BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Fuel tank door keeps locking
      11-18-2024, 11:54 AM   #1
bogdantica26
Drives: BMW 3-series F31
If anybody had this problem please give some advice. My fuel tank door keeps locking (when the car is unlocked, obviously). I need to use that emergency unlock green thing every time i go to refuel and it's getting annoying.
      11-21-2024, 04:10 AM   #2
BashShah
Drives: 2012 335i Sedan
keeps locking or does not unlock are 2 different things.
either case, sounds like the either door lock actuator itself.
hopefully it is not another module, like an FRM.
Any codes?
Billfitz8877.00
      11-26-2024, 06:33 AM   #3
bogdantica26
Any codes?
it does not unlock unless I pull the emergency green string, I have to do that every time I have to refuel
      11-26-2024, 08:06 PM   #4
BashShah
You may have to replace the actuator
this is the only video on a convertible I could find.
It should be a lot easier on a sedan or coup as there is other hardware to remove except the wall cover.
look at 4:41 min and forward... on this video.
