BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Endless WGDC issues
proTUNING Freaks
      11-25-2024, 04:24 PM   #1
karbonation
Drives: 2013 BMW 335i xdrive sport
Endless WGDC issues
So i'm beside myself on what to do next.
Tuner has stated that I have WGDC issues and that I am not achieving "target boost". Take the car in and perform the following:
1. Check codes: no codes for boost leak or any other issue
2. Check WG operation: no sign of abnormal operation, wear, damage, etc
3. Replace boost solenoid: Done
4. Perform Vacuum test: Done - no issues
5. Perform Smoke test: Done - no issues
6. Perform soapy water test: Done - no issues
7. Test drive: no issues
I dont know what else I can do other than replace the turbo.
Is there such as "wastegate replacement" or "wastegate repair"
Apologies, not super technical
2013 F30 N55 xdrive PWG, WMI, PS2, Spool 2.5 HPFP, ERW 2.0 LPFP, all other supporting mods
      11-25-2024, 08:19 PM   #2
NEWTRON
NEWTRON's Avatar
96
Drives: F32 435i
here you go https://www.pureturbos.com/product/b...gate-actuator/
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
      11-25-2024, 10:47 PM   #3
karbonation
Thanks for this.
The only thing throwing me off a bit is that I'm being told there are no issues with my wastegate.
Does the heavier duty wg just better at holding pressure especially for bigger boost applications?
      11-29-2024, 09:07 PM   #4
E36M3
Drives: 97 M3, '14 335i, '12 X3 35i
Change your valve cover. Sounds strange but your vacuum reservoir is part of the valve cover and mine cracked internally so you wouldn’t have seen smoke on a smoke test. Also check the hose from the vacuum pump as mine was cracked on our PWG N55. Both made it so insufficient vacuum was reaching the wastegate. Once fixed power was back.
