12-07-2024, 05:10 AM | #1 |
Rep 106
Tyres - Again! Run-flat v Non….
F31 335i currently with original staggered runflat setup, 18” wheels, and adaptive suspension. Time to replace and currently decided to go for the CrossClimate 2 as an all year round. They do the 225/45 18 in Runflat or non runflat. The 255/40 is only in non run flat.
All say that ride comfort is better with non runflat - but does that make it more bouncy? Current ride comfort with the 18s and adaptive is good. Some say that steering is better (more responsive) with the runflat? So, do I go square with the runflat, or stay staggered with non? Any thoughts and specific experiences much appreciated Thanks
F31 335i Tanzanite Blue with lots of boxes ticked...
1999 E39 528i Touring (gone), 1995 E36 328i Touring (Some sod wrote it off), 1986 Toyota MR2 Mk 1 (Modified) (Sold), 1979 VW Scirocco Mk 1 (Modified) (Sold) |
12-07-2024, 07:15 AM | #2 |
Rep 2,764
Which 18" wheels do you have?
I run 18" 405Ms for summers, Style 397s for winters with 235/45/18s all round - Goodyear Assym 6s summers, Goodyear Vector Gen3 all seasons for winters. Alloys are 18x8 all round I also run CC2s on my 130i staggered fitment as Ive staggered wheels If your 18s are the same size all round; get the same sized tyres all round You could go 235/45 or 245/40 18s
12-07-2024, 08:01 AM | #3 |
Rep 7
See my post:
https://f30.bimmerpost.com/forums/sh...&postcount=120 I don't find the CC2s bouncy and handling around bends is sharp and not wallowy. Still to try them in summer though. |
12-07-2024, 09:34 AM | #4 |
Rep 1,158
I have 18" runflat CC2s on my winter wheels. I also have adaptive suspension. No complaints at all.
They were still on the car for the early part of the summer and were just as good in the warmer weather. I'll be fitting them back on the car in the next week or so. |
gembrain39.00 |
12-07-2024, 09:54 AM | #5 |
Rep 683
always had 18" non runflats on my E90, and went back to 19" non runflats on my F30.
Ride is night and day. but you will always have some, that for whatever reason, prefer RFT. I just don't get it though.... I've always preffered a staggered set though.
MOD's/DIY list
Bonnet Badge Repacement, LED Door Sills, 35%VLT Window Tinting, 442m alloys, Stainless Steel Pedals, Front and Rear Disk Replacement, GTechniq C1 Detail, Gladen HIFI upgrade, LED DRL's, 90mm Stainless Tailpipe, Complete Leather Reupholstery. |
danb19792615.50 |
12-07-2024, 10:51 AM | #6 | |
Rep 1,158
I've got 19" PS4 RFTs on my summer wheels and 18" RFT CC2s on my winters. No issues with either. That said, I stick with RFT tyres for convenience. Being able to drive off the motorway on a cold wet night is worth more to me than any marginal improvement in comfort. I appreciate that RFTs won't get you out of every situation, but the odds are on your side. I think the adaptive shocks do help with comfort though. I find is surprisingly compliant in 'comfort' mode. Certainly softer than non adaptive sport suspension. |
12-07-2024, 11:21 AM | #7 |
Rep 1,640
I use the PS4 runflat as well (18") and "for whatever reason" I just prefer them to non-runflats. Better steering and better cornering on the limit. It's just basic physics. Stiff sidewalls improve cornering feel and don't roll over on the rim so much when pushed, which is exactly the same reason why a sports non runflat tyre handles better than a crappy ditch finder non runflat.
As you say, the Michelin runflats are no where near as harsh as the shitty OE * Bridgestones and Pirellis. |
12-07-2024, 05:37 PM | #8 | |
Rep 106
12-08-2024, 06:11 PM | #9 |
Rep 32
I ran the Goodyear asy 2 RFT for a while and they were perfect. Think people base their opinions on the dreadful s001 from factory. Using other brands are fine tbh
12-09-2024, 05:58 AM | #10 |
Rep 683
I can understand that for safety reasons runflats have an advantage.
But ime you are more likely to breakdown and be unable to get off a motorway, than get a puncture so severe you can't carry on driving and exit. But then i've always wondered why M3 and M4 would come non runflats, if runflats are better for performance?
