08-18-2018, 04:37 PM | #1 |
Rep 11
HDD failure, iDrive stuck on "starting navigation system"
Nothing works except radio. Out of warranty. New unit costs $2500 just for the part.
Is there a way to replace the hard drive itself without replacing the head unit? Please help! 2016 428i |
08-18-2018, 04:57 PM | #2 |
Rep 10,473
08-18-2018, 05:41 PM | #5 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
It would be bench programmed just like our retrofit kits. PM me if you need help with that.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
IK6SPEED4488.00 |
08-18-2018, 08:20 PM | #7 | |
Rep 11
Edit: is there a way to put a SSD in there? I dont want it to happen again. When it happened, I unplugged bimmertech amp and it started working until I plugged the amp back. Idrive restated immediately and issue came back. I'm afraid that the amp could be causing it. Had no issues for a little while Last edited by ea55; 08-18-2018 at 08:30 PM.. |
08-18-2018, 08:24 PM | #8 | ||
Rep 10,473
If it's truly just over 50k miles, you might try and see if they will make exception as electronics really should not fail on a 2016 vehicle regardless of mileage. It's not like other mechanical parts for wear and tear. |
08-18-2018, 08:50 PM | #9 | |
Rep 11
08-18-2018, 08:52 PM | #10 | ||
Rep 10,473
08-18-2018, 10:33 PM | #12 | |
Rep 1,976
The QNX system will not boot up if it detects that you swapped the HDD so the only way to fix this would be to replace the head unit.
02-12-2019, 10:28 PM | #13 |
Rep 440
Drives: 2013 335i xDrive
Are you talking about Blackberry QNX Car Platform? Could that not be hacked, er, coded to match the new SSD? I'm interested in this also because my idrive startup time is starting to vary quite a bit - I think the hard drive is starting to show it's age.
I'm not completely useless, I can be used as a bad example.
02-13-2019, 06:39 AM | #14 |
Rep 5,456
My iDrive screen has randomly restarted while in use twice over the past month.
Im wondering if my head unit is dying as well? |
02-14-2019, 04:56 AM | #15 | |
Rep 153
Or it's S/N related. |
01-04-2022, 05:03 PM | #16 | |
Rep 4
