BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 540i fitment question
      12-05-2024, 12:05 AM   #1
540iCarbonGolfing
Drives: BMW 540i 2017
BMW G30 M SPORT 2017 540I
86428 wheels off an M850i
Rear 20x9 et41
Front 20x8 et26
255/35 285/30 too wide?
H and R springs make a difference if wanting to lower eventually?
      12-05-2024, 01:29 AM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
Rear 20x9 et41
Front 20x8 et26
255 is too wide for 8" and 285 is too wide for 9".
      12-05-2024, 09:40 AM   #3
540iCarbonGolfing
So keep the OEM 245 275?
      12-05-2024, 11:59 AM   #4
alohasurftoad
if you want to try and overpinch a wide tire with low profile sidewall, that's your choice.
on 20", min rim widths are 8" & 9" for 245 & 275, respectively and the most pinch i'd do. imo the best tire performance fit is 235 & 255(or265)
      12-05-2024, 12:20 PM   #5
540iCarbonGolfing
Ok thanks. Looking to upgrade from 19s. Not sure if best idea but 20s should fill the well a bit more?
      12-05-2024, 12:27 PM   #6
alohasurftoad
filling the wheel well depends on the overall tire diameter, not rim diameter.
if you want to fill the wheel well with your 19", upgrade the tire width 10mm(max 20mm), with the same aspect ratio.
      12-07-2024, 10:41 AM   #7
540iCarbonGolfing
So go up to 275 40 and 245 45 from 275 35 245 40? How do I know of 285 40 and 255 45 fit.
      12-07-2024, 12:39 PM   #8
alohasurftoad
No...
What are the 19" tire sizes? And their rim width and offset?
      12-07-2024, 06:35 PM   #9
540iCarbonGolfing
No...
Trying to decide if its smart to upgrade from my current 19s to these 20s
