BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > I need help - F30 2017 330i xDrive
      11-16-2024, 04:02 PM   #1
FancyTie
FancyTie's Avatar
Drives: 2017 330i xDrive
My handbrake seems to have a problem. I hear an annoying sound while driving. If I pull the handbrake just a bit, it stops. Is it the shoe inside the drum?
Anything else?
Loose cable?
      11-19-2024, 10:07 AM   #2
gunnerxq
gunnerxq's Avatar
Drives: 2015 335i xDrive 6MT
Try this.
Just need to jack up one side and remove one lug nut. Very easy to adjust the handbrake this way. I've done it on my E90, can't see the F30 being too much different.
Former E90 325i:
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
      11-19-2024, 10:56 AM   #3
cfm56d7b
Caveat: remote diagnostics are what they are.
This could very well be a known issue: the plastic OEM parking cable clip is broken.
https://f30.bimmerpost.com/forums/sh....php?t=1997235
Replace it with a metal clip instead.
gunnerxq233.00
      11-20-2024, 11:42 AM   #4
FancyTie
FancyTie's Avatar
Could be this. Was my first thought but my car doesn’t do any sound similar to those videos so I can’t tell if it’s the plastic bracket!
      11-20-2024, 11:48 AM   #5
FancyTie
FancyTie's Avatar
Originally Posted by gunnerxq View Post
Try this.
Would make sense!
Rear wheel can definitely move when car is jacked on one side with ebrake
