BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > MHD showing 22psi stock turbo
      11-25-2024, 06:59 AM   #1
fortythirtyfive
Drives: 435i
Recently installed the b58tu hpfp to run the MHD stage 2 hpfp tune.. performance is noticeably better, however my log is showing a peak of 22psi on the stock turbo
Am I right in thinking this is just how the "brapp" overrun feature works? Surely it's not making a full 22 psi under load.. it appears to be at the end of gear 4 when I let off for a moment so that's what makes me question it.
Other than that I'm now seeing a peak of 656nm torque and 18.6psi during 5th gear pulls.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, B58tu HPFP, MHD Stage 2 HPFP 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
AmuroRay3097.00
      11-25-2024, 08:09 AM   #2
AmuroRay
AmuroRay's Avatar
3097
Drives: M235i
Can you post a full log?
Mods: Yes.
As long 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
      11-25-2024, 08:52 AM   #3
fortythirtyfive
Drives: 435i
Yeah my bad
https://datazap.me/u/producerlawson/...og=0&data=4-20
Not exactly a traditional 4 to 5th as I let off and then continued a bit through 5th. We've got icy roads and 2c ambient temps so it was very slippy haha
2015 435i - 401whp
AmuroRay3097.00
      12-14-2024, 04:56 PM   #4
PLEB
PLEB's Avatar
Belgium
Drives: 2014 BMW F32 435i EWG
Hey,
Have you changed the DV valve?
Maybe the DV is just to slow to respond, so the pressure builds briefly before being vented.
Should be fine ig?
