ARM F3X IC / BMS CP / AFE Pro Dry S
      11-12-2024, 02:23 PM   #2
mcsweeto
Problem apparently/hopefully solved.
140210 looks to have been the cause the others the effect. Swapped out the coil on #2 and everything went away. Still waiting on all systems to ready but the motor feels fine now, not stumbling mightily like it was when it happened.
      11-19-2024, 11:00 PM   #3
Smooth_Operator
Drives: F30 BMW 335i 6MT
Yeah after reading your first message coil was my first guess... 140210 is absolutely the cause and the others the effect, I've had a few misfires before and the DME usually cuts injection whenever misfires are bad enough to throw codes
      11-21-2024, 06:38 AM   #4
mcsweeto
It was rather concerning because it happened in second when I was getting on it. I had never experienced that and began to fear the worst. All is well now.
In fact, I went ahead and did fresh coils and plugs this weekend as well as a fresh 2+ tune. Man, it's amazing how hard it pulls and that's not my imagination. The car wants to GO!
      11-26-2024, 05:32 PM   #5
Smooth_Operator
Glad to hear it! Mine would miss too under full throttle... swapped in new coils and the problem disappeared.