MOD's/DIY list
12-09-2024, 07:08 AM | #11 | |
Rep 2,286
Stiff side walled tyres need softer rubber to create the same amount of grip as you actually need tread movement to turn and brake. Track tyres like AD08's etc have very stiff sidewalls but very soft tread (even on the road I killed a set of ultra soft R888's in less than 2k miles) but for a road tyre sold to the masses you need harder rubber so they last a reasonable length of time. I've found winter run flats to be better predominantly I suspect because of the softer rubber that's generally used. A performance tyre isn't just about ultimate traction but feel and balance, and that's where non-RFT's have the advantage, as it's much easier to tune them without the premise that the sidewalls need to be drivable with no air in them for a decent period of time. |
davethefish147.50 |
12-09-2024, 11:40 AM | #12 |
Rep 683
I agree with that, wish i had the space in the boot under the mat to put my space saver.
But I do carry a space saver + scissor jack and brace, as i very rarely carry anything in the boot.
MOD's/DIY list
12-10-2024, 07:43 AM | #13 |
Crustacean denier
471
Rep 649
Sorry to jump on the thread but I wonder if I can get some thoughts on my conundrum?
I have a 340d x drive, currently with RF Bridgestone Potenza on the front at ~6.5mm and Turanza on the rear at ~3.5mm and I'm concerned that the difference is going to have an adverse effect on the transfer case, so I'm looking to replace the rears. Ideally I need to stay on RF, however I'm not too keen on replacing the Turanza like for like as the general consensus seems to be that they wear quickly. If I wanted to change the rears to another brand of RF and keep the Potenza on the front am I asking for trouble? I'm thinking something along the line of Goodyear Eagle F1 Asymmetric 3 which are available * marked etc? TIA |
12-10-2024, 08:09 AM | #14 | |
Rep 3,387
I would always stick with the same manufacturer / tyre type front and rear. So repace rears with same and next time round you just replace all 4 for tyre of your preference. I had a similar situation RFT all round 6mm on all, 2 rear ones were mis-shapen so considered all options in the end replace the rears for same even though I dislike tye tyres and would go to non run flat and a different manufacturer, it served the purpose for the time. I now have a matched set of RFT with 6mm (still) fronts and rears on 6.5mm, so I have an option to sell a full set which someone my be looking for to offset the cost of some new rubber that is more to my liking, without the possible issue of transfer case issues. Last edited by Alscoob; 12-11-2024 at 03:44 AM.. |
12-10-2024, 09:17 AM | #15 | |
Crustacean denier
471
Rep 649
12-10-2024, 03:13 PM | #17 | |
Rep 2,286
cramsnik470.50 |
12-13-2024, 02:23 PM | #18 | |
Rep 1,640
I assume a runflat has to be binned anyway after making it to your destination, so you're in for a new tyre regardless. I don't think they can sustain running in 'flat' mode for many miles either? 50 or so max is it? At no more than 50mph or less? Can't remember the guidelines. Horses for courses really. I had no issue carrying a can of goo when running non runflats, but call me crazy, I just prefer the feel of runflats. I'm not bothered about what they do when they go flat tbh! Runflats are more for average Joes and a way for BMW to save money by not including spare wheels and widow maker jacks. M division are way more focused with tyres on the M cars compared to the bread and butter cars, and are often made specifically for them. So it's a different kettle of fish with the Ms from tyres, to dampers to body bracing. All substantially different to the non Ms. |
12-20-2024, 04:13 AM | #19 |
Rep 247
Last week, I had a puncture on a dual carriageway. There was no hard shoulder, and it would've been bloody dangerous to try and change a wheel there, so I was really grateful for the RFTs, meaning I got home in one piece.
I had been planning on ditching the RFTs purely on the larger range of non RFTs available, but in the end I put on 4 Goodyear AS3 RFTs for £710, fitted by my local F1 Autocentre (young lads, and petrolheads so trustworthy). The RFT v non RFT discussion will go on forever, but if anyone is thinking of putting these on their staggered 19"s, I'm really impressed with the GYs. It drives like a different car completely (although tbf I did have ditchfinders on the front). I've covered about 600 miles now, and in all aspects they are spot on. |
12-21-2024, 05:28 AM | #20 |
Rep 1,640
Runflats like a lot of other things have improved over the years, so glad you found one that works for you. What's it like driving with a flat runflat? Not experienced it yet, and hope not to either! |
01-04-2025, 07:24 AM | #21 | |
Rep 247
TBH, not too bad though, didn't once feel as if the tyre was going to shred.... |
01-04-2025, 07:39 AM | #22 |
Rep 51
I have gone from Michelin PS4 back to Pirelli RFT. Reason being I very rarely push the tyres anywhere near the limit or drive erratically so I was disappointed with 15k from all 4. Also the roads are in a shocking state and I couldn’t shake the feeling of needing recovery if I was far from home. Not noticed any significant difference so far.
