11-19-2024, 11:41 PM | #1 |
Rep 3
Max Wheel Size and Tire Width for 2016 340i xDrive?
I am looking to buy the Apex Wheels ARC-8s for my 2016 340i xDrive. I am wondering what the max wheel size and tire width I can go in the front and back. I have the track handling package with the blue M brembo brakes and on OEM 19" staggered wheels, however, I am trying to switch to a squared setup. I was looking at either getting the 19x9.5 or 19x9 option for the wheels, but I don't know what is the widest I can go without rubbing or any modifications to the fenders. Also, I already have 255/35/19 tires in the rear, if I buy two more 255/35/19 tires to go in the front since I want a squared setup, will they fit?
11-20-2024, 08:44 AM | #2 | |
Rep 765
'25 M850ix GC
BMW CCA 30 years |
hooligan_G016542.50 |
11-20-2024, 10:02 AM | #3 |
Space Shuttle Door Gunner
6543
Rep 5,432
Aggressive Street Fitment (square setup)
Wheels Front Wheel Size: 19x9" ET28 (ARC-8) or ET30 Rear Wheel Size: 19x9" ET28 (ARC-8) or ET30 Available in: ARC-8, ARC-8RT, EC-7, ML-10RT, SM-10, VS-5RS Tires APEX Staff Pick: Front Tire Size: 255/30-19 Rear Tire Size: 255/30-19 Direct fit. Slight front negative camber recommended. 245/35-19 tires can also be used, but tire models that run wide may cause rubbing. https://apexwheels.com/fitment-guide...-fitment-guide |
Llarry22725.00 |
11-20-2024, 11:22 AM | #4 |
Rep 4,702
255/35/19 on 19x9.5 ET33, square
hooligan_G016542.50 m3less130.00 |
11-21-2024, 09:33 PM | #6 | |
Rep 3
11-21-2024, 09:59 PM | #7 |
Rep 4,702
in the link below is a F36 with 255/40/18(26.0") on 18x9.5 ET35 square, the same 3-dimensional tire "footprint" as a 255/35/19(26.0"). at ET33 yours would be poking 2mm more. there will be no rubbing issues.
https://f30.bimmerpost.com/forums/sh...&postcount=460 added link to slicer's F31 with 255/35/19 ET35 lowered, no rub. your's would poke 2mm more and have 2mm more clearance from the strut(a good thing), which is pretty damn close at ET35. https://f30.bimmerpost.com/forums/sh...8&postcount=16 . Last edited by alohasurftoad; 11-21-2024 at 10:07 PM.. |
