BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Widest 19" on 540i?
      12-12-2024, 12:11 PM   #1
540iCarbonGolfing
Drives: BMW 540i 2017
Widest 19" on 540i?
Hi would these fit? Dont think I want to go up to 20s so is this the widest 19 can fit? It fit on an m3 seeing if itll fit on my 540i m sport.
      12-12-2024, 12:21 PM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
although i don't know the 5series that well, my 1st intuition is they are too wide with offsets too low. they will poke out a lot and will rub the fenderwell while turning. if you want better advice, you need to provide your stock wheel/tire specs...front&rear tire sizes, rim widths and their offsets.
      12-12-2024, 12:25 PM   #3
540iCarbonGolfing
Oem specs
      12-12-2024, 12:40 PM   #4
alohasurftoad
it probably won't fit for the reasons i described earlier. here is a view comparing the stock front size with the planned M front size.
      12-12-2024, 12:45 PM   #5
alohasurftoad
rear comparison. again, i don't know the 5series well. if you think it has room to poke 45mm+, then try it out.
      12-12-2024, 01:18 PM   #6
540iCarbonGolfing
Prolly not then? Surprised they fit on an m3.
      12-12-2024, 01:45 PM   #7
alohasurftoad
M3/4 have flared fenders and fenderwell cavities that are designed to accomodate wide tires at wider track width. when you put a wide tire with low offset in normal cavity, it oftens rub the fenderwell liner while turning at or near full lock and both fenderlips under large suspension compression.
i don't know the 5series so i cannot give you a definite answer. my gut feeling is that things will be very close and the front rubbing while turning is likely.
