BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > N55 Engine won't start
      11-17-2024, 09:27 PM   #1
Viken365
Drives: 2014 335i
Replaced the oil filter housing gasket and the intake manifold the other day. Upon completion, car would crank but not start. Tested the car for codes and these are the ones it’s shooting.
I checked all the connections in the connections and they all seem to be seated properly.
Any suggestions?
      11-19-2024, 05:07 AM   #2
scubajim
scubajim's Avatar
93
Drives: 16 BMW 435 F33
Anything that was unplugged during the repair should be disconnected cleaned and re connected. It has to be something you overlooked or got dirty during your repair. Buy some electrical contact cleaner and spray the connections as well.
Billfitz8865.00
jsouth115.50
      11-21-2024, 04:07 AM   #3
BashShah
Drives: 2012 335i Sedan
yup, sounds electrical, cause you replaced mechanical parts and that should be just remove and replace.
but this sound like an over site or some connectors not installed correctly or not making contact.
