11-15-2024, 03:17 AM | #1 |
Rep 7
19x10.5 squared help F30
Hey Im looking to buy a new set of wheels and i found a set i really wanna buy but im not sure if these are gonna fit.
19x10.5 all around ET35 bagged on airlift 3p |
11-15-2024, 07:34 AM | #3 |
Rep 4,702
9.5 @ ET35 is max practical square fitment without camber modification. The front fitment controls it.
robbanbtw6.00 hooligan_G016542.50 |
11-18-2024, 10:17 AM | #7 |
Rep 4,702
19x10.5 @ ET35 is too wide for the front. You will need a 12.5mm spacer for the inner lip to clear the strut, which will then cause the outer lip to poke more than 25mm over flush, which means you will be unable to turn without causing damage to the fenderwell liner and wing.
You will need to run super stretched tires, a ridiculous amount of negative camber and I'm not sure that will be enough to function. Be sure to post pics and a review. I actually want to see what it takes to make it work |
11-18-2024, 10:28 AM | #8 |
Rep 7
alohasurftoad okay thank u for the information, Stretched tires and camber I already had in mind to fix for it to work but just had to make sure it wasnt impossible, ill make sure to post pictures when im done.
alohasurftoad3515.00 |
11-18-2024, 10:30 AM | #9 |
Rep 4,702
I suggest you read through the slammed stanced thread, linked below...
https://f30.bimmerpost.com/forums/sh...d.php?t=909786 Post a query there as they may have more insight on overly wide fitments and excessive negative camber. My gut feeling remains that 19x10.5 ET35 is not possible... |
hooligan_G016542.50 m3less130.00 |
11-19-2024, 08:23 AM | #10 | |
Space Shuttle Door Gunner
6543
Rep 5,432
I've been wrong before, though. |
robbanbtw6.00 alohasurftoad3515.00 |
11-19-2024, 08:24 AM | #11 |
Rep 7
hooligan_G01 yeah maybe😅 we’ll see.
11-19-2024, 08:31 AM | #13 |
Rep 7
hooligan_G01 Yes, I’ll make sure to update this thread with the results!
